A way to get a glossy surface
2003-09-06 by sanfo2003
I was fooling around with different coating techniques when I came up
with this way to get a glossy surface on EEM.
I airbrushed (coating rod may work too) a smooth generous coat of a
Hydrocote/Flow Ayd mixture and dried it to the touch quickly with a
hair dryer. Let the coating dry an additional 15 minutes or so and
then put print on glass face up with a piece of typing paper (or
poster paper if print is large) between it and the glass. With a
rubber roller, roll on a sheet of waxed paper (the kind you get at
the grocery store) covering the print. Roll hard making sure there
are no wrinkles or bubbles, then immediately pull off waxed paper.
Heat surface just a bit with hot air from the hair dryer again and
you will have a nice glossy surface. Let dry normally.
The gloss I got using Satin Hydrocote using this technique is the
same as the surface of regular Epson Photo Paper. Haven't tried
Glossy Hydrocote.
I tried this identical technique except airbrushing to an "orange
peel" surface consistancy before rolling and when done ended up with
a surface like Epson Premium Luster.
Re: A way to get a glossy surface
2003-09-06 by Rob Adams
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "sanfo2003"
up
//The gloss I got using Satin Hydrocote using this technique is the
Glossy Hydrocote.//
Hmmm....where did I put that ferrotyping drum..
Interesting technique.
