Basic levels adjustments
2003-10-07 by Steve Kale
A basic PS question:  I am working my way thru Martin Evening's PS book as I try to
learn more about digital.   I am a little confused by the discussion re Output Levels in
the Image > Adjustments > Levels section.  Martin always seems to talk in terms of
half tone printing presses and talks about constraining the output levels (eg 12 to
243) to suit the press.  What if any alteration to these output levels should I do to
print on an inkjet printer?   (I predominantly print using my Epson 2100 - both B&W
and Colour but would also like to deliver content to larger format Epson printers or
even a Lightjet printer at a lab.)
Thanks in advance
Steve
RE: [Digital BW] Basic levels adjustments
2003-10-07 by Paul Roark
Steve,
I want some 100% black and 100% white in my prints.  The 100% white spots
have to be very small, but they add some sparkle as spectral highlights.
So, I avoid significant blank spaces at the ends of the levels histogram
(just a little for scanning and processing to give some room for errors and
sharpening), and for printing I have none at all.
http://www.PaulRoark.com
_____________________________________
Sent: Tuesday, October 07, 2003 10:37 AM
Subject: [Digital BW] Basic levels adjustments
try to
Output Levels in
terms of
(eg 12 to
should I do to
both B&W
printers or
Thanks in advance
Steve
page.
them short.
resources on the homepage.
Re: Basic levels adjustments
2003-10-07 by Mark Hahn
With some simple tests you can find what level your printer starts
printing full black at (typically not 0) and limit output to that.
White is trickier.  If you have spectral highlight with a hard edge,
going to paper white gives you a real sparkle, but if you are
breaking to pure white on something like someone's cheek, it doesn't
usually look that good.  You can do tests and find out what the
lightest shade of gray that you can *print* and then limit output to
that.  Taking 5-10 off each end isn't a bad starting point.
mark
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steve Kale"
book as I try to
talk in terms of
levels (eg 12 to
2100 - both B&W
Epson printers or
> Thanks in advance
> Steve
Re: [Digital BW] Basic levels adjustments
2003-10-07 by Tom Baker
This is a lot like planning a negative to print in the darkroom.  You first must know the ranges of your paper/printer/profile (paper/developer/light source, in the darkroom).  Once you khow where the points of blackest black and whitest white start you are in a position to make the call about what output levels you need in your output file for printing.  You need to run those basic tests on your printer(s) to start.  That's a lot easier on an ink jet than in the darkroom.
Steve Kale <stevekale@...> wrote:A basic PS question:  I am working my way thru Martin Evening's PS book as I try to
Thanks in advance
Steve
Yahoo! Groups SponsorADVERTISEMENT
