Hello Lon,
Not exactly an answer either, but I do use the MIS-FSN with the
Piezography ICC profiles and the results are outstanding.I have been
told the UT2-FSN work like the FSN but are much more archival. It's
also my understanding the FSN inkset will be discontinued at some
time in the near future, so I may be doing like you and trying the
UT2-FSN inkset. I've just gotten my workflow set up just right for
the FSN inks and now a change is in the wind, that's life.
Your friend in Photography,
Johnny
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "londuck"
<lon_c@h...> wrote:
> No luck with a response to my original question (below) so I
thought
> I would break it into parts so hopefully someone can help.
> Can the MIS UT-FSN inkset (with the "eboni" black) be easily used
> with the Piezopraphy ICC profiles on an Epson 1160 (possibly using
> the Selenium Portfolio ICC profiles).
> Has anyone tried this and is it a viable and easy to use workflow?
> Enjoy! Lon
> _____________________
> lon_c@h...> wrote:
> Is the MIS UT-FSN inkset a good match for both the:
> The old Cone software RIP (activated within Photoshop) and the new
> Cone B&W ICC profile software (uses Epson Driver).
> I have an unused 1160, so the mix up on the 6 ink printers is not a
> problem (between these two versions of software).
> Does the "photo black" used in this set really allow you to use
> glossy stocks with great results.
> Enjoy! Lon
