Thank you Roy and Roger for your suggestions. Unfortunately, I
couldn't get anything working. It is interesting to note that after
tossing the 2200 from Print Center and reloading it (along with
fresh profiles) the printer started to respond. Print Center said
that the QUAD2200 was printing. It said that for about 5 seconds
and then it disappeared and nothing else happened.
I'm going to throw out and reinstall OSX 2.6 next. I hate doing it,
but it probably is a problem on that level. It is curious that it
would occur in both machines.
Frank
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Roger
Sopher <rlsopher@c...> wrote:
"culturalvisions"
> > <fmward@h...> wrote:
> > > The 2200 with G4 desktop or my G3 iBook does not
respond when I try
> > to print
> > > from ImagePrint Rip or Quadtone Rip 2.0. It seems that I
am doing
> > something
> > > wrong, but I don't know what. The 2200 woks fine when
printing out
> > of OPM
> > > or the standard Epson driver. It even prints through the
QTR2 when
> > I have the
> > > printing software set on QTR2 Calibrate. Unfortunately, that
> > setting does not
> > > seem to allow for any adjustment.
> > > Yes, I've followed the instructions on IP and QTR2
meticulously and
> > had a
> > > friend with both systems installed go through it with me. I
am
> > running OSX
> > > 2.6 and everything else seems OK. Has anybody had this
problem?
> > > Frank
> > > http://www.culturalvisions.com
> > Frank,
> > It sounds like the OS X print system is somehow hungup. It's
very
> > strange
> > that the calibrate mode would work but not the regular mode.
OPM and
> > the Epson driver reach the printer in completely different
ways -- but
> > at
> > least their working says your hardware is connected
correctly. I'm
> > not
> > sure how IP connects through OS X to the printer.
> > You could check the error_log using Print-Gimp-Errorlog.
This may or
> > may not give you a hint about what is wrong.
> > Anyway, my suggestion is to Delete the printer from Print
Center and
> > re-add
> > it. That will clear out the spooling queues and reinitialize
them.
> > You
> > will have to run Run-Install-Curves again to get the curves
back.
> > Roy
> > www.harrington.com
> One place to look is at the descriptor file eg 860-fs.txt. I had a
> similar problem until I found a typo made when I modified one
of the
> canned files to fit my paper and inkset. Once I found the typo,
> corrected it and reloaded using run-quadprofile I was able to
print.
> Roger
