Re: [Digital BW] Autofx Photographic Edges
2004-03-19 by lea
I have a hunch you're doing something wrong...those edges are designed
to be used on photographs and indeed I've seen them on photos as large
as 16x20" without a bit of jaggie. The edge should conform to whatever
the resolution of the image you're applying it to...you might check to
make certain your image is in the 300 ppi range before you do the edge
effect.
Lea
Sent: Friday, March 19, 2004 2:50 PM
Subject: [Digital BW] Autofx Photographic Edges
Has anyone used this set of filters with success?  A friend of mine has
it and I was able to
try it for just a short while.  The range of Edge effects in particular
is quite appealing but I
was surprised to see that they are very very low resolution.  That is to
say, if I try to do an
edge effect for an A3 print then the effect is a bunch of squares like a
low res jpeg when
viewed even at 50%.  I guess this can then be blurred or something but
then the
underlying image is blurred also which is by no means ideal.    Was I
doing something
wrong or is this as good as this thing gets?
Steve
Please visit the Group Homepage to check the Files, and other resources
as they are often being updated.
unsubscribe, please edit your Membership preferences by visiting this
same page.
- As threads develop, trim off excess portions of earlier messages to
keep them short.
membership without notice.
printing. Users who persistently make off-topic posts may be removed
from the membership.
guidelines, and to abide by the actions and decisions of the group Owner
and Moderators. See "Group Topic, Rules and Guidelines" in the Files
section:
"MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO
YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR
EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF
PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE
"OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN
ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE
OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii)
UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA;
(iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE
PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW,
THE PRINT YAHOO GROUP.
Yahoo! Groups Links
2004-03-19 by Steve Kale
Hi Lea
The image I tested on was 16 x 10 inches at 360 ppi.  I didn¹t have the
chance to read the manual or anything.  We loaded the image in PS CS and
then clicked on the filter and used one of the layer presets.  When I then
hit ok and the adjusted image finally appeared in PS CS, looking at the
image at 50-100% reveals very heavy pixelation where the image was altered.
The interior of the image was not pixelated at all ie it was left alone as
one would expect.  I was using an edge which made the edge of the image look
etched away.
Steve
Reply-To: DigitalBlackandWhiteThePrint@yahoogroups.com
Date: Fri, 19 Mar 2004 15:01:21 -0600
Subject: Re: [Digital BW] Autofx Photographic Edges
effect.
Lea
2004-03-19 by DigitalLipothymy@aol.com
In a message dated 3/19/2004 4:02:10 PM Eastern Standard Time,
stevekale@... writes:
Has anyone used this set of filters with success?  A friend of mine has it
and I was able to
try it for just a short while.  The range of Edge effects in particular is
you can easily make your own Edges with watercolours or acrylic paint... just
paint a frame in the size that you want [the more uneven the edges, the
better], and scan it in at the resolution that you choose :)
k
