> Manuel,
> Some background information on the Epson ink monitor that may help
> reduce confusion.
> If you pop the chip off an Epson ink cartridge you'll only see a
> little blob of epoxy. There are no wires or no sensors into the ink
> well. The chip is used as a scratch pad by the Epson driver to
> subtract the amount of ink that it estimates has been used, picoliter
> by picoliter. You'll also notice that for the multi-color cartridges
> the ink wells all drop uniformly. I believe the Epson driver is
> subtracting the worst case amount. [I have an epson 2200 and I find
> it amazing how vastly different the color consumption is for the
> different colors. I was surprised to see that Lite Magenta and Lite
> Cyan are most heavily used with Yellow being the slowest.]
> There's a device which will reset the ink chips back to full to fool
> the ink monitor so it will continue to work. There are also chips
> that reset themselves when the power is turned off the printer.
> Bottom line: You have to take with a grain of salt what the ink
> monitor is estimating as the ink level. It does not necessarily
> reflect reality.
> I recently bought an Epson 1280 dedicated to black only printing.
> Following Paul Roark's recommendation, I started off with the UT inks
> in Epson-replacement cartridges to try it out. I liked them so I
> ordered the CIS cartridges and UT ink bottles.
> [I encountered a problem: the chips on the CIS cartridge were not
> resetting on power down. MIS sent me new chips (pink substrate) that
> worked fine. The non-resetting chips were on a green substrate.]
> Your note does not state which printer and MIS cartridges you are
> using.
> When I spoke to Bob Zeiger at MIS, he said that the two cartridges
> are different. The CIS cartridges are simpler and depend on creating
> an air bubble at the top to regulate ink flow.
> The Epson-replacement cartridges have a more convoluted path to
> regulate flow and deter people from refilling them. It's more
> difficult to force ink back into these, since the air vent is used to
> limit air intake.
> There's a guy in Hong Kong, Kui, that's analyzed Epson cartridges:
> http://www.digital4to.com/
> click on Introduction. This gave me a better way to visualize what's
> going on.
> It also helped me to conclude that I was better off using cartridges
> that were engineered for continuos refilling. It's just easier to go
> with the flow.
> Hope this is useful.
> Lincoln Fajardo
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Johnny Eades"
> <jeades1@s...> wrote:
> > Hello Manuel,
> > It may not be the ink getting low, but the cartridge could have a
> > buildup of foam so that when you filled the first refill and the
> ink
> > flowed out the vent hole appearing to be full, it was really not
> > full. The overflow was foam buildup. Every other refill I always
> use
> > a large syringe and tape over the vent holes and draw out all the
> > foam and ink inside the chamber before refilling.
> > Your friend in Photography,
> > Johnny Eades
> > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Manuel Toledo
> > <mtoledo@e...> wrote:
> > > Hello,
> > > I have a problem with a MIS cartridge that I am using with the UT
> > > inkset. The ink monitor tells me that the inks are 80% full, but
> a
> > > nozzle check shows no lines in the yellow position. I replaced
> the
> > > cardritge with an Epson original and noticed that the MIS
> cartridge
> > is
> > > very light. All colors are fine with the Epson cartridge. I think
> > that
> > > in the MIS cartridge the yellow-position is empty and the others
> > are
> > > running low!
> > > I refilled the cardridge a couple of weeks ago. Prior to that,
> when
> > it
> > > was in the printer, the ink monitor was showing about 10%-20% ink
> > for
> > > all colors, but I started to get bad nozzle checks that were
> > getting
> > > worse (fast) with cleaning. Originally I thought that it was
> > clocking.
> > > However, before refilling I extracted the remaining ink from the
> > > cartridge. There was very little of it. So I thought that it was
> > just
> > > that the sensors where not reliable and that my bad nozzle checks
> > were
> > > due to insufficent ink in the cartridge.
> > > However, now the cartridge seems to be empty again! Only about
> two
> > weeks
> > > after reffiling the! During this time I think I have printed the
> > > equivalent of perhaps four 13x19in. pages only.
> > > Can someone tell me if the capacity of these cartridges is this
> > low? Or
> > > perhaps the one I have is defective and should be replaced? I
> > refilled
> > > it once after filling it the first time.
> > > Thanks in advance!
> > > Your friend in photography,
> > > Manuel Toledo
