New icc based Soft-proof profiles for QTR
2004-01-13 by Carl Schofield
I recently discovered (stumbled across) a way to create standard icc
profiles that can be used for soft-proofing QTR prints in Photoshop.
I've put a sample soft-proof profile that was created from an icc
profile for a QTR sepia curve that I use quite often in an archive on
my filesharing site.  Just drop the proof profile (sepia1.psf) in the
folder Library>Application Support>Adobe>Color>Proofing and follow the
illustrated instructions for using the soft-proof in the read-me file
that is also in the archive.  You don't need to be using or have QTR
installed to just see how any RGB or grayscale image you have will
actually look if it were printed with QTR and the sepia curve I'm
using. The read-me also has instructions for creating the icc profiles
if you want to make your own.  This can be applied to any inkset/paper
and probably with quad workflows other than QTR as well.  One of the
nice things about using standard icc soft-proof profiles is that you
can work up your image for printing in any mode (full RGB color or
grayscale) and get a preview of the printed results as you do RGB to
grayscale conversions, curve adjustments, etc. with the soft-proof
turned on.
The softproof archive with the profile and tutorial is in the QTR
Soft-proof folder at:
http://homepage.mac.com/scho/FileSharing2.html
Re: New icc based Soft-proof profiles for QTR
2004-01-13 by Tyler Boley
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Carl Schofield
snip
Nice work Carl, you got it exactly right. Have you tried going
directly from RGB to gray with the target, rather than through LAB? If
both are the same gamma it may work fine. I did it the LAB way, but am
wondering about the effects of the various methods of getting to gray
to print the target with our various output methods that want a single
channel file.
I've not discovered a way to get i1 photo to accept custom charts,
tried a number of things. If you come across something that works let
us know. Of course ProfileMaker will let you, but at a major cost.
Until then I think you are stuck with single patch reading, the charts
were designed with good color contrast from patch to patch so the
convert to monochrome probably confuses it at some patch borders.
Also, with ColorLab, you could design your own charts with patches in
colors that might be more helpful for accuracy with these particular
printing methods.
Cool,
Tyler
PS- Culbertson surfaces yet again, years later.
Re: [Digital BW] Re: New icc based Soft-proof profiles for QTR
2004-01-14 by Carl Schofield
Thanks again for your help Tyler.  It was your assistance and tips on
using MeasureTool and ColorLab that got Roy and I on the right path
using the Eye-One with QTR for linearization.
I was uncertain about how to convert the target to gray and thought
that using LAB might be safest to start with (assuming luminance
wouldn't change), but as you noted direct conversion to gray, keeping
the same gamma, should also work fine.  Roy also suggested trying
custom targets and reference files made with ColorLab and if i1Match
doesn't accept them then perhaps the strip reading can be done in
MeasureTool which has a provision for reading targets with boundaries
between the patches without error checking.  I've been able to get
i1Match to accept the standard target data that was patch read in
MeasureTool so hopefully it will take strip read data as well.
I went way back into the archives of the lists and some older files on
the net and re-read some of Dan's groundbreaking work in this area and
his findings were certainly an inspiration to try this approach.
> snip
> channel file.
> printing methods.
> Cool,
> Tyler
2004-01-14 by Tyler Boley
Give yourself some credit Carl, even with Dan's old work few if any
have carried it forward. It takes some creative thinking to come up
with this stuff. Your thought about L values seems right to me as
well, but then there is always that final conversion to gray, and then
WHICH gray? But if your profile is previewing properly to your prints,
that's all that matters and the converions must be valid. I'm in the
process of doing the same thing for StudioPrint here, and this
approach can be used to preview literally any type of printing with
any kind of output system, any of your ink mixes on any paper.
Paper white and ink black are useful as well.
Good to know Match doesn't choke on these values so far from the
expected color, Profiler Pro works as well.
Tyler
Re: [Digital BW] New icc based Soft-proof profiles for QTR
I've found a way to strip read the targets.  I used ColorLab to create
new reference and target files from the original i1 RGB 1.5 reference
file.  I converted the target tif to LAB-L and then gray (gamma 2.2) as
before for printing. The new reference file is placed in the reference
files>printer>eye-one> folder in the ProfileMaker Pro folder so it can
be accessed by MeasureTool.  The new target tif file has borders around
the patches and it is easily strip read in MeasureTool.  You need to
check spectral data in the configuration and then pick the new target
reference file from the chart pop-up list and specify strips with gaps
before reading the strips.  The data is saved from MeasureTool as a
text document and the file is placed in the i1Match measurement
data>printer folder.  Next, open i1Match, select the radio button "load
the measured chart" and open the file that was read and saved from
MeasureTool.  i1Match will then create the profile and it did so
without errors on my first try.  I've added the new target and
reference files to the Softproof archive on my filesharing site for
those that want to try making their own softproof icc profiles with the
eye-one.
Carl
> turned on.
2004-01-14 by Roy Harrington
Hi Carl,
I see you've been scratching away at this, too.   I've also been figuring
out how to use this.  I managed to figure out that the reference files
names are hard coded into Eye-One Match so that why we haven't been
able to get it to recognize other Ref files.  So I converted the 21 step
Ref file to an RGB description rather than Grayscale, and just overwrote
the existing i1 RGB 1.5 file (save it first).  This works like a charm.
Just use the ordinary step-21-random.tif file for printing -- in fact I
already had linearized print outs from before.   All you need to do is
run i1Match and scan the strip.  Voila instant soft-proofs and it'll
work for any kind of grayscale output scheme -- QTR, Roark, Piezo.
Roy
www.harrington.com
Here's the new ref file:
Date: 9/8/2003  Time: 18:47
LGOROWLENGTH 01
BEGIN_DATA_FORMAT
SampleName	RGB_R RGB_G RGB_B
END_DATA_FORMAT
BEGIN_DATA
A1	178.5	178.5	178.5
B1	76.5	76.5	76.5
C1	242.25	242.25	242.25
D1	140.25	140.25	140.25
E1	38.25	38.25	38.25
F1	204	204	204
G1	102	102	102
H1	0	0	0
I1	165.75	165.75	165.75
J1	63.75	63.75	63.75
K1	229.5	229.5	229.5
L1	127.5	127.5	127.5
M1	25.5	25.5	25.5
N1	191.25	191.25	191.25
O1	89.25	89.25	89.25
P1	255	255	255
Q1	153	153	153
R1	51	51	51
S1	216.75	216.75	216.75
T1	114.75	114.75	114.75
U1	12.75	12.75	12.75
END_DATA
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Carl Schofield <scho@m...>
> eye-one.
