Having problems with Paul Roarks curve settings
2003-11-08 by dizzyashell2003
I have downloaded the profiles that Paul has on the MIS website for an Epson Photo
Stylus 1200. I'm using the variable Quadtone ink sets and have everything set up as
suggested by Paul's workflow. I have had nothing but horrid results. After the first
print hit the garbage can I loaded the curves back in and went into the individual
channels and looked at the way he has them bent. After looking at the individual
colors and how they are bent, I thought I had found the problem. I was having a
minor bit of solarization going on in mid-tones. So I took the pins out of the Blue
curve which were bent in a ridiculous manner which was causing the solarization. You
can't bend curves up and down in a sign wave type of manner and have your tones
come out without them being solorized. I can't see how anyone can have decent
results with these curve settings. My shadow area is not continuous; there are blotchy
spots through out the blacks, no continuous tones. It looks like someone took a felt
tip pen and made a bunch of dots to create the black area. I just can't see how these
curves were created and anyone have, like I said, good results. I'm professional color
technician and have been doing color for prepress for over 7 years and can't seem to
get this to work. If anyone has ANY advice on how these inks and how digital printing
with these inks and curve settings, please let me know how you accomplished this.
Everyone I have asked can't see how these curve settings can even come close to
giving good results. I have had everything set exactly as to Paul's workflow and just
can't seem to get it right. Conventional printing may be the road I travel again. This is
very counter-productive.
www.deanmbeattiephoto.com
Re: Having problems with Paul Roarks curve settings
2003-11-08 by sceptre12345
I've been using Paul's curves in a 1160 and getting pretty good
results, as good as if not better than what I was getting with the
PiezgraphyBW software. In fact I no longer see any banding with the
heavier weight paper.
Did you by any chance convert your grayscale image to RGB prior to
printing ?
And lastly, you might want to tone down your remarks a wee bit!
Andre
--- In
DigitalBlackandWhiteThePrint@yahoogroups.com, "dizzyashell2003"
an Epson Photo
the individual
the individual
was having a
out of the Blue
solarization. You
have your tones
have decent
someone took a felt
can't see how these
professional color
and can't seem to
accomplished this.
come close to
workflow and just
I mean no disrespect toward the work people have put into these curves. I am simply
not having the results that everyone is saying should be present when using the
workflow.
Yes I did convert to RGB. I'm not having any luck. I'm using  Epson Enhanced Matte
paper and having the blotches in the shadow area. My highlights and midtones are
smokin', but the rest is unfavorable.
-Dean
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "sceptre12345"
> printing ?
> Cheers,
> Andre
> --- In
> an Epson Photo
> the individual
> the individual
> was having a
> out of the Blue
> solarization. You
> have your tones
> have decent
> someone took a felt
> can't see how these
> professional color
> and can't seem to
> accomplished this.
> come close to
> workflow and just
2003-11-09 by markroth61
I also have an 1160, and you may find very satisfactory results not
using those curves, but instead creating a transfer function curve
(search here will yield the details). It makes all the difference.
The trick is an 11 step wedge to determine your tonal values.
I believe Paul's work is wonderful, but each specific printer seems
to be different in how it reacts, so there is no flat answer.
I'm getting terrific results using this method.
Best,
Mark R.
> printing ?
> Cheers,
> Andre
> --- In
for
> an Epson Photo
into
> the individual
> the individual
I
> was having a
pins
> out of the Blue
> solarization. You
> have your tones
> have decent
> someone took a felt
> can't see how these
I'm
> professional color
years
> and can't seem to
> accomplished this.
> come close to
Paul's
> workflow and just
I
2003-11-09 by PhotoWorkshops Partnership
On 9/11/03 2:20 am, "DigitalBlackandWhiteThePrint@yahoogroups.com"
> Photo Stylus 1200. I'm using the variable Quadtone ink sets and have
> everything set up as suggested by Paul's workflow. I have had nothing but
> horrid results. After the first print hit the garbage can I loaded the curves
> back in and went into the individual channels and looked at the way he has
> them bent. After looking at the individual colors and how they are bent, I
> thought I had found the problem. I was having a minor bit of solarization
> going on in mid-tones. So I took the pins out of the Blue curve which were
> bent in a ridiculous manner which was causing the solarization. You can't bend
> curves up and down in a sign wave type of manner and have your tones come out
> without them being solorized. I can't see how anyone can have decent results
> a felt tip pen and made a bunch of dots to create the black area. I just can't
> see how these curves were created and anyone have, like I said, good results.
> I'm professional color technician and have been doing color for prepress for
> over 7 years and can't seem to get this to work. If anyone has ANY advice on
> how these inks and how digital printing with these inks and curve settings,
> please let me know how you accomplished this. Everyone I have asked can't see
> how these curve settings can even come close to giving good results. I have
> had everything set exactly as to Paul's workflow and just can't seem to get it
> right. Conventional printing may be the road I travel again. This is very
> counter-productive.
I use an Epson 1200 with MIS inks (Permajet VTBlax) and can hopefully
comment on your problem. Don't attempt to tweak Paul's curves as they do
work fine - I understand where you are coming from saying 'you can't bend
curves up and down in a sine wave without solarisation' but that is not the
way to think of the individual ink curves - they are ink coverage for
particular tonal values and blend seamlessly with the ink coverage in other
channels. Forget Paul's curves for the moment.
I can repeat your problems if I either forget to assign and sRGB profile to
the greyscale image when I change to RFGB mode (I usually work in Adobe RGB
1998 for colour and get something like the problem you describe if I leave
the colour space set to this default). If you don't have the printer driver
colour adjustment set for Vivid you will also get weird areas of flat tone -
done this too.
The workflow is simple but every step needs remembering.
Greyscale (get the image as you want it)
Convert to RGB mode
Assign sRGB profile
Use Curves to load appropriate Roark curve (screen image from this time on
tells you nothing as it is false coloured)
Send job to printer choosing 1440dpi, Photo Quality inkjet paper, Colour
control Vivid
I made up a sample file with four copies of a well-toned image and four
21-step wedges and applied one each of the Roark curves to the four images.
The first time I printed this and got all the variable tones with full
separation on the 21-step wedges I knew I was doing things right.
David Prakel
Centre of Britain PhotoWorkshops Partnership
www.photopartners.co.uk
Minor Clarification Needed on use of UT Curves
2003-11-18 by Keith Hollister
I've been lurking for a while and finally ordered the MIS UT carts for
my 1280. Paul's workflow seems pretty clear, although I would like to
verify the color space settings. I understand that I need to convert
the RGB image to AdobeRGB (which will become the source colorspace),
and I'm assuming that I should select "Same As Source" for the output
colorspace since the printer driver is run NCA?
I also gather that while I do not need to flush the heads, it is
recommended that I clean the parking pads? I downloaded the purge
patterns from MIS to use to clean out the traces of the Epson dyes.
And finally, are the curves on the MIS workflow page and the ones from
the Files section here the same? Which are the latest, if not?
Thanks
Keith Hollister
Orlando, FL
Re: Minor Clarification Needed on use of UT Curves
2003-11-18 by Bob Michaels
Keith: I'd download the files from MIS as you KNOW they are the most
current. I believe RGB and Adobe RGB are the same. Someone will
correct me if I'm wrong.
Alex Pettit from this list lives in Winter Park and I'm in Apopka. I'm
always taking a class at Crealde School of Art in Winter Park if you
happen to be there as well. Let either of us know if you want to
compare prints. I use 1280, Alex a 2000 & a 3000.
Bob Michaels
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Keith Hollister
> Thanks
> Keith Hollister
> Orlando, FL
