On Sun, Aug 17, 2003 at 09:01:48AM -0700, winddancing wrote:
> Since several bursts of fresh highly diluted developer are possible by
> sequencing is it possible to consider using a Jobo processor for stand
> developing? Would a full drum/tank cover the film? Would one just turn off
> the processor?
Depends on how you fill the tank. You'd probably need at least the volume
listed on the tank for normal inversion development, probably even more - to
the point where there was very little air in the tank at all. I also don't
think it is possible at all if you have a lift and are using the drums with
the lift cogs attached - you'd find the developer would part drain.
Tony Terlecki
ajt@...
