MIS - B&W Printing - right system? Help
2003-10-29 by aevoegels
Hi all,
I've been reading this site and other for over 6 months now. I have
done extensive research in color printing and calibration/ profiling
on the Canon, HP and Epson printers.
At the same time I started reading about B&W printing since in my
opinion I can't get a descent B&W print from color printers - it
needs to be a quad system.
I've been told that MIS offers quality for a low price. The B&W
printing research has made my head spin more than once! I've been
looking into MIS and Piezo. I'm willing to start with the MIS, with a
1160 or 1280 and ultratone inks, and have the following questions for
you:
1 - Is there any difference on using the 1280 over the 1160? Is it
better to use the 6 bottles over the 4 bottles. I will be using the
printer for B&W only, so a 4 color printer would be cheaper, but I
would like the best quality. Will one perform better than the other?
Less clogging? How long can I go between prints?
2 - Has anyone used both Piezo and MIS? I like the selenuim, but not
sure it's worth the extra cost. I wonder if Piezo not being variable
tone that the prints will be more consistent over time. I read here
one of Roark's curves gives the selenium feeling, do you think it's
compatible?
3 - On the Piezo forum people use a lot Hahnemuhle and photorag, but
here mor of the Epson papers. Can MIS print on those papers, is it
better? Maybe more expenive?
4 - Roark's workflow does not use a RIP. If I buy the 1160 or 1280
with ultratones, will I get consistent prints? If 5 years from now I
decide to print the image again (new PS, inks, printer, etc...), can
I get the same result?
5 - If I need a print larger than 13" wide, do you know of any
commercial service to ship this to that uses the same MIS-UT inks?
6 - Longevity is important to me - is UT the best option?
Your input is greatly appreciated!
Thanks, Alfred
RE: [Digital BW] MIS - B&W Printing - right system? Help
2003-10-29 by Paul Roark
Alfred,
> - Is there any difference on using the 1280 over the 1160? ...
I used the 1160 for quite a while, and it has a great reputation.  However,
comparing the 1160 prints to the 1280 Ultra Tone prints, I think the 1280
has a quality advantage.  The light toner gives the highlights a little
smoothness advantage.  Also, the shadow tone ramp is a bit smoother.  As a
practical matter, since I and others use the 1280 more at this point, it'll
be better supported.
I've had no clogging problems with either one of them.
> ... I like the selenuim, ...
As an old silver printer who toned with selenium, that is the specific tone
the UT inks are mixed to replicate with the "neutral/selenium" curves.  The
main difference between the silver print tones and the ink tones is that the
black ink is warm.  As such, we can't get the cold deep black tones that
some selenium-toned silver prints have.  And, of course, different silver
papers and toning procedures produced different tones.  In general, however,
the "selenium" tone -- of my silver prints, PiezoTone Selenium, and UT with
the neutral curve -- is characterized by midtone spectrophotometer readings
where the cyan and yellow channels are equal, the magenta channel reads 0.01
units higher.
I don't think so.  If you're talking about fading, both the variable-tone
and monotone approaches have to use color pigments to tone the warm carbon
inks.  Whether it's in separate dots or mixed into the gray ink probably
makes no difference.  In my fade testing the PiezoTone selenium is not more
stable.
In my view, the flexibility of the variable-tone system allows one more
control over the tones among the various paper types.
> On the Piezo forum people use a lot Hahnemuhle and photorag,...
Hahnemuhle PhotoRag has been one of the most popular "rag"/cotton-based
papers, which are recommended for archival storage.  There are other cotton
papers that "flake" less (PremierArt Fine Art Hot Press, also sold as Epson
Scrapbook paper, once called "UltraSmooth" in beta) and papers that are less
expensive (Moab Entrada).  The Ultra Tones will print fine on all these,
with there being specific profiles for the latter two.
One advantage of the open Photoshop curves approach is that you can
fine-tune the curves to fit your precise printer and other variables.
