RC Papers, Print Spray and Bronzing: what am I looking for?
2003-12-13 by Steve Kale
This may be a dumb question but I will ask it anyway.  Having read all the discussion
about RC papers and the potential of Epson Premium Semi-Gloss I decided to do a
test of my own.  Using Epson UC inks, I printed an image using QTR on EEM using
Carl's EEM curves 50:50 warm/cool.  I then printed it twice on Prem Semi-Gloss using
Carl's curves for Oriental FB, again 50:50 - admittedly this is not perfect but I do not
have curves for Premium Semi-Gloss.   One of the Semi-Gloss prints I sprayed with
Lyson Print Guard - 3 generous coats with drying time between each.
What is bronzing, ie what differences should I see?  Here is what I see... The Premium
Semi-Gloss prints are decidedly _warmer_, if that is the right term, than the EEM print
which I would consider neutral, ie they exhibit a slight brownish tone (looked at from
directly above).  I assume this is simply because I have not used a consistent paper/
curve combination although I am surprised that the difference (OFB vs PSG) is as
significant as it is.  I thought that _bronzing_ is the effect that occurs when the prints
catch light (ie viewed at an angle) and the image tends to look metallic and begins to
disappear.  I quite frankly can't see the difference between the sprayed and the
unsprayed Semi-Gloss prints in this regard.  What should I be looking for?
Finally, I admit the RC images initially pack an optical punch but there is something
almost more 3 dimensional about the matt one.  Obviously a question of taste but I
wonder if the so-called _search for the Holy Grail_ is perhaps a little biased by
historical restrictions.  As you can tell, I have no history in the darkroom and so I am
much less interested in replicating a historical precedent.
Steve
RE: [Digital BW] RC Papers, Print Spray and Bronzing: what am I looking for?
2003-12-14 by Paul Roark
Steve,
>... One of the Semi-Gloss prints I sprayed with
>What is bronzing, ie what differences should I see...
>catch light (i.e. viewed at an angle) and the image tends to look
>metallic and begins to disappear.
With the UT inks, I see a warm "bronze" reflection in the shadows, peaking
at about 70%.  Also, there is a reduction of the gloss level at 90 and 95%,
but then the 100% is quite glossy.
A couple factors come to mind.  First, while the PremierArt and Lyson sprays
appear to be the same, there could be minor differences.  The only test
strip that I sprayed with Lyson did not show as much reduction in bronzing
as the PremierArt test strip.  I thought this was just inconsistent
techniques, but maybe not.  I'll try to do a more controlled test when I
have more paper.
Second, of course, the Epson UC inks may be different than the MIS UT inks
in their bronzing.  However, I've heard fans of the semi-matte say how
wonderful it is with UC inks -- except for the bronzing.  So, I think it is
there.
Third, I was showing samples in an area that had windows on 3 sides and lots
of natural light flooding the room.  It was hard to see any differences in
that light.  So lighting may be a factor.  In my office, where I have
fluorescent lights, the bronze nearly fluoresces.  So, maybe the types of
lights are also a factor.
Re: [Digital BW] RC Papers, Print Spray and Bronzing: what am I looking for?
2003-12-14 by Carl Schofield
I haven't tried Epson semi-gloss yet, but with Ilford Smooth Pearl and
similar RC papers I've tried bronzing is very evident.  Tilting the
paper back and forth under a light you should see a reflective,
metallic bronze tone at certain angles - particularly in the mid-tones.
  There could also be some gloss differential between paper white areas
and ink covered areas.  The brown color is from the PK and LK inks,
which are difficult to cool down on most RC papers.  You could try
using a much higher cool/warm ratio, but a profile made specifically
for this paper would probably be better.
Carl
> the discussion
> decided to do a
> EEM using
> Semi-Gloss using
> sprayed with
> see... The Premium
> than the EEM print
> (looked at from
> consistent paper/
> PSG) is as
> sprayed and the
> for?
> there is something
> taste but I
> little biased by
> Steve
2003-12-14 by Steve Kale
Thanks for this.  I would be very interested in any further Lyson vs
PremierArt testing you do because of the lack of availability of the
PremierArt product here.  I am looking at these prints under halogen
lighting (ceiling recessed spots) - I will check again in daylight in the
tomorrow.  Unfortunately I don¹t yet have the luxury of switching to the UT
inks for a test.  I assume your tests were using the quad UTs rather than
what I think I would initially have to look at ­ the colour UTs.  I am
aiming for an Epson 4000 but can¹t justify two of them ­ and I know that
somehow once I get the bigger size the thought of only being able to print
B&W on the smaller (albeit B&W-dedicated) 2100 won¹t appeal.   I would be
interested if anyone can test the bronzing issue with the UC vs UT (colour
set) inks.
