<paul.roark@v...> wrote: Paul
I am using the new MIS plastic tube holders the one that is about 6
in long with a tube clip on the under site. It keeps the tubes
fairly streight. What I did was put some spray silicon on the tubes
and inside of the carrage, so that any tube rubbing would not cause
any damage.
The only minor problem I see is the carts are held in place by the
plastic wire strap, which holds both carts in place. The felt pads
should should work without the plastic strap.
Since I don't do much semi or gloss printing, I think I will stay
with the CFS Eboni and use a standalone PK cart for gloss.
The system is working so well I don't to mess with it. My prints have
never been so good.
Thanks again
Ed Blake
> Ed,
> >I am using a 1280 with MIS UT CFS ink set. It works very nicely
with
> >no clogs. I would like to print on some gloss paper.
> >Has anybody come up with a easy way to change out the Eboni cart
for
> >a PC cart with out makeing a mess.
> > My thought was to seperate the EBoni CFS tube from the bundle and
> >insert a new tube from the PK ink bottle to the new PK ink cart.
> There has been talk of using the CFS/CIS just for the color-
position inks
> and using carts for the black ink.
> When I used a CIS on my 1160, I did what I think you are talking
about,
> although for other reasons. I separated the black line and had
separate
> black inks. It worked, but barely. With the 1160 -- a quad -- the
tubing
> ribbon with only 3 lines became unstable, flopping all over the
place. I
> was usually able to tape the black line onto the other 3 and get it
so that
> it would not catch on anything, but I always worried about that
possibility.
> It often took a number of different tape positions to finally get
the setup
> to the point where even in slow motion testing the tubes stayed
where the
> were supposed to be.
> Because of my marginal luck with taping the black tube on the other
3, I
> don't recommend using CFS/CISs this way on 1160s. I now just fill
empty
> carts each time.
> With hextone printers, I think a 5-tube ribbon would be fine.
Whether it'll
> stay stable when you try to tape on the 6th/black like is an open
question.
> Give it a try and let us know. Be sure to test the setup manually
by moving
> the carriage back and forth to see where that tubing ribbon is
going to flop
> to.
> Good luck.
> Paul
> http://www.PaulRoark.com
