Just Installed UT2 CIS from MIS
2004-03-31 by glewis4457
and it seems to be operating just fine.  I used the prefilled
version of the CIS.  Now, what do I do with the the hinged lid since
it no longer closes properly and even seems like it might crimp the
plastic tubes from the ink bottles to the cartridge.  The printer is
located in a place which requires me to lean over the top of the
printer to put paper into the sheet feeder or to install the roll
paper holder and roll paper. Should I remove the hinged lid and come
up with some kind of cover to keep out the dust?
Jerry in Houston
Re: [Digital BW] Just Installed UT2 CIS from MIS
2004-04-01 by Sam McCandless
>Jerry in Houston
That's what I did, Jerry, but at the time I think some others were
using the foam earplugs hardware stores have as small bumpers to hold
the lid ajar. I've forgotten how they attached them, but I remember
worrying they might come loose and fall in. Of course, so might
something else as you lean over the printer, but for some reason I
never worry about that.
The Epson store on Epson's web site used to sell dust covers. I use
plastic bags to keep the scanners from getting jealous.
Sam
2004-04-01 by Kip Babington
If they have a flat bottom, you could use regular double stick tape, or
(the even stronger) industrial strength foam tape.
Kip
At 3/31/2004 08:41 PM -0800, Sam wrote, in part:
>worrying they might come loose and fall in.<snip>
