2200: Making Grayscale Pigment Prints
2003-12-10 by Joe Davajon
I posted the procedure recently posted to this group a couple of hours ago.  I
had not personally used the procedure but there seemed to be interest  in it,
so I described the method.  Since then, I have made several B@W prints and
would like to share my observations.
I  was hopeful but my experience demonstrates this is not the perfect solution.
I use several printers and tried this on my 2200 using OEM cartridges with the
matte black.  Here is what I have (unscientifically) found.  The metamerism is
most definitely still there.  Under tungsten lighting you can see it clearly see a
majenta cast although it isn't pronounced.  But it's there.  Under daylight
florescent daylight lighting the slight majenta tone disappears and the print is
fully acceptable with no blocking of highlights and good shadow separation.
Tonal range is, to my eye excellent.  In conclusion, if you display under
daylight lighting, you'll find this method very acceptable.  Unfortunately that
isn't the case with most of us who display under various lighting conditions.
Finally, my usual printing of B@W is using the 1280 and MIS Ultra-Tone Hex
inks which I have found does not my prints to suffer from metamerism (of
course) and produces very pleasing prints.  This causes me to decidedly
agree with those persons who argue that one must have more than one
printer and dedicate one for B@W only.  This IS expensive.  But, what if
Michaelangelo, De Vinci, or Van Gough had worried about the expense of
their mediums?  Friends, the piper must have his pay.
Many thanks for all the unselfish effort put forth to help each other.  I think this
is a great forum and the occasional lapses in good manners I just ignor.
Joe D.
Re: 2200: Making Grayscale Pigment Prints
2003-12-10 by Jesus RV
I assume al this procedure involves the matte black cartridge, not the so-called photo
black one. Is that right, or it is mostly indifferent?
Thank you
J
