Can't use "ROLL PAPER" settings
2003-04-30 by Daniel Smith
After taking apart my 9500 for cleaning and to resolve an ink
problem, I now have a new problem.
If I load any kind of roll paper, after hitting pause, the printer's
paper setting switches itself from roll to "sheet". Does not matter
what i have selected in driver, or what type of paper. After printing,
the printer will spool out yards of paper, looking for the end of the
sheet.
I was printing on rolls of canvas no problem, rolls of EEM no
problem, cutter on or off. Now it always switches to "sheet".
Maybe I knocked the paper thickness sensor out of whack? Or
one of the sensors is dead or dirty? Or do you think the main
board is going bad?
Any ideas? Any one ever adjust or replace a paper sensor?
thanks,
dan smith
Re: Can't use "ROLL PAPER" settings
2003-04-30 by Antonis Ricos
Dan,
sounds like you need the service manual.
http://www.visual-artists.com/manuals.htm
And I think you got the right idea. It's probably a sensor that got gunk on it or
knocked off . The manual details how to check for that.
Let's pray it's not the board that's fried!....
Also, you may get expert advice from the folks at  epsonWideFormat:
http://groups.yahoo.com/group/EpsonWideFormat
Good luck.
Antonis
> board is going bad?
> thanks,
> dan smith
thanks antonis.
I do have a copy of the service manual.
it shows how to check the P_THICK sensor to see if it is reading
thickness properly (p. 215), but it does not explain how to adjust
it, unless i am not understanding the manual correctly.
Wondering if anyone has ever attempted to adjust or replace this
sensor.
dan
gunk on it or  knocked off . The manual details how to check for
that.
