UT vs UT2 for glossy..
2004-03-09 by tronicart
Just ran out of UT and was wondering.. is the UT2 inkset a
significant improvement on glossy (PSPP) over the UT set?  Which
black would I use for glossy with the UT2 set?  Seems I've heard both
Ebony and Photo can work on glossy with UT2.
Any rub off problems on PSPP with UT2 like I've seen with UT?
Thanks for the help,
  -Daniel Perez
RE: [Digital BW] UT vs UT2 for glossy..
2004-03-09 by Paul Roark
Daniel,
>... is the UT2 inkset a significant improvement on glossy (PSPP)
>over the UT set?
Yes, that is one reason I made the inkset.  The UT inks tend to flood the
paper (too much light ink), and the dark cool toner has a bit too much
magenta in it.  (It was made for quads.  The UT2 inkset is the first one I
made specifically for modern printers.)
If you have a 1280 or better, the UT2 is the way to go.
> Which black would I use for glossy with the UT2 set?  Seems I've
>heard both Ebony and Photo can work on glossy with UT2.
With curves the UT2 inkset allows glossy printing with Eboni installed.  It
just uses the midtone inks.  The dmax is about 5% less than with Photo K.
With the glossy papers the dmax is so impressive that 5% is not enough of an
improvement to mess with.  This is especially true since the 5% PK advantage
comes with a gloss differential that is irritating.
I assume that is from the Eboni.  If you use the UT2 & Eboni with the
"Eboni-glossy" curves, you'll have 100% glossy-compatible inks on the paper.
There is some gloss differential on most papers.  I recommend a spray to
eliminate this, reduce bronzing, and protect the print.
For UT2 information, curves, and settings see:
http://home1.gte.net/res09aij/
Re: [Digital BW] UT vs UT2 for glossy..
Yes, I'm on a 1280.  So, printing with "Eboni-glossy" curves cuts out
the black position entirely?  While printing with "Photo-glossy"
curves kicks in the black position (with Photo K installed)?
I'm assuming a "Photo-glossy" curve with Photo K ink is 100% glossy-
compatible as well..
Also, is gloss differential the same as bronzing?
Thanks for the help, again.
  -Daniel Perez
<paul.roark@v...> wrote:
> Daniel,
> >over the UT set?
flood the
much
first one I
installed.  It
Photo K.
enough of an
advantage
the paper.
spray to
> Paul
> www.PaulRoark.com
Daniel,
That is probably the case.  I pull the lightest ink (blue curve,
yellow-position [sepia]) up to the top to turn it off.  As such the dark
gray and dark cold gray inks are all that is left.  Two inks firing gives a
better dmax than one ink by itself, even though the ink limit -- total ink
allowed by the driver - may be the same.
>While printing with "Photo-glossy" curves kicks in the black position
Yes.  The standard PK curves I've made for the UT2 inkset use PK in the
usual manner.
Yes.
Tehre are a number of gloss differential "artifacts."  The one I'm referring
to is that with 100% PK the glossy papers often get a mirror like look to
them at the 100% black patch.  I don't think it looks very good.
______________________________________
> Daniel,
> >over the UT set?
flood the
much
first one I
installed.  It
Photo K.
enough of an
advantage
the paper.
spray to
> Paul
> www.PaulRoark.com
they are often being updated.
page.
them short.
membership without notice.
the membership.
Yahoo! Groups Links
