Re: Re[2]: [Digital BW] Banding on a scanner
2003-11-30 by daschkenas@aol.com
No banding on the negs, also I have made gelatin silver prints in a wet darkroom that look fine. David Aschkenas
2003-11-30 by Daniel Staver
> No banding on the negs, also I have made gelatin silver > prints in a wet darkroom that look fine. David Aschkenas I get banding in the light sky areas of my 6x7 transparencies scanned with the Epson 3200. I had the same problem, but even worse, with my previous CanoScan 9900f, and returned it for that reason. Does it by any chance look something like this? http://download.petraflux.com/img/streaks2.jpg -- Daniel Staver http://daniel.staver.no
Daniel, it looks a bit like that, but no actual lines, just slight undulations (banding ) in certain sky areas. Not thru the entire image. David Aschkenas
> Daniel, it looks a bit like that, but no actual lines, just > slight undulations (banding ) in certain sky areas. Not > thru the entire image. David Aschkenas I'm just wondering if it's a limitation of flatbed scanners in general since I had the same problem with both the 9900 and the 3200... -- Daniel Staver http://daniel.staver.no
2003-11-30 by Carl Schofield
Daniel, I've recently started scanning Polaroid type 55 negs using an Epson 3200 with Vuescan and have not seen the banding you described. Carl Schofield
On Sunday, November 30, 2003, at 11:53 AM, Daniel Staver wrote: >> Daniel, it looks a bit like that, but no actual lines, just >> slight undulations (banding ) in certain sky areas. Not >> thru the entire image. David Aschkenas > > I'm just wondering if it's a limitation of flatbed scanners in general > since I had the same problem with both the 9900 and the 3200... > > -- > Daniel Staver > http://daniel.staver.no > > > > > ------------------------ Yahoo! Groups Sponsor > ---------------------~--> > Buy Ink Cartridges or Refill Kits for your HP, Epson, Canon or Lexmark > Printer at MyInks.com. Free s/h on orders $50 or more to the US & > Canada. > http://www.c1tracking.com/l.asp?cid=5511 > http://us.click.yahoo.com/mOAaAA/3exGAA/qnsNAA/ucIolB/TM > --------------------------------------------------------------------- > ~-> > > Please visit the Group Homepage to check the Files, Bookmarks, Polls > and other resources as they are often being updated. The page is at: > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > > If you wish to receive no emails or just a daily digest, or you wish > to unsubscribe, please edit your Membership preferences by visiting > this same page. > > Please follow these basic guidelines: > - Include your full name with your message. > - Include the address of your website, if you have one. > - As threads develop, trim off excess portions of earlier messages to > keep them short. > - As the topic of a thread changes remember to change the subject > header. > - Good manners are required at all time. No personal attacks or flames > - Complete your Yahoo profile. > - Before posting a question, search the message archives and the > various resources on the homepage. > > > > > Your use of Yahoo! Groups is subject to > http://docs.yahoo.com/info/terms/ > >
> I've recently started scanning Polaroid type 55 negs using an Epson > 3200 with Vuescan and have not seen the banding you described. The example was from the 9900 that I returned, with the 3200 it's less pronounced. Here's one I just made from the 3200: Converted to grayscale and increased contrast: http://daniel.staver.no/img/3200.jpg Original: http://daniel.staver.no/img/3200_2.jpg You'll see that the BW version has vertical banding in the sky, while it's not easily visible in the original. Rotating the transparency 90 degrees on a scanner makes the problem even less visible. -- Daniel Staver http://daniel.staver.no
Daniel, I'm scanning in 16 bit greyscale, so don't know if that makes a difference or not. Here is an example from a type 55 negative, scanned at 1200 dpi (select the large image size for better detail): http://www.schophoto.com/gallery/photo.php?photo=553&lang=eng The large image was reduced in size from the original scan, which was 5400x4179 pixels. Carl Schofield
