OT dying monitor
OT dying monitor
2004-02-08 by bfwoolner
My NEC monitor is in its' death throes and I am taking suggestions.  Can the LCD flat screen monitors be calibrated with a Spyder?  Anyone know or have advice.
Thanks in advance.
Barbara Woolner
Re: [Digital BW] OT dying monitor
2004-02-08 by Joe Davajon
Thanks in advance.
Barbara,
The Spyder can be used with LCD screen.  When you
calibrate you can choose "LCD".  I've found the system
very helpful but not infallible.
Joe D.
Re: OT dying monitor
2004-02-08 by hitechfactoryworker
LCD still can't compete with a good CRT.  I just bought a NEC
FP2141sb and love it.  The monitor depth is surely greater, but
they've done a good job of minimizing it compared to past models.
Regards;
SteveO
2004-02-08 by Dragonfly Imaging & Printing
Barbara,
Yes, LCD monitors can be profiled quite nicely with a compatible spyder.
I have had good experience with the Eye-One Display and Spectro.
John Toles
Toronto, Ontario, Canada
http://www.dragonflyprinting.com/
http://www.colour-management.com/
> Date: Sat, 7 Feb 2004 17:32:26 -0800
> From: "bfwoolner" <bfwoolner@...>
> Subject: OT dying monitor
> Thanks in advance.
> Barbara Woolner
RE: [Digital BW] OT dying monitor
2004-02-09 by Paul D. DeRocco
> From: bfwoolner [mailto:bfwoolner@...]
If you don't have some overriding reason to go with an LCD, I recommend a
CRT, because they generally have a wider gamut, and they're reliably easy to
profile. If you must go with an LCD, be careful what you choose, because
even with very good tools some of them can't be profiled accurately.
RE: [Digital BW] Re: OT dying monitor
> From: Dragonfly Imaging & Printing
Only some LCDs can be accurately profiled by a Spyder, and indeed most
can't. That isn't to say that you'll get an error message telling you that
it was unable to calibrate it. It will simply miscalibrate it. I don't mean
to pick on the Spyder--I expect most devices will have similar troubles.
Although I can say from personal experience that the Eye-One Pro (the
36-band spectro) works better than a Spyder on marginal LCDs.
Re: [Digital BW] Re: OT dying monitor
2004-02-09 by Jeff Magidson
I recently bought an Apple 17" LCD studio display after using a LaCie
19" Blue III for the past few years. My original thought was to
continue to use the Lacie for photoshop work using a dual monitor
setup, figuring that the Apple was not good enough for critical work.
After profiling both monitors with a EyeOne, to my surprise and delight
I really prefer doing all my work with the Apple LCD display! I am able
to get Wonderful WYSIWYG with the Apple display, It requires next to no
warm up time for it to display accurate color, it is much easier  on
the eyes, much sharper, uses less electricity and no radiation. Unlike
most other LCD displays, the newer Apple displays do not change color
or density depending on the viewing angle.
Anyway... after two weeks of use I would never go back to a CRT !
- Jeff
> that
> mean
> troubles.
> From: Jeff Magidson [mailto:jef.jef@...]
I've heard good things about the high-end Apples, too.
I'm curious, though. When you profiled them both, and put them side by side,
did they look the same, color-wise? Could you put up an image (without any
out-of-gamut colors) on both monitors, and have them look identical?
2004-02-10 by grdglass@aol.com
Can the Apple LCD studio displays be used with PC setups?
Helene
2004-02-10 by Dragonfly Imaging & Printing
> Date: Tue, 10 Feb 2004 06:31:32 EST
> From: grdglass@...
> Subject: Re: OT dying monitor
>> delight
>> able
>> no
Indeed. The Apple LCDs profile very well.
They have an ADC connector, specific to Apple video cards.
You might be able to get it working with a PC, but you'd need a DVI to
ADC converter, and a PC with a DVI video card.
John Toles
http://www.dragonflygallery.ca/
