RE: [Digital BW] Re: Epson Velvet Fine Art (was: EAM turns yellow!_
2003-09-04 by Alessandro Pardi
Ron,
I'm printing with MIS FS inks (now with Eboni black). I'm afraid that EVFA would need tweaking of the curves, and this isn't something I'm very willing to spend time on :-)
PhotoRag, the only other paper "profiled" for this workflow, is the obvious - expensive - alternative.
Thanks again for your help,
Alessandro
Sent: Monday, September 01, 2003 23:38
Subject: [Digital BW] Re: Epson Velvet Fine Art (was: EAM turns yellow!_
Alessandro,
Yes, I use a different profile for each paper...each paper with it's
own profile.  I can say that using EVFA paper I can see slight
differences between using the EEM and EVFA profiles....however,
ImagePrint profiles will show variances even with the same paper and
1440 dpi and 2880 profiles. I haven't tried using the EVFA profile
with EEM.
If you are using the Randall Workflow, I assume you are printing
with PiezoTone inks.  If so, you will get a higher Dmax using
PhotoRag than you will with EVFA or EEM. And with PiezoTone inks
Dmax will increase over a few days time on PhotoRag.
