RE: Epson Velvet Fine Art (was: EAM turns yellow!_
2003-09-01 by Alessandro Pardi
Ron,
just to make sure: are you using the same ICC profile for the two papers or you print on each paper with its own profile? I ask this because I print with curves (the excellent Randall workflow), and therefore a different paper would mean tweaking the curves (unless it takes the same profile).
BTW, in a post dated Oct, 12 ("New Epson Velvet Papers"), Robert Morrison talked about a 40 years longevity rating published by Epson for this paper. If this is true, then we probably need to look elsewhere for a true archival paper.
Alessandro
Sent: Monday, September 01, 2003 15:50
Subject: [Digital BW] Re: EAM turns yellow!
Alessandro,
Yes, prints on EEM and EVFA are nearly identical.  I am using the
standard Ultrachrome inks on the Epson 2200.  For printing I am
using ImagePrint 5.5 available from www.colorbytesoftware.com. So, I
do all my general printing and proofing on EEM and make my fine art
prints on EVFA.
When printing with ImagePrint, I am using their furnished ICC paper
profiles.
I do find that prints made on EVFA paper using the above method seem
to have more "depth" than when printed on EAM/EEM.
Ron
Re: Epson Velvet Fine Art (was: EAM turns yellow!_
2003-09-01 by harrisimages
Alessandro,
Yes, I use a different profile for each paper...each paper with it's
own profile.  I can say that using EVFA paper I can see slight
differences between using the EEM and EVFA profiles....however,
ImagePrint profiles will show variances even with the same paper and
1440 dpi and 2880 profiles. I haven't tried using the EVFA profile
with EEM.
If you are using the Randall Workflow, I assume you are printing
with PiezoTone inks.  If so, you will get a higher Dmax using
PhotoRag than you will with EVFA or EEM. And with PiezoTone inks
Dmax will increase over a few days time on PhotoRag.
You asked about print life....this number has bounced around a bit.
The latest from Wilhelm is:
http://www.wilhelm-research.com/ep9600%20print%20permanence.html
here he rates EVFA with B&W printing using full-color Ultrachrome
inks at 115 years, and greater than 140 years if sprayed with
PremierArt spray.
Ron
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Alessandro
Pardi" <alessandro.pardi@i...> wrote:
> Ron,
> Alessandro
> From: harrisimages [mailto:harris@s...]
> Alessandro,
I
art
> prints on EVFA.
paper
> profiles.
seem
> Ron
