Bowhaus and QuadTone RIP questions
2003-03-28 by mr_misty_44
Antonis and Roy,
 Perhaps this should go to Roy but I thought both of you might
comment..
I've been using PiezoBW and Roark curves on my 3000 to make
prints.
I've been unhappy with the PiezoBW software for the simple reason
that it is so Profile dependant and if you don't have the
ink/paper
combination profile it does not work very well. I have an 1160 and am
in the process of purchasing a 7500. The 3000 is good when it works
but…
 At any rate I'd like your takes on Roy's system, which he so
kindly
made available, and the Bowhaus system. At this point what are the
Pros and cons of each. I still have 9.2 loaded on my G3 as well as
OSX10.2.4. So I will be able to work with either system.  I've
been
alternately happy and unhappy with my results. I really would like a
system, which would allow me to be a bit more in control of the
results. I suppose a side comment might be made about Jon Cone's
new
system as well. If anyone else would like to chime in I'd
appreciate
it.
					John H
Re: Bowhaus and QuadTone RIP questions
2003-03-28 by Roy Harrington
--- In DigitalBlackandWhiteThePrint@yahoogroups.com,
"mr_misty_44" <jharvey@i...> wrote:
> Antonis and Roy,
> comment..
make
> prints.
reason
> ink/paper
and am
works
> but…
> kindly
are the
as
> been
like a
Cone's
> new
> appreciate
> it.
> 					John H
John,
As I see it, Bowhaus and QuadTone RIP have quite a few
similarities but we've started at different ends of the problem.
My stuff started with OS X a given and a grayscale workflow
built into the normal printing system.  I have full control over
4 inks but not 6 inks because the regular gimp-print code
only provides that currently.   I've done a few aids to making
curves using a couple of spreadsheets but it's not a
productized, automated process.
Bowhaus on the other hand seems to have put a lot of
effort into curve design software -- this is what they are selling.
Their printing workflow is based on a separate program that
prints TIFF files and initially runs on Mac OS 8 and 9 and
I guess under Classic.  Seeing how they are a money making
company, no doubt they will make it run on the other platforms.
So what should you do?  I'd say download both and try them
out.  It doesn't look like there are any Bowhaus curves for
the printers you have but at least you can see what its like.
I would think someone would have an 1160 curve soon.
As it turns out I have an 1160 and recently a 7500 both with
VM-Sepia inks so my 1160 curves are fine and I'll be working
on the 7500 for QuadToneRIP.  I expect the 3000 curves
wouldn't be too difficult.
Roy
2003-03-28 by Antonis Ricos
John,
the IJC/OPM combo supports the 1160 and 7500 but not the 3000. Please go
back to my messages of the last two days to see if that solution works for you.
The big difference from any other bw printing solution is the ability to make
your own profiles and update them as needed.
Be aware that at present there is a 36" limit to the length of the prints it allows
(and won't run the 7500 in roll mode either).
If you haven't already, check out their site:
http://www.bowhaus.com/inkjetcontrol/
I can't quite give you the comparison you are asking about since my only
reference is the old piezo plug-in and ImagePrint both of which rely on
company-supplied profiles (as does the current solution that Jon Cone offers).
 To me that era is behind us and the thought of using canned profiles for bw is
only a necessary compromise if there is nothing else around (such as for an
old unsupported printer or prints longer than 36").
Your mileage may vary, of course!
Antonis
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "mr_misty_44"
> kindly
> been
> new
> appreciate
> it.
> 					John H
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Roy Harrington"
> > Antonis and Roy,
> > comment..
> make
> > prints.
> reason
> > ink/paper
> and am
> works
> > but…
> > kindly
> are the
> as
> > been
> like a
> Cone's
> > new
> > appreciate
> > it.
> > 					John H
> John,
> Roy
Roy,
    So, as I read it OpenPrintMaker which comes with
IJC supports 6 ink printers where as Gimp Print does Not. Or is it
that the part you've added does not, as yet, support 6-ink printers?
I'm confused a bit over this since Gimp Print lists a great number of
6 ink printers as supported printers.
Just as a bit of further confusion, could you use Gimp print with the
IJC software or not. What is the advantage of the OpenPrintMaker over
Gimp Print when used with IJC.Would there be any advantage in using
the IJC software with Gimp Print.
                            John H
John,
IJC and OPM support up to 7-ink printers. The IJC profiles are only good on
OPM. For a list of supported printers and the free OPM see the bowhaus  site.
Antonis
2003-03-28 by Charles Bandes
QuadToneRip and Gimp-print do support 6-ink printers, and do a fine job with them. The problem Roy mentioned is that the _current_ version of Gimp-print does not support _direct_ control of the photo-cyan and photo-magenta inks. Those inks are used, but are controlled by the driver to print different densities of cyan or magenta.
To the end user (me) this subtlety doesn't really seem to matter, though I suspect that when Roy gets his hands on a newer Gimprint that allows direct control of those inks that his quality will improve beyond the already very good quality he is getting :)
> Roy,
>                             John H
Harrington"
> > > Antonis and Roy,
might
> > > comment..
> > make
> > > prints.
> > reason
> > > ink/paper
1160
> > and am
when it
> > works
> > > but…
> > > kindly
what
> > are the
well
> > as
> > > been
would
> > like a
Jon
> > Cone's
> > > new
> > > appreciate
> > > it.
> > > 					John H
> > John,
selling.
making
platforms.
> > Roy
> Roy,
is it
printers?
number of
OpenPrintMaker over
in using
>                             John H
John,
As Charles said, gimp-print handles 6 and 7 ink printers
just fine INTERNALLY.  What it doesn't allow is separate ink
controls EXTERNALLY i.e. from where QuadToneRIP stands.
There is an effort by the gimp-print people to allow this
control sometime in the future.   The gimp-print source code
is all available under the GNU license so I imagine that
Bowhaus just started with the basic package and added the
external control of 6 and 7 inks.
If you want to use IJC curve software you'll have to use a
program that understands their curve files -- so you must
use their OPM.  The fact that OPM contains some gimp-print
code is invisible and impossible to separate.
Roy
