Eboni Problem
2003-04-02 by Chris Hargens
I'm running VM with a CFS on an 1160. I recently installed the new MIS Eboni ink with a new cartridge. No problems at all for the first 8 or so prints. Today, some 4 or 5 days after last printing, I tried to print. Started with a nozzle check -- perfect. When I started to printed, however, I noticed about halfway through that terrible banding was beginning to take place, as well as some small blotches and pools of ink on the print. I stopped the printing and ran a nozzle check. It looked pretty bad. I then ran a cleaning cycle -- no help. I ran two more, still the same. Looking at the nozzle check, I see that it is not always the same lines that are missing. It almost seems random. What I'd be interested in learning is whether ink pooling/blotching can occur with a foam problem or air-in-the- cartridge problems, or is it a sign of something else. BTW I ran several purges -- no help. Also, I would get a good nozzle check and then that would be followed by bad one, almost seeming random. Perhaps I should follow Robert Morrison's advice to someone else and just not use the printer for a few days? Any help would be appreciated. Chris Hargens
