Glossy for Pigments with a Fiber Based Air Dried Look - NO SPRAYING!
2004-02-11 by Editor P.O.V. Image Service
A few days back I got some samples of Lyson's new "Archival Quality Premium Matte" and "Archival Quality Premium Glossy" papers. These papers are reportedly an entirely in-house development by Lyson, with production, of course, outsourced to a European manufacturer. I've tried so many papers that I'm more than a bit skeptical when stuff like this comes in the door these days.. It's generally like "aggh!! another paper?!!" I did however test these papers with both pigments and dyes on Canon S9000s, EPSON 1280s, and EPSON 1270s. First, the heft of both papers is considerable. Their physical feel and stiffness are wholly reminiscent of matte and gloss traditional FB papers. However, they fed flawlessly through all the machines. I printed 21 step wedges on both media and love the results with EVERY ink I tried. Blacks are deep, rich, and transitions are smooth without tweaking default output. All that would be good news already, but I've always had problems with any glossy paper holding the pigment when using the MIS VM-S inks with warm toned curves - ruboff has always been a huge problem - solvable by spraying but I don't like spraying every print. So, I wondered how well this new Lyson glossy media would hold the pigments (heresy of heresies I know.. but I was curious). Well, I'll say I'm dumbfounded.. not simply impressed. On every other glossy paper I've used, the VM-S inks rubbed off. But, on the Lyson Archival Quality Glossy media.... well, let me give some detail.. Immediately after printing there was no bronzing, but pigments did ruboff somewhat, so I was resigned to another failure. I still decided to wait a day, hoping that results might be different after drydown, letting the print cure. Twenty-four hours later I checked again.. The high ink load areas felt different from from other areas, by different, I don't mean raised or that annoying embossed feel of some swellable polymer papers, the paper felt slightly tack to the touch when compared to areas with low or no ink load. However, there was no rub-off! NONE! and no bronzing! The tackiness still annoyed me, so I waited a bit more.. At the two day point the tackiness is negligible and clearly decreasing with time. Most importantly to me. The finished prints look and feel as much like traditional FB prints (glossy and matte) as anything I've tried. I can't give you dMax numbers as I don't have a densitomer (yet), but these papers are the best new media I have seen in some time. I'll try them with my UT 2 inks next, but given the results with the VM-S they should shine with the UT 2 inkset. These papers seem to be a multi-layer hybrid of some type, given the differentials I am seeing over time and the tackiness in high ink load areas etc. Now for the bad news. 1) The glossy paper should NOT be used in the 2200 - the "heavier" pizza wheels in that machine (and others with a similar setup) WILL leave tracks. 2) For now, the papers are only available in A4 and A3 sizes... Lyson USA hopes to be able to supply these papers in sizes up to 13x19 soon. I CAN say though, that I've found new papers of choice for headshots, retouching, and other letter sized and A3 output.. I'll try and get Paul some samples to test for dMax and in his fade chamber. Keith Krebs "Just some guy," caretaker of the Multiverse's largest EPSON printer User Community (highly recommended by Vogon Poets and MegaDodo Publications), at: http://groups.yahoo.com/group/EPSON_Printers/ and the Multiverse's largest Canon printer User Community at: http://groups.yahoo.com/group/Canon-printers "For the rest of you out there, the secret is to bang the rocks together guys" [Non-text portions of this message have been removed]