> Carl
> > turned on.
Hi Roy,
Terrific!  That really is a time saver.  I also noticed that the ref
files were hard wired into i1Match and wouldn't accept anything else.
I'll give your new ref file a try.  Many thanks for working this out.
Carl
On Wednesday, January 14, 2004, at 03:34  PM, Roy Harrington wrote:
> Hi Carl,
> figuring
> step
> Roy
> www.harrington.com
> LGOROWLENGTH 01
> BEGIN_DATA_FORMAT
> END_DATA_FORMAT
> BEGIN_DATA
> B1	76.5	76.5	76.5
> F1	204	204	204
> G1	102	102	102
> H1	0	0	0
> M1	25.5	25.5	25.5
> P1	255	255	255
> Q1	153	153	153
> R1	51	51	51
> END_DATA
> <scho@m...>
>> as
>> around
>> "load
>> the
>> eye-one.
>> Carl
>>> the
>>> profiles
>>> inkset/paper
>>> turned on.
> If you wish to receive no emails or just a daily digest, or you wish
> this same page.
> - As threads develop, trim off excess portions of earlier messages to
> keep them short.
> flames. Hostile, aggressive or argumentative users may be removed from
> the membership without notice.
> - Keep your posts and threads related to the group topic of digital
> B&W printing. Users who persistently make off-topic posts may be
> removed from the membership.
> guidelines, and to abide by the actions and decisions of the group
> Owner and Moderators. See “Group Topic, Rules and Guidelines” in the
> Files section:
> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE
> PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE “OWNER”
> AND “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE
> LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
> CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO,
> DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE
> LOSSES (EVEN IF THE  “OWNER” AND “MODERATORS” OF DIGITAL BW, THE PRINT
> YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES),
> RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW,
> THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF
> YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD
> PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER
> MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
> To visit your group on the web, go to:
> To unsubscribe from this group, send an email to:
>  DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com
> Your use of Yahoo! Groups is subject to:
>  http://docs.yahoo.com/info/terms/
2004-01-14 by Joe Davajon
Roy Harrington,
Roy, some months ago, if memory doesn't fail, you were
working on resolving how one can best coat prints.
I'm curious to know if you are still considering this
issue and whether or not you have been able to deal
with it satisfactorily?  I'm also wondering that if
you are using a Meyer rod are you having a high rate
of success.  If so, are you using a number 30 rod?
Personally, I find the #30 puts on too heavy a coat.
I tried a #10 and it works beautifully for letter
sized prints but doesn't work well for 13x19 prints.
Thanks for any consideration.
Joe D.
Re: [Digital BW] Coating Prints, was New icc based Soft-proof profiles for QTR
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Joe Davajon <davajon@s...>
wrote:
> Roy Harrington,
> Joe D.
Hi Joe,
No, sorry, it was somebody else.  I think Paul Roark and some
others were doing this.  I followed a lot of the discussion but
couldn't see getting into all the mess.
Roy
Roy- Outstanding! This is probably obvious, but I want to doublecheck
with you. The values below look like RGB numbers, which suprises me a
tad for a profiling reference file, rather than LAB. So RGB values are
what Match wants to see?
Also, can I assume from your work here that I can create my own
targets and ref files as you have done? I'd like more than 21 patches,
I find these profiles don't predict some areas well, like 95 to 100%,
and more samples might help.
You guys are smokin' now!
Tyler
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Roy Harrington"
<roy@h...> wrote:
> Hi Carl,
figuring
> Roy
> www.harrington.com
> LGOROWLENGTH 01
> BEGIN_DATA_FORMAT
> END_DATA_FORMAT
> BEGIN_DATA
> B1	76.5	76.5	76.5
> F1	204	204	204
> G1	102	102	102
> H1	0	0	0
> M1	25.5	25.5	25.5
> P1	255	255	255
> Q1	153	153	153
> R1	51	51	51
> END_DATA
<scho@m...>
create
2.2) as
reference
can
around
gaps
"load
with the
> > eye-one.
> > Carl
archive on
in the
follow the
file
profiles
inkset/paper
> > > turned on.
2004-01-14 by Sören Lindqvist
Roy
I would like to try your suggestion and reference file.
Just an update on this thanks.
Were do you get this "Just use the ordinary step-21-random.tif
file "? This file you rename to "i1 RGB 1.5.tif", print it and take
the readings with i1Match using your referencefile?
Soren
21 step
charm.
fact I
do is
it'll
> Roy
> www.harrington.com
> LGOROWLENGTH 01
> BEGIN_DATA_FORMAT
> END_DATA_FORMAT
> BEGIN_DATA
> B1	76.5	76.5	76.5
> F1	204	204	204
> G1	102	102	102
> H1	0	0	0
> M1	25.5	25.5	25.5
> P1	255	255	255
> Q1	153	153	153
> R1	51	51	51
> END_DATA
2004-01-14 by Stan Jakubek
Attachments enclosed.
Stan
  Sent: Wednesday, January 14, 2004 5:31 PM
  Subject: [Digital BW] Re: New icc based Soft-proof profiles for QTR
  Roy
  Soren
  21 step
  charm.
  fact I
  do is
  it'll
  > Roy
  > www.harrington.com
  > LGOROWLENGTH 01
  > BEGIN_DATA_FORMAT
  > END_DATA_FORMAT
  > BEGIN_DATA
  > B1      76.5      76.5      76.5
  > F1      204      204      204
  > G1      102      102      102
  > H1      0      0      0
  > M1      25.5      25.5      25.5
  > P1      255      255      255
  > Q1      153      153      153
  > R1      51      51      51
  > END_DATA
  - By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See "Group Topic, Rules and Guidelines" in the Files section:
  BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
  Yahoo! Groups Links
I got it, your referncefile is renamed to "i1 RGB 1.5.txt".
What about the step-21-random file?
Soren
> Roy
take
> Regards
> Soren
been
> 21 step
> charm.
> fact I
> do is
> it'll
Piezo.
> > Roy
> > www.harrington.com
> > LGOROWLENGTH 01
> > BEGIN_DATA_FORMAT
> > END_DATA_FORMAT
> > BEGIN_DATA
> > B1	76.5	76.5	76.5
> > F1	204	204	204
> > G1	102	102	102
> > H1	0	0	0
> > M1	25.5	25.5	25.5
> > P1	255	255	255
> > Q1	153	153	153
> > R1	51	51	51
> > END_DATA
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Tyler Boley" <tyler@t...>
Yes, everything is based on RGB values presumably because that's what
most people use.  Under the Eye-Match directory (folder)  there are
TIFF target files -- lots of random color patches.  There's one called
"i1 RGB  1.5.tif"  and under Reference files the file "i1 RGB 1.5.txt" is
a standard text file describing all the RGB values from the tif file.
