VM and 1280
VM and 1280
2003-10-14 by Matt Betea
Last week I got my replacement 1280 for my first one. Figured I would
give the VM inks another shot. Posterization is still there,
horizontal banding is still there. I've tried cleaning, nozzle checks
(never a clog), head alignments, nothing changed. Also ran through
about 5 different sets of curves with the same results. Tweaking some
sets got me almost there, but every time I messed with one part it
would throw another out of whack.
Out of all the curves I've tried for the 1280+VM set, the curves that
got me closest to anything acceptable was the UT curves for the 1280.
Thinking I might have another problematic printer, I try some Epson
inks. Banding and posterization is gone. I've read a few places that
mentioned something about the MIS cartridges maybe sitting slightly
different in the carriage to cause some of these problems. Has anyone
ever heard about this? I was looking to maybe tryout the UT inks, but
I don't know if anything would changed compared with the VM inks.
Anyone get bad results from VM inks that going to UT inks cured?
Thanks, time to go pull more hair out.
matt
Re: VM and 1280
2003-10-14 by Gareth
The big thing that needs to be addressed is the levels throughout the
image making sure there are no big gaps in the histogram.  These come
about by too much manipulation in curves/levels.
I had this problem and went back to scanning the original image back
in again using Vuescan and getting the image to what it should look
like before playing with it in PS7.  This made all the difference.
If you have BB/ADSL send me a link to a file I can download and I
will see if I can reproduce the errors that you are talking about
using my 1290/UT setup.
Gareth
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Matt Betea"
would
checks
some
that
1280.
that
anyone
but
> matt
1280 and the lack of built in paper cutter
2003-10-14 by gendem
For those of you with a 1280, do you find the lack of
a paper cutter built in to be a big deal?
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
http://sitebuilder.yahoo.com
An expensive experiment...wish me luck!
Hi all
I'm about to order the MIS variable mix quadtone
cartridge intended for the 1280 for use in my Photo
900 (NOT color 900!).  I have to use the QVM inks
because the full spectrum stuff requires the cone
driver, for which I'm not ready to pay if the
cartridges won't work! ;)
I'll keep you all posted with what I discover.  Here's
hoping the Paul's 1280 curves will work properly! ;)
...Mike
Do you Yahoo!?
Re: VM and 1280
Hi Gareth,
That was the first thing I looked at initially with the first
printer. The images I've tried printing were from a D100, shot with
the RAW format and converted to 16bit tif. Histograms would show that
everything was fine, no gaps, no "comb" spikes. I would post/send you
a file but I have no webspace at the moment other than the 10mb they
give you with cable. Here is a smaller zipped file that I can post to
my space though.
http://home.wideopenwest.com/~beteahome/technical.zip
This is an image I got from another member. It contains a step wedge
and 4 different images, I believe was made up by Clayton Jones. I
haven't been able to get this image to print with good results.
Thanks for the help.
matt
come
back
> Gareth
Re: VM and 1280
Just downloaded the file, no problems printing on 1290 with UT inks
and a tyler curve.
Not wishing you to teach you to suck eggs but you did have the file
in sRGB or RGB when you applied the curves didn't you?  When I opened
your technical.tif file is was grayscale, I then converted it to sRGB
for tyler's curves and then printed it no problems.  As a test I also
applied the curve to a grayscale image and printed that out - really
bad!!
Let me know how you get on
Gareth
> Hi Gareth,
that
you
they
to
> my space though.
wedge
> matt
> the
> come
> back
look
difference.
> > Gareth
Re: VM and 1280
2003-10-15 by Matt Betea
Thank you Gareth for taking the time to check. Yeah I have about 30
or so prints of that file trying all different combinations of
settings. But I do convert to sRGB or Adobe RGB before.
But, doing some more test prints and printing a few purge patterns
with the Epson inks. I see luck isn't on my side. The horizontal
banding I'm getting is coming from all the color inks. I've tried a
couple more settings in the print driver but nothing changed it. So
time to send this one off I guess. Thanks a lot for your help, I
really appreciate it.
matt
> and a tyler curve.
opened
sRGB
also
really
> bad!!
> Gareth
Re: VM and 1280
2003-10-15 by Gareth
No problems.
Gareth
> matt
inks
> > and a tyler curve.
file
> opened
> sRGB
> also
> really
> > bad!!
> > Gareth
Re: 1280 and the lack of built in paper cutter
2003-10-15 by dgabbe2001
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, gendem <gendem@y.
No.  I found a nice, effective paper cutter for 13x19 paper at
PhotoPlus 2yrs ago.  It's now availaible here:
http://www.bhphotovideo.com/bnh/controller/home?
O=productlist&A=details&Q=&sku=17524&is=REG
The plastic lock which holds the blade in place is the weak spot in
the design.  My cutter lasted 2yrs before it needed replacement.  It
had moderate to heavy use & for $15, I don't mind replacing it.
Dave G.
Need RC paper suggestion
2003-10-16 by Ed Mathews
I've ordered the UT B&W inks with PK black for my 1280.  Can someone
suggest an RC paper with a swellable surface for better longevity and
also a pearl or textured finish?  I bought the PK black just for the
purpose of printing onto RC paper for my wedding photographs but I'm
wondering if I made a mistake because I can't seem to find a pearl
finished paper that's not instant dry.
Ed
http://lightandsilver.com
Re: [Digital BW] Need RC paper suggestion
2003-10-16 by Editor P.O.V. Image Service
1) Given that the UT inks are pigment based, I question the desire for a
swellable polymer paper, as I haven't seen data showing increased
longevity for anything but dye-based inks on swellable polymer papers.
2)    EPSON does not recommend the ColorLife Paper as appropriate for
the 2200 (the only swellable polymer paper AFAIK that EPSON sells)  But,
it has added anti-oxidants and I personally hate the look and feel of
that paper...
Given the basic chemistry and physics involved, I don't see how a
swellable polymer paper would generally be compatible with pigment based
inks, but perhaps I'm missing something..
I'd go with the Ilford Smooth Pearl or Smooth Glossy Galerie papers..
Just my 2 cents....
Keith Krebs
"Just some guy," and caretaker of the Multiverse's largest EPSON printer
User Community (highly recommended by Vogon Poets and MegaDodo
Publications), at:
http://groups.yahoo.com/group/EPSON_Printers/
"For the rest of you out there, the secret is to bang the rocks together
guys"
2003-10-16 by Jon
I couldn't tell from the pic at B&H, but I'm assuming this cutter is only
long enough to trim the 13" side?
Jon
