Alternative 8 >16 bit conversion, Grey > CMYK conversion,
2003-06-16 by Ernst Dinkla
To help me with the adaption of the Wasatch SoftRip for quad printing a friend wrote a small PC application to convert 8 bit and 16 bit greyscale files to plain 8 bit or 16 bit cmyk files. No separation is done just 4 copies of the greyscale gathered and given the C,M,Y,K, mark. Similar to what can be done with a PhotoShop action. He also added a choice of compression, LZW, ZIP, RLE or none. The ZIP compression is not accepted by the RIP but PhotoShop does, with that kind of CMYK files the size is then a bit smaller than the original greyscale file. I wonder whether it has any sense to make the application available on my site, with the LZW compression added it isn't wise to put in the file section of this list. Following a small thread here (OPM in theory) on the conversion of 8 bit greyscale to 16 bit I asked him whether it could be added to the same application with the bit shifts as discussed here. He made some comments I like to add (my translation): Quote: From the discussion I gather there are three variants: i8 : 8 bits grey values (0-255) i16: 16 bits grey values (0-65535) A) i16 = 256*i8 B) i16 = 257*i8 C) i16 = 256*i8 + random(0,256) I consider B to be the only correct one. With that the complete 8 bit intensity range is scaled to the complete 16 bits range. Software writers tend to do A that gives a small offset and a bit lower contrast. Some people in the discussion had high hopes for C. I don't get how you can get a better result by introducing a random falt of half the step value on purpose. Best guess is that it tries to generate a random dithering. I seems to me that the dithering process should be done on results obtained with exact computations. If there's a desire to experiment I can add a 8-16 bit conversion option with a choice between B and C. Any thoughts on the random function in C are welcome. It can be a uniform distribution where all the numbers get an equal chance. A normal distribution may be better, the numbers further from the middle get a lower chance. Gert-Jan End of quote, translation by Ernst Ernst