So instead of these files, I'm using my 21step wedge that was designed
for eye-one reading Step-21-random.tif  in the Eye-One folder.
I had a Ref file for it but in grayscale description instead of RGB.
I just edited the Ref file into RGB values:
      R = G = B = (100-gray) * 2.55
Fortunately, i1Match is perfectly happy as long as the description
Ref file matches what you actually scan.
I also have a 51 patch target that'll give you every 2%, I'll can send you
a new RGB Ref file for it.
I hadn't really thought about soft proofing much, except with the eyeball
custom dot gain.  But when Carl brought up the idea and what he
had done, it was a terrific idea.
Roy
> Tyler
> <roy@h...> wrote:
> > Hi Carl,
> figuring
> > Roy
> > www.harrington.com
> > LGOROWLENGTH 01
> > BEGIN_DATA_FORMAT
> > END_DATA_FORMAT
> > BEGIN_DATA
> > B1	76.5	76.5	76.5
> > F1	204	204	204
> > G1	102	102	102
> > H1	0	0	0
> > M1	25.5	25.5	25.5
> > P1	255	255	255
> > Q1	153	153	153
> > R1	51	51	51
> > END_DATA
> <scho@m...>
> create
> 2.2) as
> reference
> can
> around
> gaps
> "load
> with the
> > > eye-one.
> > > Carl
> archive on
> in the
> follow the
> file
> profiles
> inkset/paper
> > > > turned on.
Sören,
I guess I was a little cryptic.  In the QuadToneRIP dsitribution there's a
folder CurveDesign/Eye-One that contains target tif files and reference
files.  step-21-random.tif is a 21 patch target, the new Ref file is
just the text I had in the previous post -- just copy and paste into an
plain text file.
I guess this warrants a comprehensive writeup of the technique.
Roy
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Sören Lindqvist
<soren.lindqvist@t...> wrote:
> Roy
> Regards
> Soren
> 21 step
> charm.
> fact I
> do is
> it'll
> > Roy
> > www.harrington.com
> > LGOROWLENGTH 01
> > BEGIN_DATA_FORMAT
> > END_DATA_FORMAT
> > BEGIN_DATA
> > B1	76.5	76.5	76.5
> > F1	204	204	204
> > G1	102	102	102
> > H1	0	0	0
> > M1	25.5	25.5	25.5
> > P1	255	255	255
> > Q1	153	153	153
> > R1	51	51	51
> > END_DATA
2004-01-15 by Sören Lindqvist
Thanks Roy
Would be nice to be able to download thoose files you mentioned (the
larger one as well 51 patch target) any adress?
I'm using PC, so QuadTone is not working for me.
Sören
there's a
reference
is
into an
> plain text file.
> Roy
2004-01-15 by Tyler Boley
<roy@h...> wrote:
snip...
send you
Only if you already have it Roy, don't go to any work. Sounds like
they are easy to make.
Tyler
2004-01-15 by Carl Schofield
Roy & Tyler,
The converted ref file seems to be working very well Roy.  I also
converted the 51 step file to RGB (used ColorLab to do it - just open
special the ref file and set mode>RGB and it does all of the conversion
calculation), but I haven't made any critical comparisons between the
21 step and 51 step yet - step wedges from both compare well to the
proofs.  This proofing method also works well for BO and compared to
dot gain proof profiles is better because you also get the paper color
effects incorporated into the proof and hence you get more accurate
tonal proofing.  Since my 1270 was also loaded up with UT (original)
inks I also generated some profiles for Paul's curves (the NCA warm,
cool, neutral cool, and neutral warm with the RGB workflow) - also got
good proofs, so this clearly can indeed be used for a variety of
inksets and printing workflows.
Carl
> <tyler@t...>
> is
> you
> eyeball
> Roy
>> Tyler
>> <roy@h...> wrote:
>>> Hi Carl,
>> figuring
>>> files
>>> step
>>> charm.
>>> fact I
>>> is
>>> Roy
>>> www.harrington.com
>>> LGOROWLENGTH 01
>>> BEGIN_DATA_FORMAT
>>> END_DATA_FORMAT
>>> BEGIN_DATA
>>> B1	76.5	76.5	76.5
>>> F1	204	204	204
>>> G1	102	102	102
>>> H1	0	0	0
>>> M1	25.5	25.5	25.5
>>> P1	255	255	255
>>> Q1	153	153	153
>>> R1	51	51	51
>>> END_DATA
>> <scho@m...>
>> create
>>>> reference
>> 2.2) as
>> reference
>> can
>> around
>>>> target
>> gaps
>> "load
>> with the
>>>> eye-one.
>>>> Carl
>>>>> icc
>>>>> Photoshop.
>> archive on
>> in the
>> follow the
>> file
>>>>> QTR
>> profiles
>> inkset/paper
>>>>> the
>>>>> you
>>>>> to
>>>>> turned on.
> this same page.
> keep them short.
> Files section:
2004-01-15 by Roy Harrington
Hi All,
I've done a short write up with all the needed files and information.
Download from here.
http://harrington.com/SoftProofing.sit
I've done this on a Mac but there's no reason this shouldn't work just
as well on Windows -- locations as probably different.
Roy
www.harrington.com
QTR linearization using i1 Match 2.0? (Was: New icc based Soft-proof...)
2004-01-15 by zhi-da zhong
Roy & Carl,
Thanks for the outstanding work!
Now that you've figured out how to make i1 Match 2.0 read the gray strips, I'm
wondering if we can use it for linearization. It should be possible since i1
Match allows you to save the measurement data to a text file.  I don't know if
MeasureTool outputs measurements in a different format, so the calc-density script
might need to be modified to work with i1 Match files.
Just a thought.
thanks,
- z.