Steve
Reply-To: DigitalBlackandWhiteThePrint@yahoogroups.com
Date: Sat, 13 Dec 2003 16:45:25 -0800
Subject: RE: [Digital BW] RC Papers, Print Spray and Bronzing:  what am I
looking for?
Steve,
have more paper.
there.
Thanks.  I was hoping that the spray (in the belief that the Lyson product
could well be the same as the PremierArt product) would act as a cure-all
for RC prints as Paul seemed to be having quite some success with it.  Have
you tried spraying your UC/RC prints with this? Perhaps it is the MIS
Ultratones that are making the real difference...
Steve
Date: Sat, 13 Dec 2003 19:54:35 -0500
Subject: Re: [Digital BW] RC Papers, Print Spray and Bronzing:  what am I
looking for?
Carl
I've used both the UC and UT inks in a 2200 and both inksets seem to
exhibit about the same level of bronzing on most RC papers I've used.
The only spray treatment I've tried so far has been Kamar Varnish,
which does reduce the bronzing, but I didn't like the appearance of the
surface after spraying.  I'm going to try the epson semi-gloss and
PremierArt spray next week with the UC inks and also see what it does
for BO printing on RC papers.  I tried printing just Eboni on some
PermaJet Oyster 271 (a semi-matte RC) and had some promising results
after spraying with Kamar.  The dmax went from about 1.51 before
spraying to 2.17 after spraying with beautiful blacks and a dead
neutral tonal scale.  Eboni is of course not designed for use with RC
papers and it will rub off easily without treatment, but after the
Kamar spray the surface is very durable.  Problem is that it is very
difficult (at least for me) to get an even coating with the Kamar and
it is gritty if you don't put enough coats on.
Carl
> product
> cure-all
> Have
> Steve
> From: Carl Schofield <scho@...>
> am I
> looking for?
> Carl
> Buy Ink Cartridges or Refill Kits for your HP, Epson, Canon or Lexmark
> Printer at MyInks.com. Free s/h on orders $50 or more to the US &
> Canada.
> http://www.c1tracking.com/l.asp?cid=5511
> http://us.click.yahoo.com/mOAaAA/3exGAA/qnsNAA/ucIolB/TM
> If you wish to receive no emails or just a daily digest, or you wish
> this same page.
> - As threads develop, trim off excess portions of earlier messages to
> keep them short.
> flames. Hostile, aggressive or argumentative users may be removed from
> the membership without notice.
> - Keep your posts and threads related to the group topic of digital
> B&W printing. Users who persistently make off-topic posts may be
> removed from the membership.
> guidelines, and to abide by the actions and decisions of the group
> Owner and Moderators. See „Group Topic, Rules and Guidelines‰ in the
> Files section:
> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE
> PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE „OWNER‰
> AND „MODERATORS‰ OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE
> LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
> CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO,
> DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE
> LOSSES (EVEN IF THE  „OWNER‰ AND „MODERATORS‰ OF DIGITAL BW, THE PRINT
> YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES),
> RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW,
> THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF
> YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD
> PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER
> MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
> Your use of Yahoo! Groups is subject to
I look forward to the results of your testing.  I am surprised that Mitch
describes the bronzing he is getting with Epson semi-gloss and UC inks as
_slight_.  I think I would describe what I am seeing as severe - although I
am worried that the fact that I don't have a dead neutral print to begin
with may be slanting the results.  The Lyson Print Guard significantly
improves the protection.  After 12+ hours of drying the surface of the
unsprayed print is still easily smudged with a rub of the finger whereas the
sprayed one is not.  The surface of each look very similar but feel quite
different - the sprayed print no longer has the _stickiness_ of the original
RC paper.
Steve
> Date: Sat, 13 Dec 2003 21:04:48 -0500
> looking for?
