Hahnemühle packaging disaster, cross posted
2003-11-01 by Tyler Boley
I just lost another full 35x46 sheet of William Turner to Hahnemühle's
horrible packaging. It's one thing to have to send one out of three
shipments back due to damage, but this is ridiculous.
With William Turner, German Etching, and PhotoRag the top sheet is
yellowed in the pattern of the tape Hahnemühle uses to close the
silver paper enclosure. If it isn't yellowed on opening, it will do so
shortly after opening. Subsequent sheets after the top one is used
will continue to have the problem if the packaging is reclosed, and it
may not appear until after a print is done and delivered. There is
something outgassing from the tape harmful to their coatings, and one
would think they, if anyone, would be aware of these possibilities.
I started a large print on WT last night, told the artist to meet me
here in the morning, and what was a clean white sheet last night is
now horribly stained in the pattern of the tape right over the image.
Not only is this getting expensive, it's embarrassing and hardly gives
people faith in the longevity of this process. This was the 3rd or 4th
sheet down, which in the last few days had become the top sheet with
the paper folded back over it.
I'll have to work out some way of storing these large new sheets so I
can imediately get everything out of the packaging on arrival and hope
for the best.
This is a huge problem, unacceptable, and I think it's time to raise
hell about it. But if I'm the only one complaining, I'll just be
considered a problematic crackpot.
I hope others will join me in individually complaining to our dealers.
Ranting Tyler
Re: Hahnemühle packaging disaster, cross posted
2003-11-03 by virtuallygrey
A related Hahnemühle paper story:
A box of 50 13x19 Hahnemühle 188gsm PhotoRag I purchased a few
months
ago had two serious problems.  One was paper handling damage, the
other was machine roller damage.
The handling damage was evident immediately on opening the box.  The
wad of 50 sheets had a kink running through the middle of the stack.
This is the sort of thing that's easy to do if you handle paper
with
one hand rather than with two.  There was no damage to the box so the
fault had occurred in the factory prior to packing.
The machine roller damage was only visible with light reflected at a
very oblique angle.  It wasn't visible when looking square on.
It
was like a slightly polished finish on the matt surface running in
two parallel bands, each about an inch or so wide and about 6 inches
apart running the length of each and every sheet.  The fault is
symptomatic of a roller being jammed, probably on a chopping machine
in the factory.  Instead of the roller turning as the paper (whilst
still on the roll before being cut) feeds over it, it drags over the
jammed roller thereby damaging the surface.
My paper dealer replaced the box.  But at first he tried to tell me
that I'd kinked it – no.  Once he finally acknowledged the
roller
damage did he agree.  I wonder whether he sent it back to
Hahnemühle?
I worked in Photographic Paper manufacturing industry for 12 years
(until 1986).  This sort of damage is not unknown!
But, the paper is so good I still use it!!!
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Tyler Boley"
Hahnemühle's horrible packaging.
dealers.
> Ranting Tyler
