Dimage 5400 vs Nikon Coolscan 4000
2003-10-01 by digikdm
I have recently had the opportunity to compare these two film
scanners and
have found the following. I use a Mac 10.2.8, 1gigabyte of RAM and PS
7.0
1. The Dig. Ice function on the 5400 results in substantial image
degradation. I
was shocked how bad the results were with Dig Ice activated. WITHOUT
Dig. Ice turned on, the Dimage scan for most negatives was comparable
in
quality to the Nikon WITH Dig. Ice activated. Even here, I give a
slight edge to
the Nikon in quality, crispness etc. Of course, with the Dig Ice
turned off,  there
is substantially more time/work involved in cleaning up the scans on
Dimage.  You will be disappointed if you expect  the 5400dpi to
result in a
better scan than the Nikon 4000dpi. IT DOESN'T.
2. The Dimage was significantly  slower.  With Dig. Ice turned on and
4x
multisampling at 5400dpi, a scan takes at least 40 minutes compared
to about
15-20 for the Nikon. With Dig Ice off , the Dimage can do a 5400 dpi
scan(4x
multisample) in about 15 minutes.
3. The scanning process with the Dimage is markedly impeded by
simultaneous work in Photoshop. I don't have an explanation for this
, and
neither did Minolta's technical help. I have a GIG of RAM so memory
should
not be an issue. All of the scan times are markedly prolonged with
Photoshop
being used simutaneously, and in some cases the scanner will simply
abort
the scan leaving you nothing after an hour scan. The Nikon scanner
does not
seem to be affected specifically by Photoshop, but I've  found it too
will
occasionally abort a scan for unknown reasons.
4. The Nikon is known for some softness around the edges due to a
very
narrow depth of field and failure to hold the negative perfectly flat
. I have
found this to be true for the Nikon, but could not determine in a
test scans if
the Dimage was any better. They seemed about the same.  I did find
the film
carrier/holder for the Dimage relatively easy to use. It made for
easy air
gunning of the negative once it was loaded into the carrier.
5. Dimage scans in general are more contrasty . I prefer the Nikon in
this
regard since I can always adjust the contrast in Photoshop and don't
want to
lose any detail up front.
6. There was one test negative I used that the Dimage totally failed
to give a
good scan on. On two attempts the scan was overexposed and blown out
on
the high end.I thought maybe the scanner had broke, but it worked
fine on
another negative minutes later. No explanation. The Minolta technical
help
said simply" if you think the scans are overexposed, send it back to
us so we
can test it". The Nikon did a great job on this negative.
7. The Minolta is cheaper by a few hundred dollars, so if cost is a
factor it may
be the only way to go. Do not use the digital ice if you want high
quality scans.
The Nikon wins otherwise.
I hope this helps anyone who might be looking at these two scanners.
Kevin Monroe
kevinmonroephotography.com
RE: [Digital BW] Dimage 5400 vs Nikon Coolscan 4000
2003-10-01 by Daniel Staver
> in substantial image degradation.
I haven't noticed image degradation at all with ICE enabled. Which type
of film did you scan?
> WITHOUT the Dig. Ice turned on, the Dimage scan for most negatives was
> comparable in quality to the Nikon WITH Dig. Ice activated. Even here,
I
> give a slight edge to the Nikon in quality, crispness etc. Of course,
with the Dig
> Ice turned off,  there is substantially more time/work involved in
cleaning up the
> scans on the Dimage.  You will be disappointed if you expect  the
5400dpi
> to result in a better scan than the Nikon 4000dpi. IT DOESN'T.
I can't comment on the Nikon, but my 5400dpi scans look better than the
4000dpi scans I got from my previous Canon FS4000US. They don't seem to
resolve more detail, but the grain looks better and more detailed than a
4000dpi image upsampled to 5400dpi. In other words the 5400dpi seems
useful purely as an upsampling method.
> turned on and 4x multisampling at 5400dpi, a scan takes at least 40
minutes
> compared to about 15-20 for the Nikon. With Dig Ice off , the Dimage
can do a
> 5400 dpi scan(4x multisample) in about 15 minutes.
The scanner is MUCH slower with C41 films and ICE enabled than with
slides or BW negatives. Part of the reason for the slowness is also that
the Minolta software enables the grain dissolver when you use ICE,
without the option to switch it off. Vuescan lets you scan with
dust-removal without using the grain dissolver, and that easily halves
the scanning times. Unfortunately the dust removal in Vuescan affects
the entire image, so I prefer to use the Minolta software for this and
do something else while it's scanning.
I have never noticed any improvement when using multisampling with this
scanner, so I would only use it if I specifically noticed a problem with
a certain slide or negative that I thought could be solved by using
multisampling. I have not come across such a slide or negative yet.
> for this , and neither did Minolta's technical help. I have a GIG of
RAM so
> memory should not be an issue. All of the scan times are markedly
prolonged
> with Photoshop being used simutaneously, and in some cases the scanner
will
> simply abort the scan leaving you nothing after an hour scan. The
Nikon
> scanner does not seem to be affected specifically by Photoshop, but
I've
> found it too will occasionally abort a scan for unknown reasons.