On Sunday, November 30, 2003, at 01:25 PM, Daniel Staver wrote: >> I've recently started scanning Polaroid type 55 negs using an Epson >> 3200 with Vuescan and have not seen the banding you described. > > The example was from the 9900 that I returned, with the 3200 it's less > pronounced. Here's one I just made from the 3200: > > Converted to grayscale and increased contrast: > http://daniel.staver.no/img/3200.jpg > > Original: > http://daniel.staver.no/img/3200_2.jpg > > You'll see that the BW version has vertical banding in the sky, while > it's not easily visible in the original. > > Rotating the transparency 90 degrees on a scanner makes the problem > even > less visible. > > -- > Daniel Staver > http://daniel.staver.no > > > > > ------------------------ Yahoo! Groups Sponsor > ---------------------~--> > Buy Ink Cartridges or Refill Kits for your HP, Epson, Canon or Lexmark > Printer at MyInks.com. Free s/h on orders $50 or more to the US & > Canada. > http://www.c1tracking.com/l.asp?cid=5511 > http://us.click.yahoo.com/mOAaAA/3exGAA/qnsNAA/ucIolB/TM > --------------------------------------------------------------------- > ~-> > > Please visit the Group Homepage to check the Files, Bookmarks, Polls > and other resources as they are often being updated. The page is at: > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > > If you wish to receive no emails or just a daily digest, or you wish > to unsubscribe, please edit your Membership preferences by visiting > this same page. > > Please follow these basic guidelines: > - Include your full name with your message. > - Include the address of your website, if you have one. > - As threads develop, trim off excess portions of earlier messages to > keep them short. > - As the topic of a thread changes remember to change the subject > header. > - Good manners are required at all time. No personal attacks or flames > - Complete your Yahoo profile. > - Before posting a question, search the message archives and the > various resources on the homepage. > > > > > Your use of Yahoo! Groups is subject to > http://docs.yahoo.com/info/terms/ > >
They are not newton's rings, I know what they look like, and this is definitely banding. Also, keep in mind that this is a 20K scanner, not a consumer item. David Aschkenas
2003-12-01 by daschkenas@aol.com
I will try the 90 degree rotation, but since its a friends scanner, I'm not sure when I'll be able to test it. David Aschkenas
2003-12-01 by Alan Zinn
At 05:53 PM 11/30/03 +0100, you wrote: > > Daniel, it looks a bit like that, but no actual lines, just > > slight undulations (banding ) in certain sky areas. Not > > thru the entire image. David Aschkenas > >I'm just wondering if it's a limitation of flatbed scanners in general >since I had the same problem with both the 9900 and the 3200... > >-- >Daniel Staver >http://daniel.staver.no Daniel, I've never seen banding using my 3200 on color and b/w pan negs. Are they are consistent or random bands? Do you hear uneven noise while scanning? Try scanning plain white paper and then checking it in PS Threshold. AZ > >Please visit the Group Homepage to check the Files, Bookmarks, Polls and >other resources as they are often being updated. The page is at: > >http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > >If you wish to receive no emails or just a daily digest, or you wish to >unsubscribe, please edit your Membership preferences by visiting this same >page. > >Please follow these basic guidelines: >- Include your full name with your message. >- Include the address of your website, if you have one. >- As threads develop, trim off excess portions of earlier messages to keep >them short. >- As the topic of a thread changes remember to change the subject header. >- Good manners are required at all time. No personal attacks or flames >- Complete your Yahoo profile. >- Before posting a question, search the message archives and the various >resources on the homepage. > > > > >Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ Build a Lookaround! The Lookaround Book, 2nd ed. NOW SHIPPING http://www.panoramacamera.us
At 07:25 PM 11/30/03 +0100, you wrote: > > I've recently started scanning Polaroid type 55 negs using an Epson > > 3200 with Vuescan and have not seen the banding you described. > >The example was from the 9900 that I returned, with the 3200 it's less >pronounced. Here's one I just made from the 3200: > >Converted to grayscale and increased contrast: >http://daniel.staver.no/img/3200.jpg > >Original: >http://daniel.staver.no/img/3200_2.jpg > >You'll see that the BW version has vertical banding in the sky, while >it's not easily visible in the original. > >Rotating the transparency 90 degrees on a scanner makes the problem even >less visible. > >-- >Daniel Staver >http://daniel.staver.no I don't see the bands - can you describe them? location, frequency, etc? AZ Build a Lookaround! The Lookaround Book, 2nd ed. NOW SHIPPING http://www.panoramacamera.us
