Re: [Digital BW] Re: OPM vs Epson driver
2003-06-05 by Martin Wesley
Sent: Thursday, June 05, 2003 2:42 PM
Subject: [Digital BW] Re: OPM vs Epson driver
> John,
> it's not so much about "how  good" OPM is at resampling: it just doesn't
at all!
> It  sends to the printer whatever gray tiff you open as is.
> So, you are correct, the closer to 720 the file is, the better. You may
not see a
> big difference past, say 400-500 dpi, but will certainly see pixelation if
you
> send a 360 dpi image. The same image printed through the Epson driver will
> print smoothly. In that sense, there is an extra step that one needs to
take if
> their files are below 400 dpi (at 100% final print size).
> As for the 16 vs 8 bit....  it definitely likes the 16bits better (it was
originally built
> that way) , but an 8bit 720 dpi file will be just fine.
> Just to clarify: this is not about scanning resolutions and extracting
info from
> the original etc - it's just about matching device dots to pixels.
Antonis,
Would this be a case where converting back to 16-bit just prior to printing
would be in order?
I know you beta tested the IJC/OPM software and are a long time user of the
Piezo/R9 plug-in. Can you give us your comparison of print quality and
workflow quality of the two?
Martin
2003-06-05 by Robert Morrison
> would be in order?
Martin,
That's what I do.  I scan in 16 bit.  I then adjust the image to 720 and do
my tonal corrections in 16 bit.  I then frequently convert to 8 bit for
dodging/burning, sharpening or to use another filter and then convert back
to 16 bit before I print.  I think you could also save the 720 to the end of
the workflow...if you wanted to minimize the crunch on your processor.
Robert
Re: OPM in theory (to Martin's q.)
2003-06-06 by Antonis Ricos
> would be in order?
Martin,
yes, exactly - or to 720dpi  for that matter.
well.... yes, I suppose I should. I would need to print the same file both ways
and upload detailed scans of the prints. I can do that with the 1280/PT
seleniums. ..   OK, "coming soon"....
Meanwhile, by way of a (lengthy) prologue:
The main difference between IJC/OPM and systems that use canned profiles
is not just the accurate match of the profile to the user's system but the fact that
you gain "analogue" control of the tonal distribution of your print.  This applies
to any Raster Image Processor that gives you single channel control of the
printer, not just OPM.
When you tweak RGB curves, or  tweak a grayscale file based on a monitor
preview (or printed output) you are altering the digital data in the picture.
That's normally where people are careful with scans and histograms, do some
moves in 16bit etc. trying protect the tonal integrity of that data.  I call that
"digital" corrections or adjustments that take place  in the digital domain.
When you tweak how much ink - and in what combination of colors or grays -
is layed down for each digital value in the image, you are performing an
"analogue" correction. Sure, it's handled digitally, but it is not dependent on
the digital data in the image file. It only becomes related to it  when the
software "looks up" the digital value in the image and matches it up with your
choice of amount of ink(s). In this scenario, you can lighten/darken etc without
affecting the precious bits and bytes in the original file. I call it  "analogue",
(like audio D/A converters) because it occurs at the point where pixels are
converted into the appearance of a continuous tone print.
This "analogue" option is not available when the controls are locked away in a
black box like the Epson driver or the R9 plug in or ImagePrint etc. Now, there
may be good reasons for locking them away - there is serious complexity in
reproducing CcMmYK color prints from RGB files and companies like
Colorbyte have brought a lot of science to help us out.
In the case of bw, it takes  a fairly knowledgable user to make a profile and
understand how you partiton the grayscale into the 2-7 inks you may be using
to print. So, this may not be for everyone, and there may be plenty of happy
users of canned profiles (as Tyler points out) - fair enough.  Of course, as
profiles become available for OPM, not only are they canned and easy-to-use,
the whole thing is free, which is another matter to consider!
By the same token, we need to be aware of what we are doing to our digital
data when (and if) we have to twist it because of  inaccuracies in our printing
systems. When you make a bw print with a "locked" system, then adjust your
image to improve that print, some of the adjustments are part of  the artistic
interperetation, of course, but a fair amount may be aimed at  counteracting
the effects of an out-of-whack system. You will never be able to separate the
two without  access to the print controls of the driver independently of the
image file.
So, these are the theoretical reasons for seeking out systems that allow
"analogue"  tweaks. Now, it doesn't mean that everything else is garbage, nor
that the ability to have these controls automatically makes a software superior.
