which way should I go?
2003-12-29 by bjornaagedk
- to get the best possible B&W digital prints? ImagePrint RIP + Epson 1290 + UltraTone inks or ImagePrint RIP + Epson 2200 + Epson UltraChrome inks or The (free) QuadTone RIP + Epson 1160 + Quad Inks (which ink set?) --- Any suggestions? Bjorn
2003-12-29 by Jake Hellbach
If you use the 2200 with ultrachrome inks you will need the RIP to get decent b/w prints. If you use the Ultratone or Quad inks, you don't need a RIP, just use the workflow and curves that are supplied from Paul Roark. Personally, I use my 2200 for color and a 1270 with MIS b/w inkset for black and white. Jake Jake Hellbach Photography www.jakehellbachphoto.com
-----Original Message----- From: bjornaagedk [mailto:reklamefoto@...] - to get the best possible B&W digital prints? ImagePrint RIP + Epson 1290 + UltraTone inks or ImagePrint RIP + Epson 2200 + Epson UltraChrome inks or The (free) QuadTone RIP + Epson 1160 + Quad Inks (which ink set?) --- Any suggestions? [Non-text portions of this message have been removed]
2003-12-29 by Stan McQueen
At 01:48 PM 12/29/2003, you wrote: > The (free) QuadTone RIP + Epson 1160 + Quad Inks (which ink set?) Lately, I've been using the 2200 with Ultrachrome inks and the QuadTone RIP and I'm getting very nice b&w prints with tones varying from cool to warm with no (or at least extremely little) metamerism. Stan ================================ Photography by Stan McQueen http://www.smcqueen.com
2003-12-29 by Alan.Huntley@cox.net
Bjorn, If you're considering IP, I would highly recommend the 2200 over the 1290. The addition of Light Black provides smoother transitions. Roy has done a tremendous job with his QuadToneRIP, however, it relies on GIMP drivers which, in my experience using QTR/GIMP with my 1160, is EXTREMELY slow; about 45 minutes to run an A3 size image. But, you can't beat the price--FREE--and, I believe, Carl S. has curves that utilize the standard UC inkset. Good luck, Alan Huntley
> > From: "bjornaagedk" <reklamefoto@...> > Date: 2003/12/29 Mon PM 03:35:25 EST > To: DigitalBlackandWhiteThePrint@yahoogroups.com > Subject: [Digital BW] which way should I go? > > - to get the best possible B&W digital prints? > > ImagePrint RIP + Epson 1290 + UltraTone inks > > or > > ImagePrint RIP + Epson 2200 + Epson UltraChrome inks > > or > > The (free) QuadTone RIP + Epson 1160 + Quad Inks (which ink set?)
I know the results from the Imageprint/Epson 2200 combination. But it has only the black and the photo black to mix. Will I get a better result if I use a dedicated b&w printer with f.ex. a MIS quad inkset (4 or 6 shades of gray) in combination with a workflow or a RIP? Imageprint (Colorbyte) has profiles for a lot of ink/paper combinations. Bjorn --- In DigitalBlackandWhiteThePrint@yahoogroups.com, <Alan.Huntley@c...> wrote: > Bjorn, > > If you're considering IP, I would highly recommend the 2200 over the 1290. The addition of Light Black provides smoother transitions. Roy has done a tremendous job with his QuadToneRIP, however, it relies on GIMP drivers which, in my experience using QTR/GIMP with my 1160, is EXTREMELY slow; about 45 minutes to run an A3 size image. But, you can't beat the price--FREE--and, I believe, Carl S. has curves that utilize the standard UC inkset.
> > Good luck, > Alan Huntley > > > > > From: "bjornaagedk" <reklamefoto@m...> > > Date: 2003/12/29 Mon PM 03:35:25 EST > > To: DigitalBlackandWhiteThePrint@yahoogroups.com > > Subject: [Digital BW] which way should I go? > > > > - to get the best possible B&W digital prints? > > > > ImagePrint RIP + Epson 1290 + UltraTone inks > > > > or > > > > ImagePrint RIP + Epson 2200 + Epson UltraChrome inks > > > > or > > > > The (free) QuadTone RIP + Epson 1160 + Quad Inks (which ink set?)
2003-12-30 by Paul D. DeRocco
> From: bjornaagedk [mailto:reklamefoto@...] > > - to get the best possible B&W digital prints? > > ImagePrint RIP + Epson 1290 + UltraTone inks > > or > > ImagePrint RIP + Epson 2200 + Epson UltraChrome inks > > or > > The (free) QuadTone RIP + Epson 1160 + Quad Inks (which ink set?) Can't advise you as to the output quality, not having used any of those combos. However, I'll remind you that the 2200 has some other nice features which might weigh in the mix: FireWire interface, USB2 interface, individual ink tanks, seven colors, paper cutter, higher resolution. -- Ciao, Paul D. DeRocco Paul mailto:pderocco@...
2003-12-30 by A. Huntley
Bjorn, >I know the results from the Imageprint/Epson 2200 combination. >But it has only the black and the photo black to mix. IP reportedly uses all the inks, except for Yellow. From what I've read, the Yellow position is not used to avoid any hint of metamerism. >Will I get a better result if I use a dedicated b&w printer with f.ex. a MIS quad inkset (4 >or 6 shades of gray) in combination with a workflow or a RIP? Better? That's a really tough call and you would probably get about as many answers as the number of people you ask. My former B&W setup was an Epson 1160 running MIS UT inks and using Paul's latest curves. IMO, this combination provided the best B&W on EEM or PR of any process that I, personally, had used. I went with IP because I wanted better color output, and because I grew tired of the "tinkering" required to keep a dedicated B&W printer running properly. I don't print often enough to avoid issues like clogs. However, after pulling out a John Custodio (spelling?) print on PR that I forgot I had--printed on an Epson 7000 with, I believe, the original Piezo inks--I may set back up my Epson 1160 with Jon Cone's new ICC profiles and Piezo Warm Tone inkset. For certain images I simply love that more chocalate (sepia) tonality! Really it comes down to what you want to see in your prints. >Imageprint (Colorbyte) has profiles for a lot of ink/paper combinations. Another reason I went with IP. However, after having a custom profile made by Andrew Rodney of imagingrevue.com I'm here to tell ya a better profile than ColorByte's can be had. Makes sense...CB provides generic 2200 profiles and mine was made specifically for my particular printer. I know this is a B&W print forum, but if you want to see the absolute best color that a 2200 can deliver go with IP and a custom paper profile! Alan Huntley
