Hello Jason,
I'm about in the same boat as you. I just got a used Epson 1280 off
ebay Monday and the inks came in Wednesday, so I have been trying to
get a decent BW print out of it. I had another printer before the
Epson that tried to do Black only printing. Now I can do really good
black only printing on the epson. You might want to try it too. It
is so much more satisfying than trying to get these curves right for
the hextone printing. With the black only, all it takes is an
initial curve applied to one stepwedge to bring all of the numbers
to match the screen. That single curve can be applied to each print
initially and then just punch "Print" and you are home free. All the
work goes into creating the image you want and getting just what you
see on the screen on the print. In the case of the 95% to 100%
steps, I just raise the numbers on the stepwedge from 9 to 14, 24 to
31, and any other step to match the numbers at the bottom of the
stepwedge bar image. If you need further information on black only
printing, here is a great website to go to
www.cjcom.net/digiprnarts.htm.
your friend in photography,
Johnny Eades
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "jfobart"
<jfobart@u...> wrote:
> I've finally gotten my new VM setup running, and I printed the
step
> wedges found in the files section, but I see no seperation in the
95-
> 100% area.
> What's the remedy? What's the source of my problem?
> Are my printer profiles too dark? Should I therefor create a
custom
> curve to bring up those values and apply it before each print?
> Thanks for the guidance!
> Regards,
> Jason
