Re: [Digital BW] Epson RIP vs ImagePrint 5
2003-02-25 by Thomas Fors
Sent: Monday, February 24, 2003 9:36 PM
Subject: [Digital BW] Epson RIP vs ImagePrint 5
> From the latest reports, it would seem the Epson RIP may cure the
> metamerism problem of the standard driver and produce neutral grays,
> but without IP's ability to tone (though this can be done in PS--if,
> that is, the Epson RIP can be made to work without converting to
> grayscale).  I don't know if the Epson RIP affords any advantage when
> printing in color, as IP is purported to do.
After following Sandy Cornelius' workflow, I now believe that the Epson RIP
may also eliminate metamerism with the proper settings (It looks to me like
it prints using Black and Light Black inks only for grayscale images)
although the prints did not look neutral at all to me.  Rather, they were
very warm.
I suspect trying to tone the image in Photoshop before printing it would
require printing in color mode which would most likely reintroduce the
metamerism.  I just tried to print a slightly cool toned image using Sandy's
Epson RIP settings and it went horribly wrong.  It gave me a very obnoxious
green-blue print in which the shadows are blocked up from 80%-100% in the
step wedge.
> Both RIPs sound somewhat problematic to install and use.  At less
> than half the price of IP5, the Epson RIP addresses half of Jerry's
> complaint, even if it's just as (or more) difficult to get up and
> running properly.  But I'd like to know if the Epson RIP can produce
> image quality on par with that described above using IP.
I've tried both and in my opinion, the Epson RIP is actually more difficult
to use and control than ImagePrint!
2003-02-25 by Robert Morrison
If in fact the Epson RIP is printing with only Light Black and Black ink the
print will look like the Sepia Piezotones, not at all like the Selenium
Piezotones as stated in one of the previous posts. The print will also be
much warmer than the warmest print possible using the tint picker in
Imageprint.  Imageprint get's its smoother dither by adding photo magenta
and photo cyan to the light black in the hilights...it avoids metamerism by
not using yellow.  As a result a Warm (100,100) print in the tint picker is
much cooler than pure light black and black.  I know because I'm running the
2200 with single channel control with an experimental driver and can fire
channels independently...so I know exactly what a print made with only light
black looks like.  If the Epson RIP is getting a dither as good or better
than Imageprint's with only light black and black then they are definitely
using a new dither not previously available...because running the standard
Epson dither with just light black results in very course hilights.
Robert
On 2/24/03 8:16 PM, "Thomas Fors" <tom@...> wrote:
> From: <dan_honemann@...>
> very warm.
> step wedge.
> Please visit the Group Homepage to check the Files, Bookmarks, Polls and other
> resources as they are often being updated. The page is at:
> page.
> them short.
> &amp;amp;quot;flames.&amp;amp;quot;
> resources on the homepage.
A while back I tricked ImagePrint into only using Black and Light Black inks
and remembered the result was very warm.  I just dug that print out and
compared it to the Epson RIP prints I just made.
While the Epson RIP print is warm, slightly sepia looking, it's not quite as
sepia as the Matte Black + Light Black only print. There may be some other
inks being mixed in there.  Tomorrow, I'll look at it under the microscope
at work and see what's going on.
--Tom
Sent: Monday, February 24, 2003 11:20 PM
Subject: Re: [Digital BW] Epson RIP vs ImagePrint 5
by
is
light
> Robert
2003-02-25 by sanfo2003 <SandyCornelius@cox.net>
>Black ink the print will look like the Sepia Piezotones, not at all
>like the Selenium Piezotones as stated in one of the previous posts.
Looking at a print made with the RIP thru a loupe reveals some photo
(dark) cyan being used. This is corroborated by ink level movement --
 black the most, light black to a lesser extent and then photo cyan
much less, but being used nontheless. If other colors are being used
I can't pick it out. I accidently laid down a print made with the RIP
next to an identical print made with Piezotone Selenium. When I came
back into the room it took a little while to determine which print
was which.
Then there must also be magenta involvement...and not just a little ink...it
takes a lot of magenta and cyan to get to the selenium tone shade. The
selenium tones have an eggplant undertone that would definitely require
magenta as well as cyan...in fact more magenta...but you may not be able to
see the dots in the shadows.  Other users seem to be describing the epson
RIP prints as quite warm, however...so I'm not sure what's going on here.
What I am absolutely sure of however, is that the light black and black inks
by themselves are well on their way sepia.  I have a light black and black
ink only 2200 print sitting next to a Selenium piezotone print as well...and
they are nothing alike.
Robert
On 2/24/03 10:24 PM, "sanfo2003 <SandyCornelius@...>"
> was which.
> page.
> them short.
Re: Epson RIP vs ImagePrint 5
2003-02-25 by chipcarterdc <chipcarterdc@hotmail.com>
Let mw wiegh in here.  I finally opened and installed the Epson RIP.
I also have IP5.  Using a Mac G4 and Epson 2200.  Here are my
preliminary impressions.
(1) Both are unnecessarily hard to use and not intuitive.  IP 5's a
little more intuitive to print with (once you have it set up
correctly) -- all you do is open the image, select the correct
ink/paper profile and hit print (oh, and remember to check the little
box that says "sheet" for the paper feed, otherwise it won't print).
With the Epson RIP, you have at least 3 or 4 different places in
different programs or parts of programs where you have to input
settings.
(2) I would NOT call the prints from the RIP neutral.  As others have
mentioned, they appear "warm-neutral."  Holding an Epson RIP print
next to an IP 5 print of the same image, the Epson RIP print clearly
is warm.  Not quite sepia, but definitely tending toward brown.  In
fact, it looks almost the same what I recall when printing with the
standard Epson driver and choosing black ink only (the prints with
the RIP are slightly less brown than black ink only, but not much.
