Re: [Digital BW] Re: QuadToneRIP 2.0 - Mac only?
2003-06-25 by Jack M Kucy
Is it any way it would be available for the Pc?
It would help a lot of photographers.
Jack
_________________________________________________
Jack M Kucy
JMK Gallery (www.jmk-gallery.com)
917-991-2096     jmk@...
Member of ASMP (www.asmp.org)
...a riveder le stelle
Roy Harrington wrote:
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Kees Brandenburg"
> <ctb@z...> wrote:
> > Hello Roy,
> > Today I upgraded to QuadToneRIP 2.0 but ran into a problem when
> > installing curves.
> > After running Run-Quad-Profile the example curve (1160-fs) is
> > installed and visible in the curve dropbox (inside the folder
> > Quad_1160). But after running Run-Install-Curves and entering the
> > password I get this message:
> > quadcurves: quadcurves: No such file or directory
> > logout
> > [Process completed]
> > When doing a search for quadcurves I find a file (put there by the
> > installer) in usr/local/bin
> > The curve doesn't show up in the print dialog.
> > What should I do?
> > Thanks,
> > Kees Brandenburg
> Thanks, Kees.  Apparently /usr/local/bin isn't in the default search path.
> Here's the simple fix,  the file Run-Install-Curves can be edited with
> TextEdit.
> Adding the line that begins with PATH will make it find quadcurves.  Note
> that you can't write the change to the read-only disk image or the
> download.
> Write it to your own copy.
> ------NEW VERSION of Run-Install-Curves ------
> #!/bin/sh
> PATH=.:/usr/local/bin:$PATH
> cd `dirname $0`
> echo " "
> sudo sh quadcurves
> ------ END
> Roy
2003-06-25 by Roy Harrington
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Jack M
> Thanks,
> Jack
> Jack M Kucy
> 917-991-2096     jmk@j...
Yes, it's Mac OS X only.  Availability for Windows
unfortunately, is not easy.  I'm not very familar with internals
of Windows so I haven't any idea how much work it would be.
There are a few people getting it running on Linux but even
just getting Linux running isn't an easy task.
Roy