I've never had any aborted scans or performance problems when using
Photoshop, but I'm on a PC (1gig ram) with windows XP, so it could be a
hardware/os specific issue.
> to a very  narrow depth of field and failure to hold the negative
> perfectly flat . I have found this to be true for the Nikon, but could
not determine
> in a test scans if the Dimage was any better.
Unfortunately, there IS a problem with edge to edge sharpness. A glass
holder would be desirable, but I don't think such a thing exists for
this scanner.
> Nikon in this regard since I can always adjust the contrast in
Photoshop
> and don't want to lose any detail up front.
> failed to give a good scan on. On two attempts the scan was
overexposed and
> blown out on the high end.I thought maybe the scanner had broke, but
it
> worked fine on another negative minutes later. No explanation. The
Minolta
> technical help said simply" if you think the scans are overexposed,
send it
> back to us so we can test it". The Nikon did a great job on this
negative.
I prefer Vuescan for BW negatives. The included film profiles does
wonders for many BW negatives which doesn't look all that good when
scanned with the Minolta software. Especially TMAX-100 and Tri-X looks
much better when scanned with Vuescan.
I've also found the Minolta to be much better at handling difficult
negatives than my previous Canon.
> cost is a factor it may be the only way to go. Do not use the digital
ice if you want
> high quality scans. The Nikon wins otherwise. I hope this
I'm a little puzzled by the image degradation you're experiencing with
ICE, as it does not reflect my experience with this scanner. I can
hardly tell the difference between scans done with and without ICE,
except that the dust is gone when ICE is enabled of course.
Daniel Staver
http://daniel.staver.no
Re: [Digital BW] Dimage 5400 vs Nikon Coolscan 4000
I used Fugi REALA 100 predominantly. The effect is especially
noticeable at 200x.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Daniel Staver"
type
negatives was
here,
> I
course,
> with the Dig
> cleaning up the
> 5400dpi
seem to
than a
40
> minutes
Dimage
> can do a
that
halves
affects
and
this
with
of
> RAM so
> prolonged
scanner
> will
> Nikon
but
> I've
be a
could
> not determine
glass
> this scanner.
> Photoshop
> overexposed and
but
> it
> Minolta
overexposed,
> send it
> negative.
looks
digital
> ice if you want
with
> Daniel Staver
2003-10-01 by Steven Karafyllakis
>>glass holder would be desirable, but I don't think such a thing
>>exists for this scanner.
Just a thought: has anyone tried glass slide holders for slides? I
realize this would introduce other problems, but if you didn't get
the dreaded newton rings, it might be worth the effort in some
cases. This problem is much worse on the medium format Nikon, mf
film being so much flimsier, etc. At least there you do have a glass
carrier available. Ernst Dinkle once posted a link to detailed
instructions showing how to take a MF strip holder and convert it to
a glass carrier; perhaps the idea could be applied to a 35mm carrier?
I have a simpler (though not as effective) way to deal with the
problem. I use 2" lengths of miniature 'I' beams or square tubes
(model-making construction components picked up at a hobby shop)
tacked down between frames and at any unsupported ends to hold the
film a bit flatter. They are held down by double-surfaced sail-
maker's tape, which is aggressively tacky, and lasts through many
applications if kept out of the dust. The tape is available from
canvas/sailmaking shops, or in art supply stores in smaller rolls.
As I said, this isn't as effective as a glass carrier, but it helps
a lot and is much less trouble than keeping six surfaces dust free.
Hope this helps
Steve Karafyllakis
http://www.stevekphoto.com
2003-10-02 by colingruk
and
I use my laptop for scanning and photosho (vt) on the desktop.
could
> not determine
glass
> this scanner.
Anti-Newton glass is made for the Nikon 4000,  These are contact
addresses Email:mike@..., Web Site http://www.fpointinc.com
that I found on the Yahoo Nikon 4000 group
Mike emailed me as follows:
<<You have to replace the top piece of plastic with our glass and
bend the
small aluminium tabs thst hold the plastic up and out of the way of
glass.  This means that your holder effectively is permanantly
converted
to a glass holder since the tabs will eventually break off if you
bend
them each time the plastic is replaced by the glass.
It can be ordered online at
http://www.fpointinc.com/cgi-local/web_store/web_store.cgi   Just
enter the word "nikon" in the search window and glass sizes
will come on screen.  Indicate the number you need and add them to
shopping cart.  Then check out.>>
 I've only just received mine and cannot comment other than to say it
sort-of clips into the aluminium part of the film strip.  For me the
fit was difficult and not entirely satisfactory as the glass could be
thinner:I guess it would have been if it were not then more
susceptible to breakage.  It cost US$33 for shipment to my son in
continental USA and he shipped it to me across the pond.
Colin
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "colingruk"
Sorry, $33 INCLUDING SHIPMENT continental USA>
> Colin