I am happy to see the introduction into the arena of monochrome printing  of
the Ergosoft product (at inkjetmall), because it appears to address the issues I
am talking about. I have not had any experience with it (because I am
Windoze-challenged) but have pretty high hopes for its performance based on
reviews and on line discussions.  It may be several times the cost of IJC, but I
believe it also supports more large format printers without the limitations of
IJC. We've seen leapfrogging before - let's see what's in store next....
Antonis
2003-06-06 by Tyler Boley
I feel like the godfather character- I keep trying to get out and they
keep dragging me back in! I really don't mean to be argumentative, and
I think OPM/IJC has many great attributes. However I have to take
issue with a lot of this, but you know, with a lot of love.
As Antonis says, editing a master file for the anomalies of a given
output system is unwise at a glance. Certainly saving a master file
with those edits is not a good idea. But in fact, correcting for
output at any given time is SOP in this day and age. We convert our
master color file to the output profile either manually or on the fly
all the time, that's the idea. We certainly don't save the converted
file, that is destructive and it's usefulness for the future is very
limited. We may even have a little editing to do to optimize our print
through that profile and printer. Again, saving the master with those
particular edits would be unwise.
For mono printing systems, we may have a master 16 bit gamma 2.2 (for
example) file. Our output system, whether Piezo, RGB driver after
curves, ImagePrint, IJC, whatever, is never perfectly linear or
possibly not appropriate for that given print. So we may have a final
curve we want to apply to print they way we want today on whatever
output system we have today. Why would anyone save their file in that
state? It's device specific. Also, if our work habits are refined, a
final curve to a high bit file is not very destructive at all. It's
not an issue.
I'll be willing to bet that, with OPM/IJC and the new Ergosoft option,
after initial sep curves are developed or canned ones selected, final
densitometer linearization is an overall correction applied at INPUT
to the file on the fly. That's exactly the same thing as applying a
final correction curve, exactly. Any other method of linearization
would be ridiculously complex and have to alter each and every ink
channel.
So, that a file needs some kind of optimization for printing is not a
plus or minus of any particular product or output system, but more of
a convenience feature of whether or not it happens on the fly or you
do it yourself in Photoshop.
Black box printing systems-
Piezo plugin and Pro
ImagePrint
Epson driver with RGB cures user can't edit (for experience reasons)
Maybe some others, I'm not paying much attention at this point
With these, if you have no flat spots, reversals, harsh transitions or
other major problems, with well made master files a final tweak is not
a problem. I'd say, for those not interested in delving the depths of
individual channel control with the new systems, it's no different
than what an overall linearization is going to do on the fly with
these new systems. If the correction can be handled by the particular
percentage points Photoshop offers in a custom grayscale space, you
can even save it out and apply it when printing on the fly, assuming
your output system accepts grayscale in.
Obviously, new systems have extraordinary features for those who
choose to work with them and I'm certainly stoked about the
possibilities. But an output system is not dictating an unwise or
destructive workflow, it may however make for a much more convenient
one. Let me know if I'm missing something, please.
This is worth restating-
> Of course, as
easy-to-use,
Tyler
Re: [Digital BW] Re: OPM in theory (to Martin's q.)
2003-06-06 by Robert Morrison
Tyler,
I think the point here is that you can have one master file that you print
from...no edits for output...and then print that file with many different
options (toners, printers, inksets, papers, etc.) and not have to edit the
file to move between the options.  Given the lack of consistency that I see
in printers, inksets and papers this strikes me as a really important
function of an output system.  If I make a print today...I want to have the
ability to make an identical print in two years when I've switched printers
and have new inks...and maybe even a different paper.  If my system is
properly calibrated I can do that.  If I don't have control over this...I'm
at someone else's mercy.  Admittedly, the RGB partitioned workflow gave some
ability to do this...the controls were just much more limited...and didn't
integrate well to a measured approach based on densitometry.
Robert
> not an issue.
> channel.
> ImagePrint
>> Of course, as
> easy-to-use,
> Tyler
> Please visit the Group Homepage to check the Files, Bookmarks, Polls and other
> resources as they are often being updated. The page is at:
> page.
> them short.
> - Good manners are required at all time. No personal attacks or flames
> resources on the homepage.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Robert Morrison
<rmorrison@p...> wrote:
> Tyler,
print
> from...
well yeah, and all I'm saying is that we've always been able to do
that if somewhat clunkier than you can now.
It's just easier to automate that process, do it more precisely, and
have it done for you on the fly by the driver now.
These are good things.
Tyler
