Lighting to evaluate prints
2004-03-06 by charlsalash
What type of lighting do you use to evaluate your prints?
    What is the best compromise when you don't know under what type of
lighting your prints are going to be viewed (e.g:portfolio)?
  Thanks              Jerome.
Re: Lighting to evaluate prints
2004-03-06 by Tom Andrews
Hi Jerome,
Solux lamps provide excellent high quality light (solux.net).  I use them.  The bulbs
are available in a variety of color temperatures and beam widths.  Most galleries use
halogen lighting, so, if you exhibit, this is probably a good color temperature choice
for evaluating prints and a nice midground between daylight and incandescent.  It
can also be argued that the industry standard of 5000K is the way to go, but this is
less important to an artist doing his/her own work (me thinks).  Cheers,
Tom Andrews
http://www.wildlandart.com
>   Thanks              Jerome.
RE: [Digital BW] Lighting to evaluate prints
2004-03-06 by Paul D. DeRocco
> From: charlsalash [mailto:gureghianj@...]
Solux 12V halogens on a track. Pretty cheap. They come in two color temps
and three beam widths. I use the 5000K ones, although I found I had to boost
the line voltage up to about 130V in order to get them up to that temp with
the fixtures I bought (as measured with an Eye-One). Fortunately, I had an
old variac lying around gathering dust.
No perfect answer, but at least incandescents (e.g., halogens) have smooth
spectra that won't introduce any eccentricities of their own. Fortunately,
B&W is much more forgiving of illumination variations.
Re: [Digital BW] Lighting to evaluate prints
I'm going to give a try to halogen, it seems to be the best
compromise. Later, I will probably get some daylight lamps from Solux
  Thanks for your help.
                               Jerome.
Solux _are_ halogen.