2004-01-15 by Steve Kale
Guys this stuff is really exciting!  It drives right back to the points I
was grappling with a while ago, namely that if one can read a step wedge of
QTR output for a known input that it ought to be possible for an ICC profile
to be made to do the mapping.  Unfortunately I do not have the technical
background ­ you guys clearly do!   You can¹t be far away from a full
integrated ICC profile approach workflow BUT with the added benefit of being
able to manipulate the driver for a range of factors and then regenerate the
ICC profile.  QTR must be but a few steps away from moving from a Same As
Source workflow to using the generated ICC profile for the QTR driver, ink,
paper, printer combination a la the colour workflow many are used to.  I
guess it just depends which side of the fence you want to put the
translation.   I look forward to going through this stuff in more detail.  I
am still trying to fully get my head around the earlier partitioning
work....so little time!
Reply-To: DigitalBlackandWhiteThePrint@yahoogroups.com
Date: Thu, 15 Jan 2004 01:26:43 -0000
Subject: Re: [Digital BW] New icc based Soft-proof profiles for QTR
Hi All,
Download from here.
Roy
www.harrington.com
page.
them short.
the membership.
Moderators. See “Group Topic, Rules and Guidelines” in the Files section:
YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE “OWNER” AND
“MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU
GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  “OWNER” AND
“MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE
Yahoo! Groups Sponsor
 ADVERTISEMENT
 <http://rd.yahoo.com/SIG=12c6ugfs2/M=267637.4116732.5333197.1261774/D=egrou
pweb/S=1705019182:HM/EXP=1074216406/A=1945637/R=0/*http://www.netflix.com/De
fault?mqso=60178397&partid=4116732>
Yahoo! Groups Links
* To visit your group on the web, go to:
* http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/
* To unsubscribe from this group, send an email to:
* DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com
<mailto:DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com?subject=Uns
ubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
<http://docs.yahoo.com/info/terms/> .
Re: [Digital BW] QTR linearization using i1 Match 2.0? (Was: New icc based Soft-proof...)
I guess it could be done, but i1Match outputs spectral data and the
math (at least to me) is a bit more involved for extracting density.
The equations and a spreadsheet for doing this are on the following web
site:
http://www.brucelindbloom.com/
Carl
On Thursday, January 15, 2004, at 01:06  AM, zhi-da zhong wrote:
> Roy & Carl,
> strips, I'm
> since i1
> know if
> calc-density script
> Just a thought.
> thanks,
> - z.
> this same page.
> keep them short.
> Files section:
Hi Steve,
Soft proofing and ICC printing are pretty different things.  What we've don=
e
lately for soft proofing is just simulating the "look" of a print in RGB th=
at
you can see on a calibrated monitor.  It has no knowledge, notion or
whatever of how the ink got onto the paper.  In a sense that's the beauty
of it -- you can simulate the look of any method of printing.
ICC printing is a whole different thing.  An ICC profile can't do an arbitr=
ary
mapping to N inks because the output has to feed into an RGB Epson driver.
You can certainly accomplish a lot going through an RGB representation --
that's what the Roark workflows do and the new ICC stuff from Cone does.
But the more you modify the inks from what the Epson driver thinks is
in there, the more work it is to "fool" (i.e. design RGB curves) the driver=
 into doing
what you want.  The QTR approach is to have a driver that doesn't "think"
anything about the inks at all.  The thinking is all done a curve design
time in an intelligent way based on a description of the actual ink you are=
 using.
Roy
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Steve Kale <stevekale@=
b...>
wrote:
> Guys this stuff is really exciting!  It drives right back to the points I=
> was grappling with a while ago, namely that if one can read a step wedge =
of
> QTR output for a known input that it ought to be possible for an ICC prof=
ile
> integrated ICC profile approach workflow BUT with the added benefit of be=
ing
> able to manipulate the driver for a range of factors and then regenerate =
> ICC profile.  QTR must be but a few steps away from moving from a Same As=
> Source workflow to using the generated ICC profile for the QTR driver, in=
k,
> translation.   I look forward to going through this stuff in more detail.=
  I
> From: "Roy Harrington" <roy@h...>
> Hi All,
> Download from here.
> Roy
> www.harrington.com
> Please visit the Group Homepage to check the Files, and other resources a=
s
> unsubscribe, please edit your Membership preferences by visiting this sam=
e
> page.
> - As threads develop, trim off excess portions of earlier messages to kee=
p
> them short.
> printing. Users who persistently make off-topic posts may be removed from=
> the membership.
> guidelines, and to abide by the actions and decisions of the group Owner =
and
> Moderators. See "Group Topic, Rules and Guidelines" in the Files section:=
AND
TO YOU
EXEMPLARY
THE
> POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILIT=
Y
> TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO=
OR
OF ANY
>  ADVERTISEMENT
D=egrou
www.netflix.com/De
> ubscribe>
Yes, the spectral data would be a pain to deal with.  The MeasureTool
does a perfectly adequate job and I think its a easier customize i.e.
pick reference files at will.
Roy
> site:
> Carl
> > Roy & Carl,
> > strips, I'm
> > since i1
> > know if
> > calc-density script
> > Just a thought.
> > thanks,
> > - z.
> > this same page.
> > keep them short.
> > Files section:
"OWNER"
> > Yahoo! Groups Links
Excellent.
Thanks Roy,
Tyler
<roy@h...> wrote:
> Hi All,
> Download from here.
> Roy
> www.harrington.com
snip:
=What we've done lately for soft proofing is just simulating the "look" of a
print in RGB that
=you can see on a calibrated monitor.  It has no knowledge, notion or
=whatever of how the ink got onto the paper.  In a sense that's the beauty
=of it -- you can simulate the look of any method of printing.
Ok I guess I am not fully understanding this.  Your ICC profile maps the
image from Gray Gamma 2.2 into the gray space of the particular QTR setup
and then visually displays the results of this mapping on the screen (when
soft proofing).  When doing the proofing (and forgive me if this is in the
stuff I have not had the chance to look at yet) which space are you in?
Still Gray Gamma 2.2? Or does the doc have to be converted to RGB?
In order to create this ICC profile you have determined how a known set of
inputs get rendered by the particular QTR setup.  (The full gray spectrum is
presumably derived from an interpolation of these measured points.)  The
soft proofing feature of PS uses this mapping and an understanding of the
profiled monitor¹s display characteristics to visually represent the final
output.
=ICC printing is a whole different thing.  An ICC profile can't do an
arbitrary
=mapping to N inks because the output has to feed into an RGB Epson driver.
In my layman¹s view of QTR ­ and I am stating this so that you can correct
this if I am way off base ­ is that it does two things.  Firstly it takes
control of the individual print heads and defines how they are used to drive
a gray scale spectrum (rather than using the Epson formula for determining a
gray scale).  BTW, can you help me understand linearization a bit better?
