ital BW] Re: UC VM 4.3 (was Epson 7500 what inks should I use?)
2003-02-18 by Paul Roark
Andy,
>... Will the MIS-VM 4.3 be usable with printers other than the 7500?
Yes, I balanced it on my 1160 using the standard curves.
>I find the cool curves useful, especially with Eclipse Satine
>Soft White and have even increased the toner on occasion.
The new inkset is a bit warmer than the old one.  The "nc" curve, for
example, is dead neutral as opposed to slightly cool on EEM with the old vm.
However, there is plenty of coldness still in the toner.
>...if one converts from the original MIS-VM to the new one
>with a CIS system is it advisable to do a purge or some other method
>of clearing the old inks out?
Yes, purge the old inks.  I would not mix the inksets.  The toner is also
new and matched to the grays.  If you mix the inksets you might get some
weird results.  While I don't think there is a clogging problem, I think CIS
heads ought to be replaced every year or so anyway.  I'm not sure how long
that sponge material lasts.
http://www.PaulRoark.com
RE: [Digital BW] ital BW] Re: UC VM 4.3 (was Epson 7500 what inks should I use?)
2003-02-19 by Doug Fisher
Hi Paul -
>>Yes, I balanced it on my 1160 using the standard curves.<<
With which papers will the combination of your curves and new ink work?  As
a user of your current VM inkset, I really want to try printing on something
else besides EAM/EEM.  The ability to print on semigloss surfaces via the
new inkset really appeals to me but won't individual profiles need to be
made for papers other than the current EEM/Eclipse Satin?
Doug
2003-02-19 by Paul Roark
Doug,
>>>I balanced [UC VM 4.3} on my 1160 using the standard curves.<<
All the usual papers plus RC papers -- if you use a black ink that is
compatible, like MIS 7600 Photo Black, UltraChrome Photo Black, or Epson
Archival Black.
>  ...I really want to try printing on something else besides EAM/EEM.  >The
>profiles need to be made for papers other than the current
>EEM/Eclipse Satin?
I tested the inks and curves on Epson Premium Luster, Ilford Smooth Pearl,
and (cheap/readily available at Costco) Epson Photo Paper.  For the most
part they print OK with the existing curves.  The warm curve is the only one
that seems to be off enough to be a problem.
I'm sure detailed profiles would help with any paper (and printer), but the
existing curves make fine prints and a good starting point for those who
want to tweak the system to optimize it for any particular RC paper.
2003-02-19 by Vincent Orlando <orlandovl@hotmail.com>
Paul, will the MIS-VM 4.3 work with the 1200 and the 1200 curves. I
probably have one of the few 1200s that print beautifully, no banding
and no clogging using the VM set and your curves.
Vinny
http://www.wulfsden.com
<paul.roark@v...> wrote:
> Andy,
7500?
for
the old vm.
method
is also
some
think CIS
how long
> Paul
Re: [Digital BW] ital BW] Re: UC VM 4.3 (was Epson 7500 what inks should I use?)
2003-02-19 by Edward Wiseman
OK Paul..
I'm probably pushing the envelope here, but how about a UC VMS 4.3XXX
"SEPIA" version that will work with my 1160??..
THX as always!!
Eddie Wiseman
Sent: Wednesday, February 19, 2003 7:17 AM
Subject: [Digital BW] ital BW] Re: UC VM 4.3 (was Epson 7500 what inks
should I use?)
> Vinny
> > Andy,
> 7500?
> for
> the old vm.
> method
> is also
> some
> think CIS
> how long
> > Paul
> Please visit the Group Homepage to check the Files, Bookmarks, Polls and
page.
them short.
&amp;amp;quot;flames.&amp;amp;quot;
resources on the homepage.
Vinny wrote:
> will the MIS-VM 4.3 work with the 1200 and the 1200 curves. ...
It should print very much like the old MIS VM.
I think these new 100% pigment inks may be a little less forgiving of
printer defects than the older inks.  With the 7500, which I've heard is
close to just being a large 1200, I can induce banding with curves that are
written in "wrong"  (meaning that it is not as tolerant of some of the
manipulations I'd otherwise use).  Hopefully the 1200 curves and average
1200 will be fine.
>UC VMS 4.3XXX "SEPIA" version that will work with my 1160??..
It might be in the cards later.  The new Vm has a much warmer warm end.
It's not as dark as the vm-s could go, but I'm going to live with it for a
while to see if the one inkset can do it all.  I'm sure, however, that some
will want a full-on sepia.
I'll have to search for a good base gray ink.  The light black MIS UC clone
ink used in the UC VM 4.3 is warmer than I'd like for a starting point for a
vm-s inkset.  The vm-s gray needs to be slightly cool.  I don't like to add
any more pigment than necessary to get to that point.  A very warm starting
point means the use of too much color pigment.  I have a couple of more
neutral candidates for a starting point, but have not had the time to test
them.
Now, as a monochrome sepia, the UC light black is so warm it would make a
perfect starting point -- and that is what I might do.  In fact, I might mix
a gray that is sepia and see if the blue toner can pull it all the way to
neutral without unacceptable dots showing.
