Re: [Digital BW] Converting Photoshop Curves into ICC profiles - Can This be Done?
2003-03-08 by Editor P.O.V. Image Service
davidspielman2003 wrote:
>Originally posted this question on the Color Theory group - got no
>answers! Will try here.
>Hello Group,
>Can anyone tell me if there is any way (3ed party PC software) that
>one can use to convert the curve functions in Photoshop (Transfer
>Function - *.ATF, Curves -*.ACV, Map Settings - *.AMP) into an ICC
>profile (.ICM, or *.ICC) ?
Theoretically you can use ColorVision's Doctor Pro to accomplish this...
You'd apply the the curve to the correct profile and generate a new
profile..
The caveat is that your images will look strange in softproof mode..
However, the new profile, should, in theory, properly convert images for
the printer..
The only real advantage in thisapproach would be that you could do all
your adjustments in the plain ol generic Pshop working profile and  then
outpput to the new profile..
Hmmm.. I'll try and find time to try this out over the weekend with a
small print and my existing VM-S curves...
Keith
"Just some guy," and caretaker of the Multiverse's largest EPSON printer
User Community (highly recommended by Vogon Poets and MegaDodo
Publications), at:
http://groups.yahoo.com/group/EPSONx7x_Printers/
"For the rest of you out there, the secret is to bang the rocks together
guys"
2003-03-08 by Ernst Dinkla
Sent: Saturday, March 08, 2003 10:05 AM
Subject: Re: [Digital BW] Converting Photoshop Curves into ICC
got no
> >Hello Group,
that
(Transfer
ICC
accomplish this...
new
> profile..
mode..
images for
> the printer..
do all
and  then
with a
> Keith
The other advantage would be the use of "curves" in
drivers/programs that are ICM compatible but don't have curve
adjustments.
It is nice to have profiles based on curves but it would be even
better to include tone corrections of the actual output in the
profile and get rid of any colour info.
Ernst
2003-03-12 by Ernst Dinkla
accomplish this...
new
> profile..
mode..
images for
> the printer..
do all
and  then
with a
Did you try it and did it work ?
Ernst
2003-03-13 by Tyler Boley
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Ernst Dinkla" <
Ernst, this is all old Dan Culbertson stuff. You can create profiles
for quad inks. You can edit curves into those or any other printer
profile with Doctor Pro, other software as well I'm sure.
However, sep curves created to work on files in a working space (as
most used here are) will not work. The idea is to be able to convert to
the profile for printing, converting to a quad (or any other) printer
profile will significantly alter the RGB values in the file, therefore
those curves will not result in the desired final RGB values for
printing as they did when applied to the working space they were
created in. They were created to work on AdobeRGB (or whatever).
So you'd want to edit those curves into a profile that does not
originally alter the RGB values, like a working space. Doctor Pro will
not edit working spaces. Alternatively, you can create a null printer
profile, and edit your curves into it. Unfortunately since it was not
created from the inkset/paper, it will not have the advantage of
preview. It's only usefulness will be to print through, no more
advantage than running a curve anyway. A null printer profile is not
that easy to come by either.
Another option is to start from scratch. Create the profile from the
inkset, attempt to create sep curves that print well on a file already
converted to that profile, then edit those in. Unfortunately the new
RGB content after conversion is not very useful for creating optimal
quad sep curves.
However, you can do all this on CMYK profiles using old Culbertson
tricks.
Creating really good RGB quad printer profiles, that also preview well,
will be much more complex than it may first appear, and editing in sep
curves made by trial and error does not take good advantage of all the
data provided by the initial profile anyway.
Tyler
2003-03-13 by Ernst Dinkla
profiles
printer
(as
convert to
printer
therefore
for
were
whatever).
Pro will
printer
was not
of
is not
from the
already
the new
optimal
> quad sep curves.
Culbertson
> tricks.
preview well,
in sep
all the
Yesterday I experienced some of the obstacles you describe here.
I still think there are possibilities to overcome them. I am not
after a good screen representation but a good quad printing
profile to be used in other (driver) applications than Photoshop.
In the past I have asked how a null printer profile is created
but never got an answer. The way I think it is possible to create
a good hexatone profile is for example by using Doctor Pro to
convert initial separation curves into a profile based on a null
profile. Use that as the printer profile to print a grey
stepwedge and measuring that wedge to create a general curve
again that will be implanted in the first profile with Doctor Pro
again. That could take care of the RGB shift you describe but
with the advantage that this second step can also be used to
compensate any printer quality drift in time as well. Like
linearisation but in this case at the end of the process.
So the two questions are: how do you create a null printer
profile and is it possible to write a tool that translates
spectrometer or densitometer greyscale data into a PS curve ? If
it doesn't already exists.
Any flaws in this concept ?