Specifically I think I understand what¹s going on with the ink limits and
you have indicated that there is a mathematical function that then smoothes
these choices.  What is it that linearization adds over and above this
mathematical smoothing?
Secondly it takes each pixel value coming in and determines where on the ink
curve it sits, ie how pixel x should be rendered.  Presumably this is a very
straightforward mapping.  The problem has been that there is no consistency
between how a screen renders the individual gray pixel values and how QTR
renders them.  Isn¹t this the conventional colour matching problem?  (Albeit
in a simpler space.)  The more I think about this I find myself thinking in
circles.  I guess if I can soft proof why fuss with the backend. But then I
can¹t see how this differs from the conventional colour problem which
requires a profile to soft proof and the use of the same profile for
conversion at print.  Why don¹t we tag the file going to print with this
mapping function, either letting PS or QTR do the mapping, a la the two
different methods for colour printing?
The reason why I am asking about linearization is because this is the point
where we first measure a step wedge.  Adopting this new soft proofing we do
so twice.  Once for linearization and then secondly for a soft proof
profile.  In the colour analogy (and I think of B&W as simply a very very
narrow colour space) I would do so once only and this would then be used for
both soft proofing and to define how colour or shade of gray x is mapped for
the printer so that WYSIWYG.
I don¹t see the Epson or any other driver that differently.  Somehow it has
a formula for driving the print heads to produce ³colour² x.  But pixel
value x may correspond to a different shade of gray by the printer than what
is displayed on screen and so we use an ICC profile to shift these so that x
on screen is the same as x on paper.  This mapping can either be done by the
driver or by PS before getting to the driver.
So, I guess I am wondering if an ICC profile constructed as you have done
can be used to simplify the front end curve design process by using it to
first map things to the display space for soft proofing and then mapping
things into the QTR space....perhaps an unlinearized one.
Sorry for the ramble but just trying to understand this better.....
Steve
b...>
wrote:
> snip:
> =What we've done lately for soft proofing is just simulating the "look" o=
f a
> print in RGB that
> =whatever of how the ink got onto the paper.  In a sense that's the beaut=
y
> image from Gray Gamma 2.2 into the gray space of the particular QTR setup=
> and then visually displays the results of this mapping on the screen (whe=
n
> soft proofing).  When doing the proofing (and forgive me if this is in th=
e
For SoftProofing you don't actually convert your file at all, but what is s=
ent to
the display does go through profile conversion.  So the file should be in
Gray Gamma 2.2 the entire time.  Ordinarily each gray pixel is converted
to RGB where R=G=B=gray, and sent to the display where some profile
is applied so you actually get a gray output i.e. gray input =>> gray outpu=
t.
When proofing an ICC profile is inserted in the middle that will alter the
RGB values so you see the correct colors.
> In order to create this ICC profile you have determined how a known set o=
f
> inputs get rendered by the particular QTR setup.  (The full gray spectrum=
 is
> soft proofing feature of PS uses this mapping and an understanding of the=
> profiled monitor¹s display characteristics to visually represent the fina=
l
> output.
I think it's worth an example here.  Say, without a profile your printer pr=
ints
too warm.  You create a printer profile that basically says "add more blue"=
I.e. it take file RGB values and ups the blue component.
Now take that profile and use it for proofing.  You already have a calibrat=
ed
monitor so gray shows as gray.  When you proof with that printer profile,
the profile is inserted in the middle and reversed.  So "add blue" becomes
"subtract blue" and what you see on the screen is a warm image -- the
same that came out of the printer.
> arbitrary
> =mapping to N inks because the output has to feed into an RGB Epson drive=
r.
> In my layman¹s view of QTR ­ and I am stating this so that you can correc=
t
> this if I am way off base ­ is that it does two things.  Firstly it takes=
> control of the individual print heads and defines how they are used to dr=
ive
> a gray scale spectrum (rather than using the Epson formula for determinin=
g a
> gray scale).  BTW, can you help me understand linearization a bit better?=
> Specifically I think I understand what¹s going on with the ink limits and=
> you have indicated that there is a mathematical function that then smooth=
es
What I mean by smooth is just that all the values are reasonably continuous=
no big jumps and also that there are no down turns.  Linearization starts
with the smooth gradient and puts the gray values in the correct spot.  So
50%K in the file makes 50% gray on the output.  It works on the 21 step
values.  Its just a tonal correction curve -- in PS if your image is too da=
rk
you go into Levels or Curves and make a correction curve.  Same thing.
> Secondly it takes each pixel value coming in and determines where on the =
ink
> curve it sits, ie how pixel x should be rendered.  Presumably this is a v=
ery
> straightforward mapping.  The problem has been that there is no consisten=
cy
> between how a screen renders the individual gray pixel values and how QTR=
> renders them.  Isn¹t this the conventional colour matching problem?  (Alb=
eit
> in a simpler space.)  The more I think about this I find myself thinking =
in
> circles.  I guess if I can soft proof why fuss with the backend. But then=
 I
You do have a bunch of circles here.  I think the break in the circle is th=
at
the ICC profile that can tell you how to display sepia on a screen has no
information whatsoever about how to print sepia on a printer with
arbitrary inks.
> The reason why I am asking about linearization is because this is the poi=
nt
> where we first measure a step wedge.  Adopting this new soft proofing we =
do
> profile.  In the colour analogy (and I think of B&W as simply a very very=
> narrow colour space) I would do so once only and this would then be used =
for
> both soft proofing and to define how colour or shade of gray x is mapped =
for
Before linearization you measure the wedge in order to create a linearizati=
on
curve -- this is like making a ICC profile that you will print with.
The second measuring takes place after linearization has been done, you
now want to measure and proof how the B&W printing really works.
> I don¹t see the Epson or any other driver that differently.  Somehow it h=
as
> value x may correspond to a different shade of gray by the printer than w=
hat
> is displayed on screen and so we use an ICC profile to shift these so tha=
t x
> on screen is the same as x on paper.  This mapping can either be done by =
It still boils down to the issue that ICC profiles and Epson drivers look a=
t
the world as colors represented in RGB.  With RGB more B means more
blue, etc, etc.  How can that come to grips with a sepia colored ink in
some slot?
> So, I guess I am wondering if an ICC profile constructed as you have done=
> can be used to simplify the front end curve design process by using it to=
> Steve
It's not intuitive, I'm still trying to understand a lot of it.  For me its=
an iterative process of seeing what works, figuring out how its possible,
and deducing how it works.
