8 bit color -> 16 bit grayscale conversion
2003-12-12 by Manuel Toledo Quinones
Usually shoots digital raw to preserve 16 bits per channel and avoid
deterioration when processing the images. However, it occurs to me
that if one is shooting color with 8 bits/channel, there are already
24 bits of information. If the image is then converted to 16 bit
grayscale mode, all bits contain information and there should be no
empty bins in the histogram due to lack of intensity resolution. The
quality of the 16 bit image should be adequate to tolerate processing.
Have anyone tested this? Any ideas?
Manuel Toledo
RE: [Digital BW] 8 bit color -> 16 bit grayscale conversion
2003-12-12 by Paul D. DeRocco
> From: Manuel Toledo Quinones [mailto:mtoledo@...]
Not true. With three channels of 8 bits, that's roughly equal to 9.5 bits,
because the maximum value you can get by adding three 255's together is 765,
which takes about 9.5 bits to represent.
2003-12-12 by Tom Baker
If one were 'adding' the values together, you'd be on the right track.  However, it is per color channel that these values are applied.  So, 8 bits is 256 values per channel.  However, if you have a value of 220 in a channel and convert it to 16bit, you still don't have any more real data than you did before.  You only have a 16 bit value with the same real value.
Tom Baker
Yahoo! Groups SponsorADVERTISEMENT
- By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See �Group Topic, Rules and Guidelines� in the Files section:
BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE �OWNER� AND �MODERATORS� OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  �OWNER� AND �MODERATORS� OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
> From: Tom Baker [mailto:tbaker1328@...]
From a strictly numeric point of view, eight bits is eight bits. The
original poster thought he could somehow get 24 bits of "resolution". My
point was that you do indeed get a little bit more resolution, perceptually,
because the amount of quantization noise you perceive in an 8bpc color image
is probably better than a 9-bit B&W image, for the reason I explained. A
more extreme example of this is that an inkjet print, even a B&W one, made
with color inks will have less visible noise than a black ink only print,
even though each ink "channel" is still only one bit.