I have checked some IP profiles and more than in any other
profiles I came across curves in the profiles that are used to
correct the output. That's an RGB driver as well so it must be
possible to use the curves in the profiles for this purpose.
Related to this:
There's profile creation software that can change a normal colour
profile into a so called "Rich Grey". It is used to get more
neutral prints from colour printers by taking out the colour data
of the colour profile (if I did understand it correctly). I got
some samples of profiles and menu screenpics probably from
Richard Millott on the Colorsync list. www.ICCtools.com is the
company, the software is ICCtoolbox pro. The profiles have an
extension pf but they are cmyk printer profiles, I can't place
them however. Anyone familiar with that application and the
profiles ?
Ernst
I suspect my knowledge falls just short of the easy solution. Editing
the header in a working space profile from mntr to prtr doesn't seem
to work.
Look at it this way, if the profiling software sees exactly the same
measurement numbers as the color data in the target file, it should
create a null profile. I have yet to take this very far, but you get
the point.
Another possibility is that the canned Epson profiles seem to have
some sort of shell profile called "standard", then setting specific
sub profiles. The 3000 or example installs SC3000 Standard, then
several related to media and resolution such as SC3000 PQP_1440. This
"Standard" seems to be equivalent to ColormatchRGB, but is a printer
profile. I haven't tested this thouroughly but it seems to be true. If
you can deal with your null profile having a gamma of 1.8, or can then
edit it to an more useful overall gamma, you can use it as a base null
to edit curves into. It works.
>...is it possible to write a tool that translates
It certainly seems possible, RIPs that have linearization features
built in, that support measurement devices directly, seem to do
something very similar, just perhaps not  a PS curve specifically.
Will they export a .acv curve?
Only if it doesn't work <G>
> profiles ?
I've downloded it and tried it briefly in demo mode. I tried making a
gray profile from a CMYK profile of a quad setup. It did work, and
will load and preview, very cool. Just haven't found a way to put it
to good use yet.
Way too many irons in the fire.
Tyler
2003-03-14 by Ernst Dinkla
Dinkla"
same
should
you get
> the point.
That was my approach too some time ago but I couldn't figure it
out.
have
specific
then
PQP_1440. This
printer
true. If
can then
base null
This is interesting, there may be other ways to convert space
profiles to "null" printer profiles. Better ask that question of
null profiles again but this time in the colorsync list.
If
features
specifically.
The Wasatch SoftRip has the Spectrocam driver integrated in that
linearisation so it is hard to get the info on the data
conversion. I have asked Wasatch to take a look at the different
workflows of quad printing (through the MIS site) and work out a
universal scheme that allows the integration of B&W printing in
the Rip. The Rip has curves for adjustment and linearisation per
Cc Mm Y K channel.
I have suggested that an overall linearisation after those steps
would be nice to even out any flaws in the curves and at the
cross over of the channels. I have no idea whether they actually
bother about a request from one Dutchman. It seems that
Ergosoft's Posterprint now has Quad support so I am not without
hope.
I will ask a befriended programmer to take a look at the ACV file
and how a Spectrocam reading can be used to make one.
Might even be easier to go to a grey profile directly if any
curve to profile conversion is creating RGB flaws in the process.
colour
data
got
place
> > profiles ?
making a
and
put it
> to good use yet.
Nice to know that it can work. No Macs here.
Ernst
Re: Converting Photoshop Curves into ICC profiles - Can This be Don
2003-03-14 by sjhenry
> Ernst
ACV file format for gray scale curve is as follows
Bytes    Description
0-1      Magic Number??? always 1
2-3      # of curves (for gray it is alwasy 1) 1
4-5      # of points in the curve
6-7      Old value for first point on the curve
8-9      New value for first point on the curve
10-11    Old value for second point on the curve
12-13    New value for second point on the curve
and so on for each point on the curve.
"Old Value" means the original RGB value for that gray ranging from 0
to 255. "New Value" means the RGB value obtained after printing the
target ranging from 0 to 255. Also I assume in gray scale r = g = b.
RGB curve essentially the same but with 3 individual curve for r,g
and b. These are from my observation. So verify it in a hex editor
what I told is correct or not.
Jones.
2003-03-14 by Roy Harrington
file
process.
> > Ernst
> Bytes    Description
from 0
printing the
= b.
r,g
editor
> Jones.
I think the old and new values are reversed.  In Photoshop
lingo it looks to me to be Output then Input.
Also with RGB and CMYK I see 5 curves and 6 curves
respectively.  The first one is the composite RGB or CMYK,
followed by the individual RGB or CMYK, and then at the
end there always seems to be an extra curve that is just
(0,0) to (255,255).  I have no idea what this last thing is but
all the acv's I've seen have it.  Maybe there's some hidden
feature to PS.
Roy
