Eboni-Neutral/Selenium, Piezo-compatible inkset
2003-08-25 by Paul Roark
As I mentioned previously, I'm experimenting with Eboni-based inksets.  The
purposes include to see if I can make an even more lightfast inkset than the
Ultra Tones (Eboni is remarkably stable and more neutral than the UT grays),
to upgrade the vm-s inkset (which currently used FS-N as the gray ink), and
to make available another alternative for the old Piezo driver.
The interim formula I have for a Piezo-compatible inkset is as follows:
The cyan position ink is
	23.9% Eboni black,
	4.8% MIS 7600 cyan,
	6.5% MIS 7600 magenta,
	64.8% MIS clear base.
The magenta-position ink is 23.5% cyan dark gray, above, remainder clear
base.
The yellow-position ink is 45% magenta middle gray, above, remainder clear
base.
This ink is for matte paper, not RC.
The Piezo driver on my 1160 prints the inks with the following densitometer
readings:
	25% patch: c=.32, m=.33, y=.32, visual=.32
	50% patch: c=.61, m=.62, y=.61, v=.62
	75% patch: c=.95, m=.96, y=.94, v=.95
So, the ink is quite neutral, going a bit cool in the shadows, and having a
bit of a "selenium" bias to it.
I matched the old PiezoBW ink densities with the above mix.  Note that the
PiezoTone sample test prints that have been sent to me indicate that ink is
a bit more dense than the original PiezoBW ink.
For the ink mixers out there, this might give you an interesting and rather
inexpensive alternative to the current PT selenium.
I have no idea if MIS is interested in mixing this ink.  I'll, of course,
send the formula to them also.
I will be fade testing various alternatives to this formula -- basically
different color pigments.  Based on past experience, I expect the MIS 7600
color pigs used here to win that contest, but since I have not tested this
combination before, the results could be different.
Hope this is useful.
http://www.PaulRoark.com
Re: Eboni-Neutral/Selenium, Piezo-compatible inkset
2003-08-26 by B. Alex Pettit Jr.
Thanks Paul,
I will be ordering the inks today and try them over the
next few weeks in my Epson 3000, Piezo driver.
Best,
Alex
Orlando Fla
inksets.  The
than the
grays),
ink), and
follows:
RE: [Digital BW] Re: Eboni-Neutral/Selenium, Piezo-compatible inkset
2003-08-26 by Paul Roark
Alex,
>Paul, which Black ink,
>The MIS 7600 Archival Eboni or MIS GP Archival Eboni ?
I assume they are the same.  I'll see if I can get verification for that.
Note that the Eboni-NS is an experimental inkset that I mixed.  It is not
something MIS has even expressed interest in.  It's mostly a first step to
an upgraded vm-s that I'm interested in.
Curve for Eboni-NS (Neutral/Selenium)
2003-08-27 by Paul Roark
I've been printing with the my experimental Eboni-based quad and have found
that with the Piezo driver I often get some unevenness in smooth tones --
like wide banding.  With the Epson driver none of this is present.  I don't
know if it is my 1160, the old Piezo driver, or the inkset.  My 1160 often
didn't do very well with the Piezo driver, which is one reason I switched to
the Epson driver long ago.  (Since my target for the inkset is the Epson
driver and vm-s, this is not an issue that concerns me now.)
For the Epson driver, I have a curve that prints the "Eboni-NS" (my name)
very well on the 1160.  (The curve is cross-platform.)
I have done enough with this for now.  I'll have to see the fade tests
before pursuing this approach further.  (For now this is only for those who
want to mix your own ink.)
_________________________________________
Sent: Monday, August 25, 2003 4:20 PM
To: DigitalB&WPrint
Subject: [Digital BW] Eboni-Neutral/Selenium, Piezo-compatible inkset
	23.9% Eboni black,
	4.8% MIS 7600 cyan,
base.
base.
readings:
page.
them short.
resources on the homepage.
Re: [Digital BW] Curve for Eboni-NS (Neutral/Selenium)
2003-08-28 by D. Hill
Paul,
Thanks again for the details on this inkset.  I have a
cartridge set up for a 1280 that I am going to try as
soon as my current ink is depleted (using the piezo
driver).
As an aside, I did a quick q-tip smear test and the
tones look very impressive - exactly what I am looking
for.  Not too warm, not too cold, its just right...
You should consider renaming this inkset as
"Goldilocks."
Hopefully I'll have much to post after this weekend.
thanks again,
Don
> inkset is the Epson
> me now.)
> cross-platform.)
> see the fade tests
> Paul
> From: Paul Roark [mailto:paul.roark@...]
> To: DigitalB&WPrint
> Piezo driver.
> 	23.9% Eboni black,
> 	4.8% MIS 7600 cyan,
> base.
> base.
> readings:
> Paul
> page is at:
> page.
> one.
> them short.
> attacks or flames
Do you Yahoo!?
SBC Yahoo! DSL - Now only $29.95 per month!
http://sbc.yahoo.com
Re: [Digital BW] Eboni-Neutral/Selenium, Piezo-compatible inkset
2003-08-31 by D. Hill
Hi all,
Just an update - Finally the Selenium Piezotone Cart
has run its course through my printer.  Earlier this
week I had mixed Paul's set given below and installed
the new carts this afternoon.  After a bit of printer
coaxing, I was able to print without problem or
banding via the Piezo driver on my 1280.  In addition,
I have to admit that this is one of the cleanest and
most beautiful inksets that I have used.
Once again, thanks Paul.  This is exactly what I have
been looking for with my digital printing.
Don
> Piezo driver.
> 	23.9% Eboni black,
> 	4.8% MIS 7600 cyan,
> base.
> base.
> readings:
> Paul
Do you Yahoo!?
