about scanning B&W
about scanning B&W
2003-02-21 by HPA
The grain of scanned B&W is primarily dependent on the film developer.  Many
labs use stuff like D76 or HC110 because of cost and replenishment.  much
better choices can be made.  If your scans are too grainy, try Kodak XTOL.
This suggestion is particularly applicable to anyone who shoots Tmax.
The developer is very sensitive to contaminents.  If your result appears too
thin, that means your darkroom tanks and vessels are not clean enough.  so
clean everything more thoroughly than usual.
I believe the invention of this developer by the Kodak engineering team is
possibly the biggest advance in chemical photography in the last decade.
The improvement is substantial.  However, the chemicals cost about double
what the old developers can be had for.
Thomas Robinson
RE: [Digital BW] about scanning B&W
2003-02-22 by Austin Franklin
Thomas,
> Many
I strongly disagree that "much better choices can be made" than processing
Tri-X and Plus-X in D-76.  It depends on the film, and what you want the
film to look like.  I have tried every developer, short of mixing my own,
and nothing works as well, for me, as D-76 1:1 for the films I mention.
I agree with XTOL for TMAX, but I found it isn't near as good for Tri-X,
Plus-X and Delta 100/400 as D-76.  Just my experience.  I only use XTOL for
Neopan 1600 and Delta 3200 and for what little TMAX films I occasionally do.
> appears too
I have never heard that with XTOL.  I do know that if they film is thin, the
developer is exhausted.  This can be caused by three things in my
experience.  One is insufficient amount of solution per roll.  This is
specified in the instruction sheet and pretty much should be adhered to.
Second is mixing it with aerated water.  Nothing kills it faster than that.
Let the water sit for a while before mixing.  Third is just time.  XTOL
gives no indication of being exhausted, unlike most other developers that
turn brown/yellow.  I only use fresh XTOL, and will not hesitate to throw
out XTOL that's been around for a month.  It also MUST be kept in FULL
sealed, preferably glass, bottles.  Plastic bottles seem to not work near as
well for XTOL.
Obviously, you like XTOL.  I find it's tonality and grain
objectionable...and find D-76 gives much better and smoother tonality, and
"easy" grain.
Austin
Re: [Digital BW] about scanning B&W
2003-02-22 by Mark Savoia
Try Ilfotec DD film developer. It works great. Made for dip and dunk
processors but you can use it in a batch setup also.
Mark
Austin Franklin wrote:
> Thomas,
> > Many
> much
> XTOL for
> occasionally do.
> > appears too
> enough.  so
> thin, the
> that.
> near as
> well for XTOL.
> team is
> "easy" grain.
> Regards,
> Austin
> Yahoo! Groups Sponsor
> ADVERTISEMENT
> <http://rd.yahoo.com/M=246920.2960106.4328965.2848452/D=egroupweb/S=1705019182:HM/A=1464858/R=0/*http://www.gotomypc.com/u/tr/yh/cpm/grp/300_Cquo_1/g22lp?Target=mm/g22lp.tmpl>
> Please visit the Group Homepage to check the Files, Bookmarks, Polls
> and other resources as they are often being updated. The page is at:
> If you wish to receive no emails or just a daily digest, or you wish
> this same page.
> - As threads develop, trim off excess portions of earlier messages to
> keep them short.
> &amp;amp;quot;flames.&amp;amp;quot;
> - Before posting a question, search the message archives and the
> various resources on the homepage.
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
> <http://docs.yahoo.com/info/terms/>.
