Re: [Digital BW] WHEN will we get clog-free printing?!
2003-02-22 by Jerry Olson
I never had had out of the ordinary clogs with MIS inks. Very rarely do
I get one. Are you sure it isn't
air in your feed tubes?
Jerry
Harry Saddler wrote:
> Hate to bring this up yet again, but I just set up a brand new 1280, MIS
> CFS with MIS VM inks, and I've got clogged nozzles. Everything was
> beautiful for the first week, then I didn't print for a week, now I can't
> get it unclogged. I've done  4-5 iterations of the three-nozzle-
> cleanings-then-print-purge-pattern routine, with no luck.
> So, what's the current wisdom on 1) fixing and 2) preventing this? I'm
> reluctant to start the whole windex routine; I did that for two years
> with my 1200 and ended up replacing the printhead, twice.
> PS: the prints with this system (pre-clog) (using Roark curves) are
> beautiful. I JUST WANT TO START PRINTING!!
> Harry
> Please visit the Group Homepage to check the Files, Bookmarks, Polls and other resources as they are often being updated. The page is at:
> - Good manners are required at all time. No personal attacks or "flames."
> - Before posting a question, search the message archives and the various resources on the homepage.
2003-02-22 by Bob_Michaels <Bob@BobMichaels.org>
Like Jerry, clogs just are not a problem for me either. I've used MIS
VM inks in carts and currently using MIS FSN inks in a MIS CIS.
It may be humidity dependent. I live in FL where the humidity has
never been below 60% even inside in the winter with the heater
cranking. But then I think Jerry lives in North Dakota.
Bob Michaels
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Jerry Olson
> Jerry
1280, MIS
I can't
> > Harry
2003-02-22 by Harry Saddler
I don't think it's air in the tubes; I haven't seen any. The CFS charging
seemed perfect, and the tubes haven't been out of the ink since.
It has been somewhat dry here. I wonder if it's possible to keep some
humidifying agent in the printer when I'm not using it?
Harry
>Bob Michaels
>> Jerry
Re:How I stopped getting clogs, was WHEN will we get clog-free printing?!
2003-02-22 by jim hayes <jimhayes@frii.com>
The CFS and CIS tubes are made of different material- that may
contribute.
Humidity here gets to 20% and I have endless problems. I even humidify
to 45%RH but no dice.
So I switched to the 2200/IP5 and an amazing difference. Only 3 or
four cleaning cycles TOTAL needed to get perfect nozzles in 2 1/2
months of operation compared to cleaning cycles needed two- 8 times a
week for 1280/VM roughly.
I have an idea why I got banding occuring in midprint six times with
2200. The Epson driver everyso often makes a lot of cleaning cycle
noise without being told to. I think it runs a cleaning cycle whenever
it feels like it-built into Epson driver. If IP5 is used, the Epson
driver isn't, except it sometimes makes noise when first turned on.
Just a wild guess right now. But if IP5 doesn't call for a cleaning
cycle now and then, maybe banding will suddenly occur. This is VERY
infrequent, I am very happy with my 2200 wrt clogging. Running a purge
pattern in draft mode with plain paper w/Epson driver before using IP5
seems to be helping with the banding stuff...I note that it sometimes
does a cleaning cycle noise during this.
Jim H.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Harry Saddler
charging
some
> Harry
MIS
> >Bob Michaels
rarely do
> >> Jerry