>... If I buy the 1160 or 1280 with ultratones, will I
I think they are as consistent as any other inkset that we have available to
us.  Unfortunately, I've measured differences in all of the ones where I've
collected samples from different sources.  I'm not impressed with the ink
industry's quality control, and this applies to all of them that I have
experience with.  Usually, however, they are close enough that the prints
are fine.  In a darkroom setting, one has inconsistencies also.
> If 5 years from now I decide to print the image again
>(new PS, inks, printer, etc...), can I get the same result?
Who knows?  So far, new Photoshop versions have been able to use the same
curves.  I matched my curves to the average PiezoBW densities, because that
is what I was printing before switching systems, and I wanted my files to be
compatible.  I've noticed that most of the test strips I've measured that
were printed with the common RIPs use a close enough midtone target that the
files should be useable with only minor adjustments on almost any of them.
I suspect any number of us on this list would be willing to print for a fee.
I consider both the Ultra Tone and PiezoTone inksets to be
state-of-the-art -- and that is very good indeed.  In my initial testing,
they do better than the Epson Archival color inkset, which has been rated by
some at 200+ years of display.  (I have not tested all of the inksets out
there.)
I hope this is helpful.  Obviously I may have some biases, but the UT inkset
is the one I'm using.
http://www.PaulRoark.com
Re: MIS - B&W Printing - right system? Help
paul, thanks for all the good info.
Assuming that the output of the 1280 is similar to the 1270, the 1280
clearly has an edge over the 1160:
http://www.inkjetart.com/news/13_comp/8.html
I read your post about the used 7500 (check out my reply) - I wonder
if that is a good way for a newbie to go? I do not expect to do WF
very often, once in a while, but I like the idea of the large
cartridges and the freedom to print wide at home. The other option is
to buy a 1280, for good small size quality and send out for larger
prints.
I'll try the UTs. I can talk a lot about it, but nothing better than
getting my hands dirty and learning the process.
The info on the inks and the industry is not good news, but I hope
the any differences are barely noticeable. My question about
monotones and consistency was if a manufacturer produces just a
monotone, it may get better QA, than the variable-tone system. I see
that's not true but the curves are what I will need to focus on. I
have experience with PS, but not with curves. Do you know of any
internet resource/ tutorial on producing or manipulating curves?
Thanks for the info!
<paul.roark@v...> wrote:
> Alfred,
However,
the 1280
little
smoother.  As a
point, it'll
specific tone
curves.  The
that the
that
silver
however,
UT with
readings
reads 0.01
> units higher.
variable-tone
carbon
probably
not more
> stable.
more
based
other cotton
as Epson
are less
these,
variables.
available to
where I've
the ink
have
prints
the same
because that
files to be
measured that
that the
of them.
for a fee.
testing,
rated by
inksets out
> there.)
UT inkset
> Paul
RE: [Digital BW] Re: MIS - B&W Printing - right system? Help
>... used 7500 ... I wonder
>if that is a good way for a newbie to go?...
It may be a bit of overkill for a newbie.  It's a lot easier to use smaller
printers if the output is sufficient for you.
>... the curves are what I will need to focus on. ...
> Do you know of any internet resource/ tutorial on
The Files section of this forum has some information.
I just read a tutorial that Dirk Hobman has put together.  It combines the
information out there in about the best and most readable form I've seen.  I
hope he's able to post it soon.
____________________________________
> Alfred,
However,
the 1280
little
smoother.  As a
point, it'll
specific tone
curves.  The
that the
that
silver
however,
UT with
readings
reads 0.01
> units higher.
variable-tone
carbon
probably
not more
> stable.
more
based
other cotton
as Epson
are less
these,
variables.
available to
where I've
the ink
have
prints
the same
because that
files to be
measured that
that the
of them.
for a fee.
testing,
rated by
inksets out
> there.)
UT inkset
> Paul
page.
them short.
resources on the homepage.
