levels and curves
levels and curves
2003-10-01 by Stephen Kobrin
This question may be rendered moot in Photoshop CS as according to
Evening's introduction you can have a "live historgram" running while
you use curves.  As I understand it, you will be able to see the
impact of any curves ajustment on the histogram in real time.
The bad news, at least for some of us, is that it looks like CS
requires a Pentium III processor.  I have a II with plenty of memory
that works just fine with PS 7.
Steve
Re: levels and curves
2003-10-01 by J Michael Sullivan
I'm sure the Adobe dudes figured out a way to optimize it for the G5 chip too :(
No matter, moving Gigabytes of 16bit layers is gonna require one kickass machine!
mjs
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Stephen Kobrin"
> Steve
2003-10-01 by Mark Hahn
I'm not sure that Adobe does it, but from my tests only a small sub-
sample of an image is all that is really needed for a accurate
Histogram... the big question is how useful is it really?  I mean,
are you really not going to apply the specific curve to an image
which makes it *right* because you don't like the look of the
histogram?
mark
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "J Michael
G5 chip too :(
kickass machine!
> mjs
Kobrin"
to
while
memory
> > Steve
2003-10-02 by J Michael Sullivan
Not sure what you mean by a small subsample. If you mean an arbitrary section of an
image, then I can assure you many of your images are being edited under a false
pretense!
The premise of a histogram is to demonstrate the prevalance of data distribution in
an image. The begin and end points are what most people focus on, but they are only
one small aspect of the usefulness of a histogram. It is VERY useful to look at an
image and "see" that it is mostly high-key, or low-key, or mid-key, or evenly
distributed. Having such knowledge is important as to which is the best method (and
there are many) to enhance the most critical image detail, as there is no way that
EVERY pixel can be important -- to me this is the key of good scanning.
MJS
(author of "Make Your Scanner a Great Design and Production Tool", now out of print)
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Mark Hahn"
> histogram?
> mark
> G5 chip too :(
> kickass machine!
> > mjs
> Kobrin"
> to
> while
> memory
> > > Steve
2003-10-02 by Mark Hahn
Take any image, cut the resolution by some factor, resampling with
nearest neighbor interpolation (so you retain actual image data), and
compare histogram to original, then cut it again... and so on and so
on...  You will see that the histogram remains unchanged for a good
number of progressive subsamples.  You could make a whole statistical
study of why this works if you chose to:)  Of course an arbritary
section would not be an actual sample of the entire image and would
probably not be representative of the image as a whole...
Yes, the histogram is a great visualization tool for understanding
your image... no arguement there:)
mark
under a false
> pretense!
distribution in
but they are only
or evenly
best method (and
is no way that
scanning.
> MJS
now out of print)
sub-
mean,
> > histogram?
> > mark
> > G5 chip too :(
one
> > kickass machine!
> > > mjs
> > Kobrin"
according
> > to
running
> > while
CS
> > memory
> > > > Steve
