2004-02-11 by Paul D. DeRocco
> From: flyfishingusa2002 [mailto:tflyfish@...]
> I hope this is not too OT, but what print sizes do you use? US letter
> size, 8.5in x 11in is fairly close to the ratio of my Canon 10D which
> is fine, but the resulting format look to retanglular for my taste.
> What would you recommend? I have a large roll of Photo Rag to cut up.
> It's 36in wide by 38ft long. Should I be using the standard 8 x 10
> format? It looks ok, but I have to crop a lot to get to this ratio.
Let the subject of the picture guide you. Crop it on screen until you like
the effect, then decide how to print it. If your printer supports roll paper
(or you can jerry-rig it to use the roll), leave it on the roll, and cut
each print after you print it.
I can think of a couple of possible exceptions: if you're doing an
exhibition, and you want all your images to share the same aspect ratio, or
if you want to use standard mats to keep the price down. But in general, I
find that there is no fixed aspect ratio that works well for all pictures.
Ciao, Paul D. DeRocco
Paul mailto:pderocco@...
