--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "chipcarterdc"
<chipcarterdc@h...> wrote:
> I'm running Mac OS 10.3. IF (and it's a big if) I understand the QTR
> instructions correctly, I must download and install something called "Gimp-
> Print" before installing QTR. But wasn't it a conflict w. Gimp-Print (preinstalled
> on 10.3) and the Epson drivers that was causing all the headaches w. Epson
> printers a few months ago? (I currently have a 2200 and will be getting a
> 9600). I seem to recall that in order to get a 2200 (7600/9600) to work w.
> 10.3, you had to uninstall 10.3; reinstall it WITHOUT the Gimp thing (and
> perhaps w/out the Epson printer drivers included w. 10.3?); then download
> the Epson printer driver separately and reinstall it.
> The short question is: am I about to "break" my system by installing Gimp-Print
> in order to install QTR 2.0?
Mac OS X 10.3 does have a lot of potential print drivers and that can
cause some confusion. QTR, however, is self contained and should be
easy to use along side of the other drivers. QTR uses code from gimp-print
but not the pre-installed or a separately downloaded version. With QTR
you just download the QTR package and install the QuadToneRIP2.0.pkg,
do NOT download any separate gimp-print code. It makes no difference
if you have the pre-loaded version or not. This package contains all the
code needed.
You should also download the 2200-UC profiles from my website. There
is an Install2200 script in the downloaded folder. With the printer on
and connected via USB, just double-click on the Install2200 script. This
will setup a Quad2200 printer with all the curves ready to go.
For color printing you should continue to use the Epson supplied driver --
probably named "Stylus Photo 2200" or SP2200. If you have any doubt
whether you have the correct one -- in Print Setup, select the printer,
run Show Info, look at Printer Model and it should say "EPSON Stylus Photo 2200"
not something with Gimp-Print or QuadToneRIP. Finally if you need to
Add the Epson driver use Add Printer>EPSON USB
If you do have any difficulty, let me know.
Roy
