Re: [Digital BW] Eboni Black
2003-03-12 by Jerry Olson
Chris, MIS told me on the phone that you can intermix the eboni ink and
the VM inkset with no problems.
That is why I just ordered a bottle of eboni, to use with my VM inkset.
That is the exact opposite of what they
told you. VERY strange! They said all the ultratone inks are compatible
with their
older inksets, but that they are still experimental, and no refunds or
returns can be given if you order their
4.3 inks now. They said further testing must be done before they put
their regular guarantee on the new inkset.
Has anybody actually done this?
If the Eboni ink can be used with the older VM inkset I would think it
HAS to be compatible with that ink!
Jerry
Chris Hargens wrote:
> I just ordered a bottle of Eboni black from MIS to replace my current
> VM black. Their representative confirmed over the phone that it would
> be necessary to change the black cart in my CFS, that the ink cannot
> just be poured in in the bottle. The black cart with attached tube is
> not listed on their Website (only the cart set), but it can be
> purchased separately. The one for the 1160 costs $15 (CFC-108).
> Also, I'd be interested in hearing results the beta users are having
> with the "Ultra-Tone" bw inkset -
> http://www.inksupply.com/index.cfm?source=html/ultratone.html In
> particular, how well does the PK black with inkset print on various
> glossy papers. If something like a fiber-based/looking archival
> inkjet paper (Oriental?) comes out soon and this inkset prints
> without bronzing on it, that would satisfy my most of my desires.
> Chris Hargens
> Please visit the Group Homepage to check the Files, Bookmarks, Polls and other resources as they are often being updated. The page is at:
> - Good manners are required at all time. No personal attacks or "flames."
> - Before posting a question, search the message archives and the various resources on the homepage.
2003-03-12 by Stan McQueen
>with their
>Jerry
The website article doesn't say the inks are not compatible. It says
>On Epson desktop printers, using cartridges, there is no need to flush out
>old inks before using the Ultra-Tones. After a couple of cleaning cycles
>the old ink will be gone. Of course if you had been using Lyson" or
>Luminous" inks, then the use of a cleaning or flushing cartridge is
>definatley recommended.
>On Epson printers using Continuous Flow, a new virgin empty Continuous
>Flow cartridge will be required. This is because there is no way to get
>the residual ink in the sponges out of the cartridge. It will mix with the
>new inks, and can take as many as 5 cartridge loads worth of ink to reach
>the 95% point. This means every print you make will be different for a
>long time. It is not worth the battle not to start with a virgin CFS cart.
>On Epson wide format printers (3000, 5000, 7000, 7500, 9000, 9500) the use
>of flushing or cleaning cartridges is recommended. There is just too much
>residual ink in the tubes and dampers to make a clean switch to the new
>inks with out using cleaning carts.
So it's a mixing problem that will cause the printing to be unpredictable,
not a compatibility (chemical, or pH) problem.
Stan
Photography by Stan McQueen
http://www.smcqueen.com
2003-03-12 by Chris Hargens
According to the MIS website,
"On Epson printers using Continuous Flow, a new virgin empty
Continuous Flow cartridge will be required. This is because there is
no way to get the residual ink in the sponges out of the cartridge.
It will mix with the new inks, and can take as many as 5 cartridge
loads worth of ink to reach the 95% point. This means every print you
make will be different for a long time. It is not worth the battle
not to start with a virgin CFS cart."
I'm not sure what this means, however. True, if you're planning on
loading the whole inkset, along with the PK black, to print on glossy
paper, then you wouldn't want to mix the earlier VM inkset with the
UltraTones. However, if you're only going to be replacing the VM
black with the Eboni (matte) black, then it seems to me that mixing
would not be an issue, at least as far as the initial look of the
print. But expectations/claims for archivality are different for the
two blacks and mixing them would mean that for a while ("5 cartridge
loads worth of ink"?) you would be in a kind of limbo regarding
expectations or claims you make for your prints.
Chris
  --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Jerry Olson
and
inkset.
compatible
> with their
or
put
it
> Jerry
current
would
cannot
tube is
having
various
> > Chris Hargens
is at:
header.
&amp;amp;quot;flames.&amp;amp;quot;
2003-03-13 by Jerry Olson
Ah, well In my case, I'm starting with a New CIS, and will never be
using glossy paper.
Jerry
> Chris