I'll have to run a black ink only print tonight of the same image to
compare directly).  Now, the fact that prints with the Epson RIP are
not neutral gray is not necessarily a bad thing -- probably a matter
of preference and I haven't decided yet.  I'm going to look at the
prints again tonight.  I have to say at this point hat in terms of
neutrality, I prefer the IP 5 prints.  Perhaps my idea of
what "neutral" is supposed to look like is different from others',
however.  The Epson RIP prints do seem to be MUCH more free of
metamerism than using the standard Epson driver, and probably equal
to the IP 5 prints in this regard. (Again, though, if I want slightly
warm greyscale prints with little to no metamerism, however, I could
use the standard Epson driver and "black ink only.")
For me, the question will come down to whether I prefer the IP 5
prints so much over the Epson RIP prints in terms of neutrality
("neutral" warm/brown v. "neutral" cold/gray) that I'm willing to pay
$300 more for IP 5.  (lack of metamerism is a wash between the two
for me, but I admit that I don't have the best eye for subtle tonal
shifts in different lighting conditions -- e.g., my "black" socks
today are actually blue because I picked them out in poor lighting).
BTW, for the Epson RIP, I'm using the workflow posted and amended by
Sandy (I think).
2003-02-25 by Dan Honemann <dan_honemann@yahoo.com>
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "chipcarterdc
> have mentioned, they appear "warm-neutral."
> In fact, it looks almost the same what I recall when printing with
> the  standard Epson driver and choosing black ink only [...]
Have you (or anyone) tried replacing the light black cartridge with
another black (matte or photo) in either case (RIP or BO)?
This might just alleviate the brown/sepia cast.
Dan
> Dan
Nope.  My understanding is that it's the black ink, not the light
black, that has a color cast.  This would make sense because when you
print with "black ink only" mode, it only uses the single black ink
(matte or photo), not the light black.  And you get a brownish cast
using black only, so the color cast has to be in that single black
ink (matte or photo), not the light black.
Re: [Digital BW] Re: Epson RIP vs ImagePrint 5
2003-02-25 by Sue Tallon
on 2/25/03 8:44 AM, chipcarterdc <chipcarterdc@...> at
Chip, great comparison.
Are you using OSX for IP5?
Would you be willing to mail me a side by side test print from each? I'd be
happy to pay expenses or.... I believe someone suggested a print exchange
which I would be very up for.
Sue
Sue Tallon Photography
suetallon@...
each? I'd be
exchange
> Sue
> suetallon@b...
Yep, I'm using oS X for IP5, and OS 9 for the Epson 2200 RIP (because
it only runs on OS 9)
And yeah, I'd be interested if someone wants to organize a print
exchange.  I'd like to see others' results with the Epson RIP, to
make sure the warmish cast I'm seeing with that isn't just my poor
color vision and/or because I've got something set wrong.
Ah, okay, makes sense.
I was basing my suggestion on the following tip:
"Using dual Matte Black cartridges (replacing the Light Black ink as
well), can produce even better results on uncoated papers."
... taken from an inkjetart.com newsletter, found here:
http://www.inkjetart.com/news/archive/IJN_02-19-03.html
But of course this says nothing about solving the brown tone.  Still,
it might be interesting to give it a try for matte prints.
Dan
> I have a light black and black ink only 2200 print sitting next to
> a Selenium piezotone print as well...and they are nothing alike.
Robert,
A print made with "black only" using the Epson driver yields a print
with a tone that is what I will call "tan". You're right, very very
warm and nothing like Piezotone Selenium. But print the same image
with the RIP and it looks like Piezotone Selenium. I would be happy
to send you (no charge, of course) a couple prints from the same
image, one from the RIP and one from Pieziography using Selenium
Piezotones and you can check it out yourself. Some folks seem to be
skeptical of this RIP comparison to Pieziography/Selenium and I need
a credible witness. As far as what's going on to accomplish this,
well, I'm afraid I would be getting in over my head to make a
conjecture -- I'll leave that up to people who understand these
things better than I.
-Sandy
2003-02-26 by maracaholics <maracaholics@yahoo.com>
Sandy and Robert,
If you would like, I can forward to Robert what you (Sandy) already
sent to me. That might save you some hassle in printing these all
over again.
I can vouch for the similarity. The piezotone selenium is slightly
cooler, closer to neutral, and printed details in a patch of grass
better (not sure why; there's no loss of detail anywhere else in this
particular Epson RIP print), but I still like the Epson RIP print
better overall. With the naked eye, the Epson RIP print seems much
smoother to me in the monotone sky. The piezotone print looks a
little more coarse in that area. No doubt if you looked through an 8x
loupe, the tables would be turned on smoothness, but I'm more
concerned about the naked eye.
I have the Epson RIP myself now and am getting similarly great
results using Sandy's workflow. (See my previous post on this for
details.) Yes it is warm -- warmer than selenium piezotone, but not
quite as warm as Black Only. It is warm in a way that I find quite
attractive. Personally I would not trade this for piezotone.
Steven Gray
photopilgrim.com
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "sanfo2003
to
> Robert,
print
need
> -Sandy
2003-02-26 by Carl Schofield <scho@mac.com>
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "chipcarterdc <chipcarterdc@h...>" <chipcarterdc@h...> wrote:
Will the Epson 2200 RIP run in Classic mode?
2003-02-26 by chipcarterdc <chipcarterdc@hotmail.com>
I'm not sure; the box says Mac OS 8.6/9.x (and Windows).  Is Classic
mode something different?
