Re: [Digital BW] Epson 1200/piezography
2003-02-25 by Martin Wesley
Jeff, I started out with the original Piezo inks, software and a 1200. I encountered just about all the problems imaginable. Eventually I switched to a 1280 and MIS inks then on to PiezoTone inks. The real weak link in the system seems to have been the printer. For whatever reason the 1200 does not seem to do well with the carbon pigment inks. I would recommend going to a 1280 if you can and the PiezoTone inks staying with the Piezo-plugin. MIS-FS, MIS-FSN, or Sundance NC would be other ink choices. I have also had the Y inks get used up faster than the other inks and others have made similar reports. This seems to be normal and can be influenced by the tonal range of your prints. Martin Wesley http://www.borderless-photos.de/guests.html ----- Original Message ----- From: <jeff@...> To: <DigitalBlackandWhiteThePrint@yahoogroups.com> Sent: Monday, February 24, 2003 10:40 PM Subject: [Digital BW] Epson 1200/piezography > I am currently using the older Piezography inks and would like to > discuss/meet users of the 1200 that have switched to the newer > Piezotone inks. Using the older inks has anyone run into what > appears to be "ink starvation" even when the supply bottle still has > almost one oz. left. Also, did you experiece a greater useage of > the yellow position ink when compared to the others? > Jeff > > > Please visit the Group Homepage to check the Files, Bookmarks, Polls and other resources as they are often being updated. The page is at: > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > > If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page. > > Please follow these basic guidelines: > - Include your full name with your message. > - Include the address of your website, if you have one. > - As threads develop, trim off excess portions of earlier messages to keep them short. > - As the topic of a thread changes remember to change the subject header. > - Good manners are required at all time. No personal attacks or &amp;quot;flames.&amp;quot; > - Complete your Yahoo profile. > - Before posting a question, search the message archives and the various resources on the homepage.
> > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ > >
