Paul, thanks. I'll give that a try after dinner.
Bob
<paul.roark@v...> wrote:
> Bob,
> >Since swapping my FNS-E inks (John Woolfe workflow) for UT in my 1280
> >and Paul's workflow, my prints are far from what I see on the screen
> >like they used to be. Prints are now much lighter on EEM. ...
> Different workflows can have very different gammas or midtone
densities. I
> have used the midtone density target that I was getting with my 1160
and the
> Piezo driver several years ago. I wanted my files to print the same
on the
> various inksets I was using.
> I'm not sure what Woolfe used as his target midtone density.
> As far as color settings are concerned, I set the Edit, Color
Settings top
> line (overall settings) first to Photoshop 5 default settings. Then I
> switch the RGB to AdobeRGB(1998).
> In the print driver the most important setting in Color Management
is "No
> Color Adjustment."
> I use the Photoshop Preview function to match the monitor image to the
> print.
> Here is the procedure I use (which I first saw explained on the
Piezo list
> by Tyler):
> 1. Open the file that has a good range of tones and that you have
> printed with the printer & inkset you want to match. I like to use the
> 21-step test file.
> 2. Go to Image, Mode, and Assign Profile. Check, "Don't Color Manage
> This Document," and hit OK.
> 3. Go to Edit, Color settings. A "Color Settings" box should appear.
> Move it down so that you can get to the top of it, but so that it
does not
> cover your image. Check "Advanced Mode" and "Preview." In the "Working
> spaces" box, scroll "Gray" line up to "custom Dot Gain." A curves box
> should appear.
> 4. This is the curve that allows you to adjust the image on the
> monitor. The idea, of course, is to match image on the monitor to
the print
> of the image that you've already made. After you have matched the
two, name
> the curve in the space at the top of the box and hit OK. The curves box
> disappears, and you now see the name you just selected in the "Gray"
Working
> Space line of the Color Settings box.
> 5. Click on this new name in the "Gray" line. Scroll up to and click
> on "Save gray." Save it as an .icc file.
> 6. In the "Color settings" box, which should still be open, hit
> "Cancel." This will leave all of your working spaces as they were
before.
> 7. Now you are back at the image file you had originally opened. Go to
> View, Proof Setup, Custom. The new curve you made should be in the
list,
> probably at the bottom - Select it. Then check "Preserve Color
Numbers."
> The image on the monitor should then look like it did while you were
making
> the curve. Hit OK.
> You can also record a Photoshop "Action" so that the preview/monitor
> profiling steps become a simple, single-keystroke function (for example,
> function key 2 on a PC can be designated to apply the preview). (To
record
> an Action, click the Actions pallet tab, click the upper right
arrow, start
> recording, select the function key, hit View, Proof Setup, etc. as
above,
> then click the Actions pallet upper right arrow and stop recording.)
> Paul
> http://www.PaulRoark.com