> Carl
>> product
>> cure-all
>> Have
>> Steve
2003-12-14 by Dan Honemann
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Steve Kale
<stevekale@b...> wrote:
> I am surprised that Mitch describes the bronzing he is getting with
> Epson semi-gloss and UC inks as _slight_.  I think I would describe
> what I am seeing as severe [...]
I would label mine severe as well; I would certainly not feel
comfortable exhibiting or selling the prints I've made on Epson
professional semi-gloss using UC inks.
I'm eager to try out the PremiereArt Print Shield spray to see how
well it ameliorates the problem.  Paul's comments have given me new
hope that I won't have to give away my Premium Luster and Semi-gloss
papers after all.
Dan
If PremierArt Print Shield is the same as Lyson Print Guard I suspect you
may be disappointed ­ I for one am now hoping that they are indeed different
products.  It would be nice to have a simple cure for bronzing.  Given Paul
was using UT (quad?) inks rather than UC, I would also like to hear from
anyone using the MIS colour UT inks, Epson Semi Gloss and PremierArt Print
Shield (or Lyson).  Carl is going to do some testing soon.  If it is indeed
a benefit of the UT inks I will be making a very fast switch to an MIS UT
CFS.
Steve
Date: Sun, 14 Dec 2003 14:43:42 -0000
looking for?
papers after all.
Dan
Re: RC Papers, Print Spray and Bronzing: what am I looking for?
2003-12-14 by Mitch Alland
For: Steve Kale
> what I am seeing as severe - although I am worried that the fact that
> I don't have a dead neutral print to begin with may be slanting the
> results.
I am printing on Epson Semi-Matte, not Semi-Gloss, with
ImagePrint...and the bronzing is slight but still unacceptable.
--Mitch/Bangkok
Re: [Digital BW] Re: RC Papers, Print Spray and Bronzing: what am I looking for?
2003-12-14 by Tom Baker
Mitch  -
I've got a roll of that coming this week.  Before I go to the expense of switching over from matte to photo on the 9600, I'd like to see if someone has actually sprayed SemiMatte/UC Photo Black prints with Print Shield.  Have you done it yet?
Tom Baker
Mitch Alland <malland@...> wrote:
For: Steve Kale
> results.
--Mitch/Bangkok
Yahoo! Groups SponsorADVERTISEMENT
- By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See �Group Topic, Rules and Guidelines� in the Files section:
BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE �OWNER� AND �MODERATORS� OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  �OWNER� AND �MODERATORS� OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
2003-12-15 by Steve Kale
Tom
In his earlier post Mitch said:
>>I'm eager to try the type of spray that you are trying but have no idea of
>>whether I can get it here in Bangkok. Do you or anyone else have any
>>idea how I can find out whether it's sold here?
so I suspect the answer in no.  I have sprayed Semi-gloss with the Lyson product and
seen little improvement.  Hopefully the products are indeed different or the results
Paul sees are due to the UT inks.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Tom Baker
<tbaker1328@s...> wrote:
> Mitch  -
> Tom Baker
2003-12-15 by alland20854
Tom:
SemiMatte/UC Photo Black prints with Print Shield.  Have you done it yet?<<<
Unfortunately not because I don't know whether or where I can get this spray here in
Bangkok.
--Mitch/Bangkok
2003-12-17 by elixirs4me@yahoo.com
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Carl Schofield
to
used.
does
> af Problem is that it is very
and
Carl,
I would like to try using this for BO printing myself as I have just
received some Perma Jet Oyster 271 and an Eboni Cartridge for my 2200.
 BUT, what paper setting do you use for this? The only options I see
are Enhanced Matte, Radiant Watercolor, and Velvet fine art.  Help!!!!
;-) I'm sorry in advance if this is something obvious. Since I don't
have Kamar Varnish I am going to try the Prismacolor stuff or Winsor
and Newton Gloss Acrylic.
Ol' Don in Broken Arrow
2003-12-17 by Carl Schofield
Actually, I cheated and swapped a chip from a PK cartridge onto the
Eboni cart which gave me access to more paper settings.  I had to do
this because the Eboni cart was from the UT -2200 inkset and was
chipped for the LK position.  I used the semi-gloss paper setting, but
I think it probably doesn't matter too much which setting you use
because the ink is going to sit on top of the paper anyway.  Just be
careful handling the print before it is sprayed as the ink will easily
rub off.
  Wednesday, December 17, 2003, at 04:55  PM, elixirs4me@... wrote:
> Carl,
