Thanks for the encouragement and the links. I will give it a try. I
can always go back to MIS-VM if there is a problem.
Steve
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Alan Zinn
<AZinn@n...> wrote:
> At 02:17 AM 7/8/03 +0000, you wrote:
> >Steve,
> >I'll tell you after I do it the first time. I ordered the carts
> >syringes and Ultratone ink for refilling a 1280 and it should be
> >arriving any day. Most folks say it's pretty easy after you do it
a
> >few times. MIS has some pretty detailed instruction on their site.
> >You should let the filled carts sit overnight to let the bubbles
> >dissipate and Paul Roark suggests wearing old clothes the first
time
> >and not doing it in a sink that your wife will have a problem with
> >if you mess it up. I'm anxious to try these new inks with Paul's
> >curves.
> >Tom
> >--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Stephen
> >Kobrin" <skobrin@h...> wrote:
> > > In response to a question about the availability of Ultratone
inks
> >in
> > > carts for the 1200, MIS told me that they were not available
now,
> > > although they did plan to make them available at some point.
They
> > > suggested that I buy empty carts from them and load them myself.
> > > That sounds like it would be more economical than buying loaded
> > > carts, but I am not sure how much of a hassle it will be and how
> >long
> > > partially filled bottles of ink will keep.
> > > Does filling carts yourself require a lot of care to prevent
clogs
> > > and bubbles or is it a relatively straight forward process? Has
> > > anyone used the new Ultratone inks on a 1200?? From what I have
> >seen
> > > thus far on the list, it sounds like it would be worthwile
> >migrating
> > > from the MIS-VM inkset.
> > > Steve
> Guys,
> >I re-fill using a top-off system see my web page below. It has
worked
> >fine through about eight ounces of FS inks. Once the carts are
filled the
> >first time it's a snap to keep them full.
> AZ
> Build a Lookaround!
> The Lookaround Book.
> http://www.panoramacamera.us