Roy
2004-01-16 by Steve Kale
Roy ­ thanks a lot.  There is a lot for me to think about here but I am
afraid it is now going to be the end of next week before I can get back into
it fully.  I must admit I have not yet made it into the Sepia world and am
thinking about this purely from the perspective of my 2100 loaded with
conventional UC inks and trying to get a B&W image that matches what I see
on the screen.  In particular, I was thinking of the warm curves where only
two inks are used K and LK.   Your points re a Sepia toner have made me take
a step back for further thought.   What of this hypothetical case: I load my
printer with two shades of brown ink ­ dark brown in the K position and
light brown in the LK position. Presumably QTR will faithfully print my grey
scale image in shades of brown brown (with a nicely linearized curve which I
forgot is linearized only with density values rather than RGB
measurements....).  Now if you I were to do an ICC profile according to your
instructions I could preview the image in its printed state.  But if I did
not want a brown image but rather a grey image then everything would be out
of gamut because there is no combination of brown that can make black (for
example).   A conventional use of ICC profiles (a la the colour world) would
show this.  I guess this is where the gap in the circle is with my earlier
thinking and I understand your points ­ it¹s not that I started with a brown
image and wanted to check how it would rendered in the printer¹s brown
space.  Presumably, though, it has some interesting eventual practicality
for a workflow which stays in RGB.  If one could profile the full colour
space capable of a particular printer and ink setup ­ be it just capable of
pure dead neutral shades of grey, warm shades of grey, or one much more
complex that introduces another element(s) of colour tint via a toner(s) ­
then one could work in RBG, introduce a tint or not, and manipulate the
image in RBG to increase or decrease the tint with the knowledge that
WYSIWYG.
So two last questions for now if you will permit me.    In the current setup
described by Carl and yourself, if I wish to produce a sepia-toned image,
can I alter and preview real time the amount of sepia that will be produced?
I suspect that all I can see is a version of the grey image sepia-toned
given one ink/curve setup and that if I want to see a more-sepia version I
would have to construct and apply another ICC profile for a different
toner/ink mix.  In a simpler case, if I can preview it  with the warm-EEM
curve or the cool-EEM curve but if I want to see it with 50:50 then
presumably another ICC profile must be produced.....The last question:  in
order to see the sepia version doesn¹t my workspace have to be a colour one
or is this taken care of automatically by PS when I proof?
Cheers
Steve
2004-01-16 by Roy Harrington
b...>
> afraid it is now going to be the end of next week before I can get back i=
nto
> it fully.  I must admit I have not yet made it into the Sepia world and a=
m
> conventional UC inks and trying to get a B&W image that matches what I se=
e
> on the screen.  In particular, I was thinking of the warm curves where on=
ly
> two inks are used K and LK.   Your points re a Sepia toner have made me t=
ake
> a step back for further thought.   What of this hypothetical case: I load=
 my
> light brown in the LK position. Presumably QTR will faithfully print my g=
rey
> scale image in shades of brown brown (with a nicely linearized curve whic=
h I
> measurements....).  Now if you I were to do an ICC profile according to y=
our
> instructions I could preview the image in its printed state.  But if I di=
d
> not want a brown image but rather a grey image then everything would be o=
ut
> of gamut because there is no combination of brown that can make black (fo=
r
> example).   A conventional use of ICC profiles (a la the colour world) wo=
uld
> show this.  I guess this is where the gap in the circle is with my earlie=
r
> thinking and I understand your points ­ it¹s not that I started with a br=
own
> space.  Presumably, though, it has some interesting eventual practicality=
> space capable of a particular printer and ink setup ­ be it just capable =
of
> complex that introduces another element(s) of colour tint via a toner(s) =
> WYSIWYG.
> So two last questions for now if you will permit me.    In the current se=
tup
> described by Carl and yourself, if I wish to produce a sepia-toned image,=
> can I alter and preview real time the amount of sepia that will be produc=
ed?
If you already have a way to produce a sepia image -- then and only then
it's possible to have a ICC proof to preview what you'll get.  But that ICC=
profile plays no role and can't help you actually print that tone.
I guess this is the main difference with color.  With color you also use th=
e
same ICC profile to help you get the print.   The reason it works for color=
is that both the display and the print driver take RGB values and those RGB=
values do influence the color of the print.
> given one ink/curve setup and that if I want to see a more-sepia version =
I
> toner/ink mix.  In a simpler case, if I can preview it  with the warm-EEM=
> presumably another ICC profile must be produced.....The last question:  i=
n
> order to see the sepia version doesn¹t my workspace have to be a colour o=
ne
PS takes care of it all.   The 50/50 blend is a feature of QTR that has no
counterpart in ICC profiles, so yes you'd have to print out a 50/50 wedge a=
nd
create a proof profile for it.
Actually the blend issue is an interesting topic and this may actually help=
in understanding profile usage.
It's a little work but you can make two layers -- one from each profile --
and vary the opacity of the top layer to simulate QTR blending.   You
can't have two profiles in one file so you need to do the effect of each
profile and get back to a common profile.
1) you should have settings: gray gamma 2.2 and Adobe RGB
2) take Grayscale and Duplicate it, conver to RGB and duplicate again.
    -- now you have two Adobe RGB files with gray image.
3) take one RGB file and Assign to Profile:  ICC Profile 1 (warm) and
then Convert to Profile: Adobe RGB  -- Relative Colorimetric and Black Poin=
t set.
4) take the other and Assign ICC Profile 2 (cold) and Convert to Adobe RGB =
too
5) now Select All, Copy one image, and Paste onto second.
You now have two layers and vary the opacity.  Also look at the RGB
values of each layer separately and combined.
If you follow all the changes -- number wise (RGB values) and color
wise on the display, it may help see what goes on behind the scene.
Roy
> Cheers
> Steve
2004-01-16 by Carl Schofield
Roy,
Thanks for the info on simulating QTR blending.  I just tried it and
compared the simulated blend to an icc soft-proof profile of a QTR
blend and they were reasonably close in appearance.  Here is a screen
grab (Adobe RGB tagged) of an RGB simulation of a 50% sepia and 50%
warm profile blend (made as you described below) on the right and the
original gray image on the left with an active icc soft-proof profile
of the same 50:50 blend.
http://homepage.mac.com/scho/comparison.jpg
If one didn't want to make icc profiles for a lot of blends, then this
would be an easy way to get close with a simulation from just two
profiles.  Should be possible to make an action to do the simulation
quickly.
