7500 Problems
2003-06-10 by Mr_Misty_44
I have posted this question on the Wide format forum but I thought I'd try here as well. If anyone can help, I'd appreciate it. I have just set up a 7500 with MIS UltraTone Inks. I am trying to run a head alignment check with cut sheets which are 17X22. The paper I'm using is 250GSM, 15mil,.015 Thick Goshawk paper. The instructions indicate roll paper for this operation. How do I go about it with cut sheets since this is what I'll be using for the most part. I have done a head alignment on a roll of epson paper I had.The #1 row is sharp but with all the others the numbers are faint to missing at the tops of the numbers and there seems to be little difference in the selections from 1 to 15 in each row except Row#4. The nozzle check seems correct. I am using the 7500 Epson Driver. should I be using the 7000 Epson Driver? Please help. any other tips in setting this printer up for UltraTones would be GREATLY appreciated. If you want to contact me off list instead of taking up space...If not, post away. John Harvey
