MIS Ultratones for the 2200: questions
2003-07-30 by chipcarterdc
I'm intrigued by the ultratones from what I've read. I have a few questions and haven't been able to find answers in the archives (maybe I'm just not a good searcher). Hopefully someone can help me out here: (1) Does use of the ultratones in the 2200 require use of special software? I'm really put off (OK, intimidated) by all the stuff I've read regarding various complicated procedures for most of these alternative systems (e.g., "you just need to create your own custom ink curves to linearize the driver response" -- I have no idea what that means and would rather not have to). When using the ultratones in the 2200, do you print with the standard epson software; some special MIS software (at an extra cost, presumably); or some 3rd party software like this GimpPrint thingy I've read about? (2) The reason I have a 2200 is to be able to print color and black and white on the same printer. When you pop out the MIS cartridges, do you have to run some special or complicated cleaning routine to get all the MIS ink out of the printer head before going back to the normal epson cartridges? Or do you just use the epson cleaning routine that's available in the epson driver? (3) I currently have ImagePrint 5.5 and have been the most pleased with that for black and white printing in comparison with other software I've tested (QuadTone RIP (which I admit I didn't fully understand), Epson's RIP for the 2200, black only printing). Will I see a noticeable improvement over ImagePrint by using the MIS inks? It seems like the answer must be yes (since I'd be using 7 shades of gray ink instead of 2 shades of gray ink plus color ones as with ImapgePrint) but I'm interested in anyone's realworld experience with the two. (someone mentioned a comparison in an earlier message, but I can't find it now) Thanks!