Carl
On Thursday, January 15, 2004, at 08:27  PM, Roy Harrington wrote:
snip..
> help=
> profile --
> each
> Poin=
> t set.
> RGB =
> too
Nice, Carl.  I think there's probably an issue about how accurate ink blending
really is i.e. is the 50% point of a 50/50 blend exactly the average of the two?
Roy
wrote:
> Roy,
> quickly.
> Carl
> snip..
> > help=
> > profile --
> > each
> > Poin=
> > t set.
> > RGB =
> > too
2004-01-16 by Ernst Dinkla
The nicest preview would be a direct coupling of the tone slider
in the QTR driver with a warm<.>cold representation in the image
window. Must be possible to add to one of the Linux appliations
but will be difficult in any other setup like PS + Gimp-print.
Ernst
2004-01-23 by colorspanmam
Hello Roy
This is my first introduction to the group, as I joined it when
someone posted a reference to this posting on the Colormanagement
group in answer to a question I had put.
We have a fineart and photographic printing and giclee reproduction
business and have been in this business for over three years now. In
the past year we have been also printing B&W for photographers.
I have downloaded the files and am looking forward to testing this
out. I am running a Colorspan printer with four blacks, and wanted
just such a profile for myself to use in soft proofing the images I
am about to send to the printer.
The differences I can see here are that I am working with ARGB files
(converted from the scanner profile) as I scan the B&W negs in RGB
16 bit. I do not convert to greyscale, but send the files to the
printer in RGB. The RIP handles them this way best, and I then use
the profile for the media I am using, in 4 black inks in the RIP.
This profile is a proprietary one for the RIP and can't be used to
soft-proof in PS.
Would it give the same results if I convert the target files from
greyscale 2.2 Gamma to ARGB 1998 before sending them to the RIP to
be printed?
I also am using Gretag Macbeth Profilemaker Pro 4.1.5 with the Eye
One. I presume I can use this to generate the profile in the same
way, using your instructions?
If so, when converting to the ARGB profile, should I print one file
in each of the two rendering intents (perceptual and relative) to
generate a profile for each of the two possibilities of conversion
for the files I send out?
Best regards,
Ellie Kennard
Innovative Imaging Studio
http://www.iistudio.com
Harrington" <roy@h...> wrote:
> Hi All,
information.
> Download from here.
just
> Roy
> www.harrington.com
2004-01-23 by Tyler Boley
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "colorspanmam" <Ellie@=
> printer in RGB.
I'm not Roy, but here's an opinion. I'd just make normal RGB profiles with =
your software using a supplied RGB target. Treat it as though you would one =
of your RGB scans, send it to the printer as you normally would. Let the RIP=
 do what you normally would, converting to the apropriate proprietory media =
profile etc..
If the target file comes up in Photoshop uintagged, you might want to assig=
n (don't convert) it with whatever space your files are normally in when sen=
t to the RIP. That way the RIP will "convert from" in the same manner as a n=
ormal image file would.
Believe me, it'll work. Regarding intents, you don't need to worry about it=
 as the proper use of "preserve color numbers for previewing makes it irrele=
vant. If you do in fact pick between different intents in the RIP for differ=
ent images, then yes you will have to profile them separately.
Hope that helps.
Tylerÿ
2004-01-23 by Roy Harrington
Hi Ellie,
I'm wondering if the RGB file you send to the printer is basically gray
where R=G=B or at least close.   Or do the 3 RGB channels separately
control different inks to significantly control the density.
The main "new" thing was to use the RGB profiling that i1Match
already does to a Grayscale.  The reference file is actually still an
RGB definition but only values with R=G=B are used.  When the idea
first came up,  we actually used the ordinary RGB targets but I think
that had two difficulties.  First was how to drive a real grayscale print
method with an RGB target file.  Converting to Lab and keeping L
worked pretty well but its not exactly the same thing.  The other
problem was that the Eye-One reader scans patches that must vary
enough for the read to recognize transitions.  Reducing the target and
reference to just 21 gray values solved both issues.
So if your RGB files are essentially gray you should be able to just
convert the targets to RGB and print, and do the same proofing that
is described.
However, if your RGB files somehow encode different inks I would
think you might have to go back to the regular RGB references and
target -- just use i1Match as normal.  The difficulty will probably be
reading the patches, although you can do it without scanning.
The other issue is how well the i1Match software can deal with
colors other than real RGB.
I suspect you'll need to do various experiments and see what works
and how well.
Roy
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "colorspanmam" <Ellie@I...>
wrote:
> Hello Roy
> soft-proof in PS.
> be printed?
> Best regards,
> Ellie Kennard
> > Hi All,
> information.
> > Download from here.
> just
> > Roy
> > www.harrington.com
Hi Roy,
Thanks for the reply.
THe file that I get from a scanned BW negative have RGB values that
don't usually vary by more than about 10, and usually much less.
When I do the two hue/sat adjustment layers trick to desaturate etc,
the values are pretty well R=G=B.
I will try the conversion and see what I get. If that doesn't work,
I'll print the usual target on that ink combi and try to work it
that way.
Many thanks,
Ellie
> Hi Ellie,
gray
separately
an
think
grayscale print
and
just
> is described.
probably be
> and how well.
> Roy
Thanks for the reply Tyler,
I will try to make the profile from the converted file first, as it
might be difficult for the eye one to read the patches on the
ordinary target. I will try that one next, though, if the first
method doesn't give me the desired results. I will just give it a
try with the Profilemaker Pro software as I don't have Eye One
Match. It should work the same, at least I hope so.
Thanks also for the info on the rendering intents. I do not change
that at the RIP end.
Best regards,
Ellie
profiles with =
would one =
Let the RIP=
proprietory media =
> profile etc..
to assig=
in when sen=
manner as a n=
about it=
it irrele=
for differ=
> Hope that helps.
> Tylerÿ
Hi Ellie,
I suspect it'll work just fine then.  Use the file in my download and
just convert the gray .tif to RGB.  And as Tyler mentioned if you want
to proof multiple rendering intents, then you need a separate proof
profile for each one.
Let us know if it works satisfactorily.
Roy
wrote:
> Hi Roy,
> that way.
> Many thanks,
> Ellie
> > Hi Ellie,
> gray
> separately
> an
> think
> grayscale print
> and
> just
> > is described.
> probably be
> > and how well.
