C82 or 870?
C82 or 870?
2003-11-06 by Antara Scales
Paul or------,
I have 870 with MIS VM, using Roark curves.. Am considering the
C82 after all the excitement here.  How would you compare the
two?
Also, is it possible to do the same or similar with the C80. The
black ink is the same as the C82, but the colors are different.
Antara
RE: [Digital BW] C82 or 870?
2003-11-06 by Paul Roark
Antara,
>How would you compare the two?
The 870 may be the better printer.  The UT inks, however, are better than
the VM inks in terms of longevity (and tones, in my view).  So, if the UT
inkset ran well with the curves and in your printer, there would not be much
reason to change.
The C82 is part of an effort to have a very affordable and easy archival B&W
printing solution -- for anyone.  For what it is and costs, it's doing a
very good job.  I'm putting the finishing touches on a neutral inkset now.
The weaknesses of the C82 are, first, that its dmax is a bit low.  With the
neutral inkset I'm seeing 1.58-9 on EEM and 1.59-60 on PhotoRag.
Second, of course, is that it, like the 870, cannot print larger than
letter-size paper.
Third, like all monotone inksets, the tones cannot be fine-tuned in the same
way the vm & UT inksets can.  And, of course, there is not ability to do
split-tone printing.
In the neutral inkset for the C82 I've compromised the neutral tone as
follows:  EEM is 0.01 cool, and PhotoRag is 0.01 warm at 50%.
On the other hand, the C82 has a unique trick here.  If the warm (UT light
C) ink is put in the yellow spot, EEM is then 0.01 units warm.  If a warm
ink cart is put in the magenta spot, EEM is then 0.04 units warm.  To switch
between these, in fact, I just swapped the yellow and magenta position
carts -- they are all interchangeable.  So, with 2 inks, much more fine
tuning is possible on the C82 than on most monotone inksets.
The forth weakness or quirk of the C82 is that the head often nicks the
bottom 3/16 inch of the paper.  So, there is sometimes if not often a little
ink on the bottom right corner.
I don't know how well the existing curves work on the 870 for the UT inks.
For PC users with 1270s the 1280 driver seems to work.  That way they can
use the 1280 UT curves.  If that approach works for the 870 and you, then it
might be worth trying a UT cart.
>Also, is it possible to do the same or similar with the C80. ...
I don't know.
http://www.PaulRoark.com
Re: [Digital BW] C82 or 870?
Thanks Paul for your full response.
On MIS website, I don't see that UT is available for the 870.
Guess they could "chip" it??
re the curves- I have used the curves for 1270 and 870 (my 1270
died recently). So I assume I could use the 1280 curves for 870.
Yes?
Do you know what the dmax is for EEM, UT and 1270/870?
Higher, I assume than the C82.
Didn't understand your explanation of EEM .01 warm and cool.
If you have time, could you please flesh that out a little more.
thanks,
Antara
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul
Roark" <paul.roark@v...> wrote:
> Antara,
better than
the UT
not be much
> reason to change.
archival B&W
doing a
inkset now.
With the
PhotoRag.
than
> letter-size paper.
in the same
ability to do
tone as
warm (UT light
a warm
warm.  To switch
position
more fine
nicks the
often a little
the UT inks.
way they can
and you, then it
> I don't know.
> Paul
Antara,
They must have the empty carts.  I wrote the VM curves for the 870 & 1270 on
a 870 -- filling empty carts from MIS with bulk VM ink.  So, it just means
you'll have to fill the carts.
The 1280 curves would work -- but work well only if you use the 1280 (or
equivalent letter-size printer) driver.
Eboni will hit about 1.66-7 most of the time.
Yes.
The spectrophotometer I have measures densities to 0.01 -- in each of the
cyan, magenta, and yellow channels, as well as a "visual" reading.  Neutral
is when c=m=y.  The "selenium" tone is when M is 0.01 above C&Y.  Cool tone
is when C exceeds Y. Warm is when Y exceeds C.  You can see a 0.01
difference in side-by-side comparisons.
So, I use these spectrophotometer readings to mix the inksets and make the
curves.  It's the most accurate way I know of to do this.
Hope this helps.
___________________________________________
> Antara,
better than
the UT
not be much
> reason to change.
archival B&W
doing a
inkset now.
With the
PhotoRag.
than
> letter-size paper.
in the same
ability to do
tone as
warm (UT light
a warm
warm.  To switch
position
more fine
nicks the
often a little
the UT inks.
way they can
and you, then it
> I don't know.
> Paul
page.
them short.
resources on the homepage.
