Mounting Oil was Re: Epson3200 - Test results/Kami
2003-03-04 by Martin Wesley
Oil mounting has been around for a long time and many products are available from heavy gels to very light weight oils like Kami. A good source in the US is Prazio. http://www.prazio.com Their "Anti-Newton Oil" is similar to Kami. Don't forget that you can just go the local drugstore and get a bottle of mineral oil. Clean up is more of a chore but it works very well and is much cheaper. For large negs consider using a cover sheet so that you have a sandwich of glass/oil/neg/oil/cover film. The cover film is taped to the glass and you can then use film wipes on the cover film to work air bubbles out to the edge of the negative. Martin Wesley http://www.borderless-photos.de/guests.html ----- Original Message -----
From: <jvlist@...> To: <DigitalBlackandWhiteThePrint@yahoogroups.com> Sent: Tuesday, March 04, 2003 9:41 AM Subject: [Digital BW] Re: Epson3200 - Test results/Kami > > http://www.kami-produkte.de/english/sxl.html > > In the USA the Kami distributor is Aztek: > > http://www.aztek.com/Products/Aztek%20Supplies%20&%20Accessories.htm > >