> > Roy
Ellie, as Roy noted you may have better luck measuring his chart. He
did a great job of organizing the patches so that you can strip
measure "without gaps". With your software you shouldn't have to
rename his text file either, making things a bit easier. Just drag his
text file into the ProfileMaker Pro x.x.x/Reference
Files/Printer/EyeOne folder. A note of caution, these conversions must
be done carefully as the software is assuming specific RGB values were
sent to the printer. Make sure you convert the gray chart to an RGB
space of the same gamma, and then assign, don't convert, the chart to
whatever space you normally send to the RIP. ProfileMakerPro and
EyeOne Match supposedly use the same algorythms, so it should work fine.
Tyler
> Best regards,
> Ellie
> profiles with =
> would one =
> Let the RIP=
> proprietory media =
> > profile etc..
> to assig=
> in when sen=
> manner as a n=
> about it=
> it irrele=
> for differ=
> > Hope that helps.
> > Tylerÿ
Thanks again Tyler,
I may have done this wrong then... I converted to the ARGB 1998
colour space, and I don't know if that is also 2.2 gamma. What would
be a similar gamma?
Also, 'assigning' a profile, is that the thing to do?
Ellie
<tyler@t...> wrote:
...snipped...
were
to
fine.
RE: [Digital BW] New icc based Soft-proof profiles for QTR
2004-01-23 by Paul D. DeRocco
> From: colorspanmam [mailto:Ellie@...]
> be a similar gamma?
Adobe RGB is gamma 2.2. sRGB is close to 2.2, but visibly different.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul D.
different.
Fine then. As I send to the RIP in that, there should be no problem.
Thanks.
Ellie
ARGB is gamma 2.2, so I think you did it right. If that is what you
normally send to the RIP then no further assigning is necessary.
Tyler
<Ellie@I...> wrote:
> Thanks again Tyler,
> be a similar gamma?
> Regards,
> Ellie
> <tyler@t...> wrote:
> ...snipped...
> were
> to
> fine.
2004-01-24 by colorspanmam
Thank you so much everyone for your posting on this subject and for
answering my questions.
I made the profile and it works perfectly. It gives an excellent
idea of how the print will look. I work in colour with a fully
colour-managed system, and felt really at a disadvantage in not
being able to judge the BW printing. Now I am happy.
On the other hand, I have not been able to receive any of the
messages from the list, only reading them on the Yahoo list online.
I have done different things, including finally going on digest, in
the hopes that at least that will arrive. We will see tomorrow.
Many thanks again and all the best,
Ellie
> Tyler
2004-02-27 by deepblue7600
I have used the procedure and files provided by Roy Harrington for
icc based soft-proofing of B&W.  The soft proofs are acurate for
images that are coming from ARGB, converted to gray, assigned gamma
2.2 and sent to ImagePrint.
I would like to have the same soft-proofing capabilities for gamma
1.8.  ImagePrint does a really nice job with G1.8 images.  The G1.8
soft-proofing profile I made with the Eye-One and the same
target/file do not provide accurate proofing.
What do I need to do to make a soft-proof profile for G1.8 source?
Do I have to do something to the target or the .txt Match is looking
at?
When starting with color images in ARGB space (G2.2) should I convert
to another color space with gamma 1.8 such as Apple RGB before going
through B&W conversion process?  Convert to G1.8 after processing or
just tag the image G1.8?  I'm a little confused here.
Eric
2004-02-27 by Roy Harrington
Hi Eric,
I haven't tried any gamma 1.8 workflows but I think this is what you need to do.
You need to get everything into gamma 1.8 spaces.
Assign Profile ... Target-21.tif file to Gamma 1.8   (not Convert to Profile).
I'd switch the Color Settings ... as well to gamma 1.8 and Apple RGB or
some other gamma 1.8 color space.  I don't think this is critical but if any
conversions get done they are in the correct gamma.
Now print the Target through ImagePrint and follow the same profile
creation method.  This profile ought to be useful for gamma 1.8 files.
As far as converting color images to grayscale 1.8, whenever you Convert
to a different gamma space you change the data values.  Whereas Assigning
just changes the space name not the data.  If you are going to be editing
in the new gamma 1.8 space based on the softproofing I don't think it
matters.  I'd try to get it into the right space while still in 16bit if possible.
(BTW, doesn't ImagePrint have any softproofing capability?).
Roy
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "deepblue7600"
> at?
> Thanks,
> Eric
2004-02-27 by Eric Brooks
Thanks for your help and all the work you've done to share your experience.
From your description of what you think should be done for a gamma 1.8 workflow, it seems that what I've done should have worked.  I tagged the target G1.8 and ran it through ImagePrint.  I did use the 51 patch target instead of the 21 patch.  I will try the 21 patch in case Eye-One measurement error caused non-linearities.
I will let you know if this worked.
ImagePrint does have a reasonably accurate soft proof for 8 bit images (Hi-rez view) in the layout window.  But that doesn't help when editing the image in PhotoShop.  Other than the tint picker for B&W mode, you don't want to use any of the correction tools in IP, they suck.
Eric
  Sent: Thursday, February 26, 2004 6:58 PM
  Hi Eric,
  Roy
  > at?
  > Thanks,
  > Eric
              ADVERTISEMENT
  Yahoo! Groups Links
2004-02-27 by donbga
Roy,
I know you have been beset with questions so here is one more if you
may indulge me.
What is meant by the phrase "rendering intents" in the context of the
sentence above?
Don Bryant
I'm not Roy, but I can help you with this one.
Rendering Intent (Perceptual, Relative Colorimetric, Saturation etc.) defines which characteristics of the original color space (Source Space) you are coming from that are to be preserved when mapping into another color space.  When the gamuts of the two spaces do not entirely overlap something has got to give.  By choosing a rendering intent you are telling the Color Management Module (CMM) what properties are important to you.  Proofing is the process of evaluating which intent best serves your image through a test print or changing the way it displayed on your monitor (soft proofing).
Perceptual - Attempts to preserve the visual relationship between colors by compressing the gamut. It usually comes at the cost of desaturation color.  Often used for photo printing.
Relative Colorimetric -  Preserves all in gamut colors  that are directly reproducible in both color spaces), clips out-of-gamut colors to the nearest reproducible hue, and scales the white point of the source to the white point of the target.
Saturation - Maps the saturated primary colors in the source space to the saturated primary colors in the target space, without bothering about differences in hue, saturation, or lightness.
No matter which Rendering Intent you use, a compromise of the original image will be made.  Proofing is important.
  Sent: Friday, February 27, 2004 1:27 PM
  Roy,
  may indulge me.
  sentence above?
  Don Bryant
  Yahoo! Groups Links
